Does measuring an atom collapse the wavefunction of its parts?
In summary: If we measure the output of a quantum system, we usually measure L, S, and J.Can you give an example of how measuring one observable would affect another observable that was related to it?For example, measuring the spin of an electron would change the orbital angular momentum around it.
friend
1,452
Suppose you have an experiment that measures the property of an atom as a whole, maybe you can put it through a double-slit or measure its spin, whatever. Presumably that will collapse the wavefunction that you used to describe the atom in that experiment. Would this entail that in the process you collapsed the wavefunction of all the subatomic particles that made up the atom? Could you know the overall spin, for example, and not know the spin of all of the parts?
Yes, that's correct. Other observables might remain in a superposition even as a particular observable takes on a well defined value.
Likes bhobba
Thinking further on this. Would it be the case in measuring the spin of the atom, for example, that the spins of all the subatomic particles would have to at least add up to the value measured of the atom, but this would allow some freedom for various combinations of how those spins were distributed among the subatomic particles? So in effect does measuring the atom then put the subatomic particles into entanglement with each other, when perhaps before they were not? Or were they always entangled with each other? Thanks.
Your basic idea is correct, that there is freedom for the component particles of the system to have various combinations that sum to the observed value.
A good basic rule is that ground state electrons (say in helium), being indistinguishable, are entangled. You know their total spin is 0, for example, but there is no way to say which is +1/2 and which is -1/2. That is a recipe for entanglement.
Likes bhobba
When we talk about how many ways to get the same measured value, then that's the definition of entropy (and perhaps information). So it sounds like what we seem to be saying is that there is some entropy associated with measurement, at least in measurements of composite particles. And it sounds like we are also talking about entanglement. Do these considerations give us a mathematical connection between a measure of entropy and a measure of entanglement? Does this suggest they are both different ways of describing the same thing? Thanks.
Yes, subatomic particles are within atoms are usually if not always entangled. Entanglement is some constraint on two or more objects that can't be written as a constraint on each object individually. Since each constraint reduces the number of possibilities, it reduces the entropy. But you can have other kinds of constraints that reduce the entropy, so I wouldn't think too much about the connection between entanglement and entropy.
Perhaps it is time to learn about LS coupling (and jj coupling). We label the state of an atom or molecule using "term symbols" which include information about the magnitude of the total spin S, magnitude of the total orbital angular momentum L, and magnitude of the total angular momentum J. We can determine this information with spectroscopy. We don't know the direction of the total spin or the direction of the total angular momentum, but we do know that they add up to J. Since we don't know all the information, there are multiple microstates with the same term symbol.
Related to Does measuring an atom collapse the wavefunction of its parts?
1. What is the wavefunction of an atom?
The wavefunction of an atom is a mathematical function that describes the probability of finding an electron in a specific location around the nucleus of an atom. It is often represented by the Greek letter psi (ψ).
2. How is the wavefunction of an atom measured?
The wavefunction of an atom can be measured using various techniques such as spectroscopy or electron microscopy. These techniques involve interacting with the atom in some way and observing the resulting changes in its properties.
3. What does it mean for the wavefunction to collapse?
The collapse of the wavefunction refers to the phenomenon in quantum mechanics where the wave-like nature of particles is replaced by a definite position and momentum when they are observed or measured. This means that the particle's location becomes certain and no longer exists as a probability distribution.
4. Does measuring an atom collapse the wavefunction of its parts?
According to the principles of quantum mechanics, measuring an atom will cause its wavefunction to collapse and its properties to become definite. This applies to all particles, not just atoms.
5. Is there any way to measure an atom without collapsing its wavefunction?
There is currently no known way to measure an atom without affecting its wavefunction. This is a fundamental principle of quantum mechanics and is still being studied and debated by scientists.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
