I Does pressure affect the thermal breakdown of water?
Thermal breakdown (thermolysis) of water requires approximately 3000°C, and pressure significantly influences this process. Increased pressure shifts the equilibrium back toward water formation, complicating the thermolysis. The relationship between pressure and temperature can be analyzed using Gibbs free energy, where higher pressure raises the thermolysis temperature despite unchanged heat components. Real-world inefficiencies in pumps mean that high-pressure thermolysis demands more energy than ambient conditions. Additionally, maintaining the separation of hydrogen and oxygen gases is likely easier at lower pressures.
some bloke
TL;DR Summary
see title
As per the title, I'm trying to research how the thermal breakdown (thermolysis) of water works. I gather that you need circa 3000°C to get it to break down, which is a lot, and I'm curious as to how pressure might affect this.
I know that pressure affects the boiling point of water, and as such was concerned that a theoretical device which compresses superheated steam to increase it's temperature might counteract the desired effects of thermolysis by the increase of pressure making the required temperature for thermolysis higher.
I'd appreciate any reading that people can direct me to on this subject, I am contemplating a combination of heat, pressure and electrolysis for breaking down water into hydrogen and oxygen. I don't want to make the mistake of only considering the energy in this!
some bloke said:
Summary: see title
Qualitatively, the Le Chatelier`s principle is applicable here. Thermolizing water increase pressure (two water molecules split into one molecule of oxygen and two of hydrogen), therefore increased pressure shift equilibrum back to formation of water.
In detail, effect of pressure is affecting the entropy component ΔS of Gibbs energy , while heat component ΔH is unchanged. Therefore, with increased pressure, your energy expended to reach desired decomposition yield should not change if pump is 100% efficient, but termolizis temperature will increase. To calculate temperature of 50% thermolysis yield, your should solve Gibbs free energy equation ΔH-TΔS=0.
Of course, in real world 100% efficient pumps do not exist, therefore high pressure thermolysis of water will require more energy compared to ambient pressure thermolysis.
some bloke said:
Summary: see title
How do you separate, and then maintain separation, of the O2 and H2 gas? I would expect that to be easier at low pressure, rather than very high pressure.
Maybe you should look at the ultrasonic resonant cavitation experiments that reach temperatures between 10,000 K and 20,000 K.
https://en.wikipedia.org/wiki/Sonoluminescence
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
