Does pumping for speed really work?
In summary, the surfer would gain speed by pumping the wave. But they would only believe it does because it feels like it does. No one has ever taken a radar gun out to test it.
GiTS
135
Surfers would say it does but they only believe it does because it feels like it does. No one has ever taken a radar gun out to test it.
Pumping for speed is where you move up and down the wave face to try and increase your speed parallel to the wave. The belief is that you will gain a higher maximum speed quicker by doing this than simply riding the wave normally. But I am unsure of whether this is actually mathematically possible.
The example scenario i am choosing is a wave with a perfectly circular form (looking at it from the side you will see 1/4 of a circle). The wave also moves at a constant speed and is perfectly uniform with no break. After x amount of time both scenarios will end with the surfer having a final position on the same part of the wave with the same heading.
I've never surfed in my life, but I did think of one thing: if you average out your speed, shouldn't it be the same as the speed of the wave crest?
I think if you pump (I assume you mean bending your knees) you will gain a little speed. I notice the same effect on a skateboard, snowboard, whatever. However, you will then outrun the wave slightly, and you will slow down again. You get up slowly, and the wave catches up with you again. Then you pump again and the cycle starts again.
So I think 'locally', you can sometimes go a little faster. But if you average it out, you won't (otherwise you could surf on a wave that was actually like 30 meters behind you! Doesn't make sense...)
Speed of the wave crest? What do you mean by that?
I mean pumping as going up and down the wave face. The thing people do where they bob up and down on their board doesn't do anything if they aren't in a turn.
Well, the wave moves forward of course, probably with a roughly constant speed (I know the speed will get higher once it reaches the shore, but I assume you are surfing a way out into the sea, and not on 3 inch waves near the shore..)
Anyway, I believe my interpretation of 'pumping' was incorrect. I was thinking of the 'pumping' you see skateboarders do in a half-pipe. If you simply stand up straight you will lose much energy and come to a stop fairly quickly. But if you bend your knees and really 'drop' your weight into the pipe, you can easily increase your speed with every 'pump'.
For simplicity, imagine the reference frame of the propagating wave in a conservative system. As a surfer slides down the face of the wave, he/she gains speed because potential energy is turned into kinetic energy. Of course, the unique nature of the surfboard in a liquid also allows for "gripping" to go down the line. Pumping is, in effect, the surfer doing work, by "stepping" back up the wave to gain potential energy and immediatly sliding back down turning this into kinetic energy, thereby gaining speed. In real life there are also losses. The skill is to generate more energy than is being lost. I hope that helps.
There is an example that is a clear case of pumping to gain speed.
Check out this youtube video of http://www.youtube.com/watch?v=KP7IBUWdeZg", eventually building up to a 360. (Of course a 360 is possible only with a swing that doesn't have cables for suspension, but rods.)
Notice how the acrobat squats down on the descend, and stretches out when ascending again. As the acrobat stretches out he moves his center of gravity closer to the pivot point, and that pumps energy into the existing motion. For maximum efficiency the pumping must be precisely in tune with the existing swing.
Now, I never surfed, but I can imagine some mechanism that is similar to pumping a swing. In order to pump the surfer must move to a more upright posture when the board is climbing the wave, and during the descend the surfer must squat down.
I'm guessing that if the surfer gets in a good pump every three or four turns he will still gain. I'm guessing that most of the shifts of posture will be towards maintaining balance, and I suppose that all of that jostling for balance will tend to "hide" the squatting and stretching that do the pumping.
So it's conceivable to me that surfers feel they gain by pumping, while unable to pinpoint exactly how the gain is achieved.
Cleonis
I am with Nick89; you can't possibly go faster then the wave on average, but I suppose you could pump to move further down / forward on the wave should that be your desire…. I am guessing that is the reason, just for initial positioning, or to catch up with the wave once/if it starts to get away from you, but its all relative... at the end of the day you are either on the wave or not on the wave, and the wave does what it wants :-)
This need not be true - in the same way that sailing boats can easily move faster than the speed of the wind by moving at an angle across it.
The surfers I have seen are moving across the wave and can go a lot faster than the wave's forward speed. The forward speed of the wave is set by the Physics of the wave but their speed is limited by rate of Potential Energy that they can transfer and the friction / drag of the board in the water.
They are constantly falling down a slope which is being raised by the advancing wave (providing more Potential Energy for them). I imagine that the pumping is effectively 'walking' them higher up the wave slope a bit, giving them even more extra Potential Energy, which they can transfer to Kinetic Energy.
sorry, I did mean perpendicular to the wave but I didn't actually say that so fair comment!
another viewpoint is that the opposite to what you say is true in that by trying to traverse across the wave, the wave maybe wants to move underneath you more (more than if your board was longitudinally aligned I mean, because the rudder is then sideways on to wave and hence less likely to be 'skidded/slipped') and hence by pumping you are perhaps trying to move 'down' the wave to stop this happening (ie the pumping could be 'lowering' the centre of gravity)
In a (breaking) water wave, a lot of the water at the front of the wave is actually moving out to sea and upwards (as in the precursor to a Sunami and you also can see this as the foam just under the breaking head actually moves upwards). There is no bulk movement of water towards the beach. If anything, I should imagine, the skeg, when parallel with the wave crest, would actually help to lift the surfer. This is just what he wants (or she, of course) as it gives more Potential energy. I wonder, in the light of this, whether the pumping actually produces more lift as it pushes the board under the rising water.
We need an expert surfer to take this much further, I think.
Personally, I always got far too knackered when just trying to stand up to examine what was actually happening during my brief few seconds. I think I would die if I tried it now!
In addition to my previous answer, the sinesoidal oscillation of a small potential energy;
[tex]{V}_{0}Cos\left[k\left(z,E_0\right)r\right][/tex], where [tex]{V}_{0}=mgz[/tex] is the amplitude of oscillation and should be much smaller than the unperturbed kinetic energy, [tex]E_0[/tex]; r is along the wave line and [tex]k\left(z,E_0\right)[/tex] is the wavevector and is dependent on the height change and unperturbed kinetic energy, will lead to an average kinetic energy reduction, to first order in kr';
[tex]\frac{1}{8}\frac{V_0^2}{E_0}[/tex].
But this is [tex]~\frac{V_0}{E_0}[/tex] orders smaller than the kinetic energy gained due to work done
A breaking wave isn't a sinusoid, though. How does that effect the outcome of your analysis? The water is decreasing in depth and dispersion plus energy loss will changt things a lot. After all, people only 'surf' on surf and not on 'waves'.
huh? I meant the pumping action as a sinusoidal oscillation.
What evidence is there that successful pumping is sinusoidal? That sounds extremely unlikely.
I was simple making as estimation to compare how much the average kinetic energy drops if the motion goes up and down (without doing work). This was to see if it is comparable to the energy that is put in by doing the work.
The problem is that the only reason that the whole thing works is because nothing is behaving linearly or sinusoidally. The water flow on the surface of a breaking wave is very complex. The drag and general performance of a surf board is not what you'd expect from treating it like a simple displacement hull going through smooth water.
You can surf along across a breaking wave without any pumping and go faster than the wave is advancing. This is all because the water at the front of the wave is moving uphill - towards the crest - you just have to arrange that you are going at the optimum angle so that you are constantly 'falling' down the wave whilst being lifted up at the same time. This is the same sort of process as gliding in updrafts produced by sloping ground.
The pumping must be a way of increasing the sideways force from the rising water by forcing the hull deeper into the water and getting more lift. You can only do this in bursts, of course. Hence the pumping action.
Has no one a comment (positive or negative) about my observation that the water at the front of a breaking wave is moving upwards?
I saw it quite clearly the other day in some very impressive Atlantic breakers.
it will divide your speed into going up the wave and down when going down you will get an increase in const. speed and going up it will decreas but this will seem like you are going faster because of the acceleration and relative vision of you eye
I feel like no one read the whole thread.
sophiecentaur,
I was only making a pertubation to a simplified problem. I realize it is indeed extremely complex. But getting nowhere on an difficult problem is much worse than making a simplification.
Yes the front of a breaking wave moves upward and over the falls. It's an interesting questions, why do waves break at all? But irrelavent to if pumping increases speed.
This comment really frustrates me.
ExtravagantDreams
It confuses me too. I don't know what it can mean.
The crux of your point "But irrelavent to if pumping increases speed." is the "IF".
IF pumping alone would increase speed, people could pump their way up and over ordinary waves. Have you ever seen them doing this? Does anyone claim to have done it?
My explanation agrees with observed fact; always a good reason to accept things.
The reason that waves break in the way that they do can be explained by the reduction in wave velocity as water gets shallower. The wavelength gets shorter as a consequence and the water particles can no longer move in circular paths. The wave still has a lot of energy and this energy ends up as vertical movement. It starts with the motion getting elliptical (Major axis vertical) - increasing GPE changes c/w/ KE, I think. Eventually, the wave tumbles forward (breaks). Surfers use the upwards flow to gain PE, which they convert to KE. You could do precisely the same thing on a very wide travellator - maintaining your vertical height and going faster and faster, laterally. You could, with suitable control, ride a bike facing downwards on a travellator with your brakes on just enough to stay in the same place. The brakes would get hot with the energy that was being transferred to you - or you could use a dynamo to extract the energy.
As I said previously, pumping will give a better 'grip' (sideways drag) on the rising water and make better use of the available energy. So there is a reason for pumping to work which a sinusoidal model of a wave doesn't give.
sophiecentaur,
Ok, I see what you are saying now.
You're right that it only makes sense to pump on the face of a wave. Buf if I assume your argument for how pumping works is correct, I should be able to pump on an "ordinary" wave, since the front of non-breaking waves still move up, just not as dramatically. Well, ok, not entirely true. Shallow waves don't really allow you to use the edge of the board.
So, do you think, compared to just moving latterally on wave, the down turn will increase your speed just b/c you're falling faster. Then, doing a carving turn turns your new gained downward speed into latter speed while digging the board deeper into the water allowing you to get pushed up quicker without loosing much of this speed.
I'm glad you see what I mean now. It certainly made sense to me.
For non breaking waves, the water on the surface moves in circles and so would the surfer. I don't think there would be any significant difference in speeds so digging in wouldn't have any significant effect. I think the wave will just pass 'under you'.
I don't know the terms "down town" or "carving turn" but I think I agree with what you are saying, basically.
Sounds like you do some surfing. Next time you are doing it, try to observe if what I have suggested actually occurs. I will try to see what my sailing boat does in almost breaking surf - but she's nearly 9m long and needs at least 2m of water in the troughs, to be safe. It's all a bit dramatic to go near the surf because you're tending to run out of water at that stage and have other things on your mind! I think I remember being 'swept' up onto the tops of waves, though.
that was misspelled
Wot woz?
town=turn. Also, not sure if carving is the appropriate word, but I didn't want to call it a bottom turn, since it's not at the bottom.
You just went and shattered my ideas that you were a really cool surfer who uses all the right terms.
Surely surfing and knowledge of Physics can't be mutually exclusive!
FAQ: Does pumping for speed really work?
Is pumping for speed a scientifically proven method?
Yes, pumping for speed has been studied and proven to be an effective method for increasing speed in various sports and activities.
How does pumping for speed work?
Pumping for speed involves using your body's natural momentum and energy to generate speed. By using a combination of pushing and pulling movements, you can create a pumping motion that propels you forward.
What types of activities or sports can benefit from pumping for speed?
Pumping for speed can be applied to a variety of activities and sports, including skateboarding, snowboarding, surfing, skiing, and even cycling. It can also be used in other non-sports activities such as running or jumping.
Are there any risks or downsides to pumping for speed?
Like any physical activity, there is always a risk of injury if proper technique and precautions are not taken. It is important to start slowly and gradually build up your pumping speed to avoid strain or injury. Additionally, pumping for speed may not be suitable for individuals with certain medical conditions.
Can anyone learn how to pump for speed?
Yes, anyone can learn how to pump for speed with proper instruction and practice. It may come more naturally to some individuals, but with patience and dedication, anyone can improve their pumping technique and increase their speed.
