Does repeating a data transmission constitute spreading?
  • Thread starter Thread starter Tybalt
    Data Transmission
Repeating a data transmission can be seen as a form of spreading, as it utilizes more bandwidth than necessary for the signal. This is illustrated by TCP-IP's retransmission of packets upon receiving a NACK, which could be classified as a spreading scheme. In OFDM, interleaving data across subcarriers increases spectrum occupancy without changing total bandwidth, leading some to refer to this as spreading. Frequency-domain interleaving introduces repetition in the time domain, where the output of the IFFT can repeat based on the number of zeros inserted between data symbols. Understanding the distinction between spread spectrum techniques and data duplication in diversity schemes is crucial for clarity in this discussion.
Tybalt
TL;DR Summary
This is a question about defining spread spectrum. It seems that spreading should involve more than just repeating data symbols.
Generally, spread spectrum is defined as using more spectrum (or bandwidth) than is needed to transmit a signal. But according to this definition, even TCP-IP would be a spreading scheme because it retransmits packets upon receiving a NACK. In OFDM, if you interleave data across the subcarriers instead of using a contiguous block of subcarriers, you increase the spectrum occupancy, but the total bandwidth (= number of subcarriers x subcarrier bandwidth) is the same. Some people call this spreading. Interleaving involves inserting zeros between data symbols that are operated upon by the IFFT, so this frequency-domain interleaving causes repetition in the time domain, i.e., the output of the IFFT repeats Z times, where Z is the number of zeros you insert between the data symbols.
Thanks. This is helpful.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
