Does rest mass increase in conformal co-ordinates?
In summary, the rest mass of a comoving particle in the FRW metric can be expressed as both E=m and E0=ma, where E is the energy measured by a co-moving observer at the same conformal time, and E0 is the energy measured by a co-moving observer at the present conformal time. This raises the question of which energy is the correct one to use in the FRW metric, and whether the rest mass/energy of a particle changes with the scale factor. This could have implications for the Friedmann equations and Newton's constant. However, rest mass is a coordinate-invariant quantity and is not affected by a choice of coordinates.
jcap
170
Title should be: Does rest mass increase in the FRW metric?
The flat FRW metric can be written in conformal co-ordinates:
$$ds^2=a^2(\eta)(d\eta^2-dx^2-dy^2-dz^2)$$
where ##\eta## is conformal time. Let us assume that ##a(\eta_0)=1## where ##\eta_0## is the present conformal time.
Now the energy of a massive particle ##E## is given by:
$$E=P^\mu V_\mu=mg_{\mu \nu}U^\mu V^\nu$$
where the 4-momentum of the particle is ##P^\mu=mU^\mu## and ##U^\mu##,##V^\nu## are the 4-velocities of the particle and observer respectively.
Let us assume that both the particle and the observer are co-moving at the same conformal time ##\eta##. Therefore the spatial components of their 4-velocities are zero. As the 4-velocities must also be normalised we have:
$$g_{00}U^0 U^0=g_{00}V^0V^0=1$$
Therefore the 4-velocities of the co-moving particle and observer are given by:
$$U^\mu=V^\mu=(\frac{1}{a(\eta)},0,0,0)$$
Thus the energy ##E## of a co-moving particle at time ##\eta##, as measured by a co-moving observer at time ##\eta##, is given by:
$$E = m\ g_{00}\ U^0\ V^0=m\ a^2(\eta) \frac{1}{a(\eta)} \frac{1}{a(\eta)}=m$$
Thus, using this definition of energy, the energy of individual co-moving massive particles is constant. Therefore, for example, we can say that the mass density of cosmological "dust", used in the Friedmann equations, simply goes like ##\rho_m \propto 1/a^3##. This is the conventional viewpoint.
But we can define an energy ##E_0## which is the energy of a comoving particle at time ##\eta## with respect to a comoving observer at the present time ##\eta_0## when ##a(\eta_0)=1##:
$$E_0 = m\ g_{00}\ U^0\ V^0=m\ a^2(\eta) \frac{1}{a(\eta)} \frac{1}{1}=m\ a(\eta)$$
My question is this: Perhaps ##E_0## is the correct energy for a comoving particle with respect to the co-ordinates in which the metric is expressed?
It seems to me that the co-ordinate system, used in the FRW metric above, is the system of co-ordinates that corresponds not to an arbitrary co-moving observer at time ##\eta## but to ourselves who are co-moving observers at the present time ##\eta_0##.
(In standard co-ordinates in which ##g_{00}=1## both ##E## and ##E_0## are the same. So it seems that one could then argue that the difference between ##E## and ##E_0## does not matter. But I think that in arguing this way one is implicitly assuming that the standard FRW co-ordinate system has a timelike Killing vector which it doesn't have. By contrast when one makes the argument in conformal co-ordinates one is implicitly assuming a conformal timelike Killing vector which is in fact a correct assumption.)
Thus we should say that the rest mass/energy of a comoving massive particle at time ##\eta## is given by ##E_0=m\ a(\eta)##.
This would have consequences for Einstein's field equations ##G_{\mu \nu}=8\pi G\ T_{\mu \nu}## when applied to cosmology.
Newton's gravitational constant ##G## in natural units, where ##\hbar=c=1##, is given by:
$$G = \frac{1}{M_{Pl}^2}$$
where ##M_{Pl}## is the Planck mass.
If rest masses are increasing with the scale factor ##a## with respect to the co-ordinate system then the Planck mass should also increase with the factor ##a##. This would imply that Newton's constant actually varies with the scale factor:
$$G \propto \frac{1}{a^2}$$
Thus the Friedmann equations, in either conformal or standard co-ordinates, would have to be modified.
Space news on Phys.org
Rest mass is a coordinate-invariant quantity, given by [itex]m^2 = P_\mu P^\mu[/itex]. No choice of coordinates has any impact on its value.
Related to Does rest mass increase in conformal co-ordinates?
1. Does rest mass increase in conformal coordinates?
According to the theory of general relativity, rest mass is an invariant quantity and should not change in different coordinate systems. However, in conformal coordinates, the perceived mass of an object may appear to increase due to the stretching of spacetime.
2. How does conformal transformation affect rest mass?
Conformal transformations involve rescaling of the metric tensor, which can alter the measurement of distances and time intervals. This can lead to a perceived increase in rest mass in conformal coordinates. However, the actual rest mass of an object remains unchanged.
3. Is rest mass conserved in conformal transformations?
Yes, rest mass is conserved in all coordinate systems, including conformal transformations. This means that the total amount of matter in a closed system remains constant, even though the perceived mass may appear to change in different coordinate systems.
4. Can the increase in rest mass in conformal coordinates be measured?
The increase in rest mass in conformal coordinates is a purely mathematical effect and cannot be measured in physical experiments. The actual mass of an object remains unchanged, and any perceived increase is due to the transformation of the coordinate system.
5. What is the significance of rest mass in conformal coordinates?
The perceived increase in rest mass in conformal coordinates is a consequence of the nature of spacetime and the way it is described by the theory of general relativity. While it does not have any observable physical effects, it highlights the importance of choosing appropriate coordinate systems when studying the behavior of objects in curved spacetime.
