Does Running in the Rain Make You More or Less Wet?
  • Thread starter mordechai9
  • Tags
    Rain
In summary, the amount of water soaking a surface parallel to the constant rain fall is a constant of the path taken, and the amount of water soaking a perpendicular surface is proportional to the time spent. Therefore, running at a constant rate will result in getting less wet than walking. This model assumes that the rain falls straight down, but can be adjusted for different angles. However, if one were to stand still or move at an infinite speed, they would still get wet to some degree.
  • #36
you so did not cite mythbusters as an authority...
  • #37
well they follow the scientific method, I suppose you would have to watch the episode to see if you agree that they covered all the bases with their experiment
  • #38
since when do they follow the scientific method?? Watch the chicken-windshield saga for a rare example of them going back and effectively admitting mistake in their method, conclusion, and high school physics calculations. In real science, you can usually only make weak conclusions, whereas on that "blow stuff up" show everything is conclusively "busted" or "confirmed".
  • #39
Well certainly they have to jazz it up to make people watch the show, They definitely make mistakes as I'm sure any science lab would. I have seen a few shows where they went back and admitted to mistakes and re did the experiment.
I'm not trying to say that they have the definitive answer, but all we can do in this thread is talk math, at least they have a real world experiment to draw conclusions from
  • #40
These are my thoughts.
Just defining terms: For a person moving through the rain they have cross sectional areas A1 and A2 above and in front of them. Rain is coming down with velocity vector [tex]-(v_x,v_y)[/tex] and person is moving with velocity [tex]v\hat{x}[/tex]. Density of the rain is [tex]R[/tex] (drops/m^3), so the current density of the rain is [tex]J = -R(v_x,v_y)[/tex]. S is the distance traveled in the rain. Assume all variables are positive except possibly v_x.
If we transform into the person's moving reference frame then in that frame the rain is coming down with velocity [tex](-v-v_x, -v_y)[/tex] which makes an angle [tex]\alpha = \tan^{-1}\left(\frac{v+v_x}{v_y}\right)[/tex] with the y-axis. So the current density is [tex]J = -R(v+v_x,v_y)[/tex]
Then the flux through each surface is the current density dotted with the area, choosing area normals so that the result is positive.
[tex]F_1 = R A_1 v_y [/tex]
[tex]F_2 = R A_2 |v+v_x|[/tex]
So here we integrate with respect to time. Since these are time independent, we just need to multiply by the time traveled in the rain, S/v.
[tex]W_1 = S R A_1 (v_y / v) [/tex]
[tex]W_2 = S R A_2 |1 + v_x / v|[/tex]
For the simplified case where the rain is coming straight down:
[tex]W_2 = S R A_2 [/tex]
So this says that the amount you get is a simple function of the form (a + b/v) so that the faster you run, the less you get wet. (The result is obviously not valid at v = 0, because we assumed that time spent in the rain is proportionate to 1/v). If the rain were suspended so that v_x = v_y = 0 (time stopped) then W_1 = 0 but W_2 isn't. If you move at infinite velocity, same result. It also says that if the rain is coming down at an angle from behind you (so v_x is negative), then if you run at a [tex]v = |v_x|[/tex] then you will get the least wet. In this case, in your frame of reference, the is rain coming straight down on you. If you run faster then your front hits the rain in front of you and slower and the rain coming down hits your back. This seems intuitive to me.
I don't see how the factor of [tex]\sin(\alpha)[/tex] comes in into your derivation, pixel01. Can you explain that? Have I missed something? It's late so there's probably a mistake in here somewhere.
  • #41
W1 = SRA1(vy/v)
I assume W1 is the amount of rain (wetness) on the top of your head. This relation indicates that your result may possibly be very correct, because as v tends to zero W1 should tend to infinity, as I have pointed out earlier. This is one good example of Physics calculation.
(When I say "possibly correct", no offence is intended. I just mean that I haven't gone into the math thoroughly, which I will do.)
  • #42
It may take some time for me to rewrite it in detail. It was more complicated as I expected at first. It is a nice question isn't it
  • #43
But two years later in 1997, two meteorologists, Thomas C. Peterson and Trevor W. R. Wallace, from the National Climatic Data Center in North Carolina in the USA, published another paper called "Running In The Rain". They had read the "Raindrops Keep Falling On My Head" paper, and found a few mistakes, corrected them, and added in stuff like "rain driven by the wind".
Their equations showed that in a light rain with no wind at all, running will give you only a 16% reduction in wetness, as compared to walking. But if you're running rapidly and leaning forward in a heavy rain that is driven by the wind, you will end up 44% less wet than if you had walked. At this stage, Petersen and Wallace showed that they were fair-dinkum scientists and decided to do the experiment. Luckily they were roughly the same build, so they bought two identical sets of sweat shirts, pants and hats. They also bought two very large plastic bags to wear underneath these clothes, so that any rain which ended up on their clothes would not get soaked into their underclothes. They then measured out a 100 metre track behind their United States National Climatic Data Center office and waited for some rain. Soon, some heavy rain came along - falling at around 18 mm (or 3/4 of an inch) per hour. They made sure that they weighed the clothes both before and after the rain.
Dr. Wallace ran the hundred metres at around 14.4 kph, and his clothes picked up 130 grams of water. Dr. Petersen walked his hundred metres at a much more leisurely 5 kph, but his clothes soaked up 217 grams of water. Running, instead of walking meant that you got less wet by 40%, which was pretty darn close to their predicted 44%.
Their results can be summed up as:
"When caught in the rain without a mac,
walk as fast as the wind at your back,
but when the wind's in your face,
the optimal pace
is fast as your legs can make track".
  • #45
thanks for sharing that mgb, that's pretty interesting.
I personally think that this problem is too complicated to be resolved using algebra, and is much easier to just do the experiment. The problem is that you cannot just treat a person like a rectangle here, and when we run, our shape changes, and even worse, if you also want to consider the direction of the rain, you have to consider the angle of the surfaces that make us up as well - which is a nontrivial function of velocity; and then different people have different proportions and different ways of running...
it's a dissaster.
But I do believe that the faster you run the less wet you get - it makes more intuitive sense.
  • #46
All of the mathematical models offered here and elsewhere are just that: models, and nothing more. Experiment is the arbiter in science. Experiment alone determines which models may be correct, and which cannot be correct. In this case, I'd listen to the MythBusters more than to anyone else, even if their show can be a bit sloppy at times.
- Warren
  • #47
Does anyone have some data on amounts of litres of water per cubic metre in a given speed that is usual?
  • #48
By algebra, did you mean mathematics or just simply algebra? I think you meant mathematics. Do you really believe what you said? I’m not joking. I would sincerely like to know. In my opinion, it is after all an extremely simple problem. We just have to sit down and concentrate on the problem, and do the math, which some people are doing.
And you have a fine intuition.
  • #49
I don't think the faster you run the less wet you would be. If you run too fast you will run into more falling rain. It would effectively change the angle at which the rain is acting against you, exposing a wider surface area for the drops to hit your body. How fast you should run depends on how the rain is falling in comparison to your velocity. Ideally you would want the wind at your back running at exactly the wind speed. Then the rain would be coming at the smallest surface area of your body, straight down.
This is assuming you are looking for the least amount of rain over an unspecified [distance]. If you have a specific destination in mind for shelter, of course, you will be better off getting out of the rain as fast as possible.
  • #50
We are considering the simplest case here. Afterward, we can refine it.
The rain is falling vertically, and the man is moving at a uniform speed in a st line betteen two shelters. I'd be grateful if you could give the basic mathematical formulae.
  • #51
- Warren
The whole of theoretical Physics are models and nothing but models. Some models has been proved to be wrong after a few hundred years. But in that time, the model has guided us towards stupendous achievements or advancements. Experiment was the arbiter in both rise and fall of the model. Without a model to guide us, how shall we understand the essence of a situation?
Your philosophy is commendable, but it’s mostly true for practical problems in engineering, where the number of parameters are high, or for a new theory in the frontiers of Physics, which is yet to be accepted as a law.
If I calculate how many electrons are emitted by a photoelectric material when EM waves of certain frequency are falling on it, nobody would think of questioning it if I mention the right formula. But the answer may depend on so many real factors pertaining to the apparatus and the situation. Then why such a fuss about an extremely well understood concept like the falling of rain?
If the Myth Busters do the experiment wearing yellow windcheaters, what does that say for red mackintoshes, or for somebody running without any clothes? You’ll probably reply that it makes no difference. How do you arrive at that model? Not experimentally, I’m sure.
After somebody constructs a good model, meaning many people are convinced by it, then of course we’ll call in the Myth Busters and verify it, but not before. Let me repeat what somebody I admire said once:
“It is theory which will dictate which experiment to perform.” – A.E.
Sorry for the rather long-ish post. But so much more to say...
  • #52
Hi all, I just thought that I'll remind you what everybody does when they want to cross the street in the rain, or go from the door maybe to the car parked a short distance away. They sprint.
  • #53
Sorry, I'm no mathematician. It would seem to me that in vertical rain the least wet one could get without shelter would be to stand still, rain/time. Any scenario with rain/distance and vertical rain, the faster you can move the better.
maybe (rain x time) / distance?
This would assume a constant rate of vertical rain.
edit - rain would have to be described as a certain volume/time. [liter/square meter/second]
edit - nevermind, that's wrong. If rain falls at some arbitrary rate, say 1Liter per Second, then one would need to know the speed that he could get to shelter. Speed is the distance crossed in a certain period of time D/T. So if your shelter is 20 meters away and you can move 5 meters/second then you will reach it in 4 seconds, enduring 4 liters of water plus a minimal amount for moving against the wind? [assuming a surface area that the rain impacts on of 1 square meter for the dude running.]
Eh, I'll leave this up to you. I passed college calculus 15 years ago and never looked back. It's a shame really.
  • #54
the optimal pace
That's an interesting study.. do you have a citation for their publication? I'd like to read that. Their conclusions sounds like the same I got from the simple model I posted above.
  • #55
mgb_phys said:
Their results can be summed up as: "[..] walk as fast as the wind at your back,
Where was it summed up thus? It seems slightly inexact: you should walk slightly faster because there is a trade-off between preventing rain striking your front (or back) and minimising the time spent with the top of your head exposed, without considering further factors. And I'd like to think their experimental results involved statistics of more than two data points (unlike the mythbusters "method").
  • #56
stewartcs said:
It seems like a read somewhere the answer to this was that you would get the same amount of wetness either way. Don't remember where I read it though.
Intuitively I would think this to be true. Since there is a certain amount of rain that the rather large cross-sectional area of your front side would be running into (as compared to that of your head and shoulders), any benefits of running faster to avoid the amount of time your head (plus any other horizontal areas) is exposed to the rate of rain fall would cancel out (if not cause you to get wetter).
This is nicely covered in marcus' post, which I quote:
marcusl said:
We assume that the density of water in the air is constant (so many grams per liter, say), given whatever velocity the drops have. The frontal surface sweeps out the same volume, hence same mass of water, from A to B regardless of how fast you walk or run, so the only difference is how wet you get on top. As stated above, the faster you go the less wet on top.
PS: mgb - do you have a citation/link for your quote?
