zoltrix
- 70
- 7
hello
Does special relativity entail matter annihilation ?
PAllen said:making QM relativistic required the prediction of antimatter
I think you should listen to your friend.zoltrix said:What do you think ?
First, this isn't a scientific question until you define what you mean by "matter annihilation". What particular physical process is entailed by SR and the above equation?zoltrix said:I have been discussing this topic with a friend
My friend claimed that the relativistic Energy equation :
E^2 = (pc)^2 + (mc^2)^2
entails matter annihilation thanks to the term m*c^2
I disagreed
The relativistic Energy, in my opinion, is somehow equivalent to the Newtonian mass
the inertia of a body in motion being me = E/c^2
m*c^2 must be understood as the contribution of the matter to the inertia of the body while pc is the contribution of the movement
What do you think ?
I think that it would have been helpful for you to include this in the beginning.zoltrix said:What do you think ?
zoltrix said:whole body can be changed to energy
PeroK said:There is nothing in the theory of electromagnetism that forbids these.
zoltrix said:Matter annihilation means that the whole body can be changed to energy.
The theory works just as well with a magnetic charge and magnetic current. Although, I guess it depends whether you consider that equation forbids magnetic monopoles or is a working assumption that they don't exist.PeterDonis said:Actually, there is: the Maxwell Equation ##\nabla \cdot \vec{B} = 0##.
PeroK said:The theory works just as well with a magnetic charge and magnetic current.
PeroK said:I guess it depends whether you consider that equation forbids magnetic monopoles or is a working assumption that they don't exist.
Dale said:For your position, ##E/c^2## is not the inertia of a body. The non-specific term “inertia” can either refer specifically to the momentum or to the invariant mass. In neither case does it refer to the energy. The concept of relativistic mass has been discarded for several decades now.
I've never found it in any modern textbook. We sometimes get homework problems from students working from A.P. French's book, which dates from 1965 and uses relativistic mass. So @Dale is right, it's been gone from undergraduate textbooks for decades.zoltrix said:I don't think the concept of relativistic mass has been discarded,
zoltrix said:I don't think that the concept of relativistic mass has been discarded
zoltrix said:maybe the term relativistic mass is out of fashion
It has no physical meaning, which is one of its problems. Any velocity you assign to a particle is frame-dependent, hence any relativistic mass is frame dependent. The particle itself has no idea what its relativistic mass is supposed to be - the particle doesn't undergo any physical change just because you choose to observe it from a different reference frame.zoltrix said:maybe the term relativistic mass is out of fashion but its physical meaning is still important in my opinion
You'll be telling us next that if you go fast enough, you turn into a black hole!zoltrix said:Mass and matter ( or bodies or objects ) are no longer related items in special relativity as they were in Newtonian physics
zoltrix said:but physical concepts remain unchanged whatever words you want to use
PeroK said:You'll be telling us next that if you go fast enough, you'll turn into a black hole!
You think incorrectly. Even as early as Einstein the concept of relativistic mass was not in favor: https://aapt.scitation.org/doi/10.1119/1.3204111 and Lev Okun expressed the "majority opinion" well throughout his career: http://www.stat.physik.uni-potsdam.de/~pikovsky/teaching/stud_seminar/einstein_okun.pdf and http://www.itep.ru/science/doctors/okun/publishing_eng/em_3.pdfzoltrix said:I don't think that the concept of relativistic mass has been discarded,
This is false.zoltrix said:The fundamental equation of the dynamics F = d(mt)/dt still holds if m = E/c^2
Whereas E is the total energy
This is also false.zoltrix said:Einstein demostrated the equivalence inertial and gravitational mass via the common factor E /c^2 while for Newton it was just an hyphotesis
zoltrix said:Does special relativity entail matter annihilation ?
Special relativity is a theory developed by Albert Einstein in 1905 that describes the relationship between space and time. It is based on the principle that the laws of physics are the same for all observers in uniform motion, and that the speed of light in a vacuum is constant for all observers.
No, special relativity does not entail matter annihilation. The theory states that matter and energy are interchangeable, but it does not predict or require the complete annihilation of matter.
Yes, according to the famous equation E=mc^2, matter can be converted into pure energy. This means that a small amount of matter can produce a large amount of energy, as seen in nuclear reactions.
Special relativity explains time dilation as the slowing down of time for an object in motion relative to an observer. This is due to the fact that the speed of light is constant, and as an object's velocity approaches the speed of light, time appears to slow down for that object.
Yes, special relativity is still a valid and widely accepted theory today. It has been extensively tested and has been found to accurately describe the behavior of objects at high speeds and in strong gravitational fields. It is also an essential component of modern physics and has many practical applications in fields such as GPS technology and particle accelerators.
