Does speed of light depend on the wavelength or frequency of it?
In summary, the speed of light is a constant in vacuum and does not depend on the wavelength or frequency of it. This means that for a light wave with a certain frequency, the wavelength is fixed at a specific value. In a medium, such as glass or water, the speed of light may vary with frequency, but this still means that the wavelength is determined by the chosen frequency and medium.
nineteen
68
I heard that the speed of light doesn't depend on the wavelength or frequency of it, how does it happen? I don't understand it because the ultimate equation is c = fλ (where c is the speed of velocity of light, f is the frequency and λ is the wavelength of it...).
Science news on Phys.org
As the frequency increases the wavelength decreases, so their product doesn’t change.
Likes nineteen and davenn
Where did you hear this? It's wrong in general.
The speed of light is a constant in vacuum. There isn't really an answer to why that is at a B level - it's just the way the world works. In terms of your ##c=f\lambda##, it means that a light wave of frequency ##f## must have wavelength ##c/f##. You don't get to choose both ##f## and ##\lambda##.
For light in a medium, such as glass or water, the speed of light does vary with frequency. But again, this means that once you've chosen a frequency and a medium the wavelength is fixed, because you are not free to choose the speed and the frequency independently.
Likes nineteen, vanhees71 and davenn
Related to Does speed of light depend on the wavelength or frequency of it?
1. Does the speed of light change depending on its wavelength or frequency?
No, the speed of light is a constant value in a vacuum and does not change depending on its wavelength or frequency. This is known as the speed of light in a vacuum, denoted by the letter 'c' and has a value of approximately 299,792,458 meters per second.
2. Why do we measure the speed of light in a vacuum?
The speed of light is measured in a vacuum because it is the only medium in which light can travel at its maximum speed. In other mediums, such as air or water, the speed of light is slower due to interactions with particles in the medium.
3. How does the speed of light relate to its wavelength and frequency?
The speed of light is directly proportional to its wavelength and inversely proportional to its frequency. This means that as the wavelength of light increases, its frequency decreases and vice versa. However, the speed of light remains constant regardless of these changes.
4. Can the speed of light be exceeded?
According to Einstein's theory of relativity, the speed of light is the maximum speed at which any object can travel. This means that it is not possible for anything to exceed the speed of light, as it would violate the laws of physics.
5. Does the speed of light change in different mediums?
Yes, the speed of light changes in different mediums due to interactions with particles in the medium. For example, light travels slower in water than in air. This is because the particles in water are closer together, causing more interactions and slowing down the speed of light.
10K
