- #36
- 10,349
- 1,525
russ_watters said:...which is exactly how GPS does it: they arbitrarily decided on a ground station to synchronze to.
GPS time (and TAI time) are good examples of the sort of trouble one can get into with clock synchronization. One can more or less consider that the "reference clock" for GPS time time (also, for TAI time) is a clock on the north or south pole. This clock isn't moving with respect to the center of the Earth (though it keeps slightly different time because of gravitational time dilation).
Momentum will NOT BE CONSERVED in a system of physics that uses GPS clock synchronizations to measure velocities when one uses the simple formula
p = mv
One can use the simple relation p=mv only if one has an Einsteinian clock synchronization. There are many options, but because most peole find it much easier to keep p=mv than to muck around with anisotrpic velocity-momentum tensors (Using anisotropic velocity-momentum tesors means that. one re-adjusts the momentum velocity relationships so that an object moving east-west with "velocity" v (said velocity being measured with GPS clock synch) has a different ratio of momentum/mass than an object moving west-east with the same "velocity").
The usual option is simply not to use GPS clock synchronizations to measure velocities, much as one does not include time zones when one is measuring velocities. If an object is moving slow enough, the difference in GPS/ einsteinian synchronization methods may not be critical to a particular experiment, but it will become more and more important as the velocity increases.
