Jaime Rudas
- 313
- 133
- TL;DR
- Would the distance between Earth and Alpha Centauri be much less than 4.3 light years if measured along a path through the Alcubierre warp bubble?
In this post, Peter Donis says:
I understand that the Alcubierre bubble, by contracting space, shortens the distances forward, however, this shortening is permanently compensated by an expansion of the space behind, so the distance between Earth and Alpha Centauri would remain at all times invariant when measured along a path going through the warp bubble.
Wouldn't it be like that?
My question is whether or not the distance between Earth and Alpha Centauri would actually be much less than 4.3 light years if measured along a path that passes through the Alcubierre warp bubble.If an Alcubierre warp drive could actually be built (which, since it requires exotic matter, it probably can't), it would allow you to, for example, travel to Alpha Centauri in much less than 4.3 years, even as seen by observers on Earth or Alpha Centauri. But the reason for this would be that the warp drive would drastically change the geometry of spacetime in between Earth and Alpha Centauri, such that the distance between them would be much less than 4.3 light years if you measured it along a path going through the warp bubble. So a light beam that passed through the warp bubble would get from Earth to Alpha Centauri even faster than the ship itself would.
