Does the angle of a ramp with the ground affect velocity?
In summary, a ramp with a smaller angle will have a shorter time it will take to reach the bottom, but the velocity will be the same.
Mr Davis 97
1,462
44
I have a question. If a put a marble at the top of a ramp, will the angle that ramp makes with the horizontal affect the velocity of the marble when it arrives at the bottom of the ramp? I am suspecting no, since the gravitation potential energy does not change as we change the angle of the ramp, so when the marble arrives at the bottom, all of that potential energy must be kinetic and thus the velocity must be the same. I think that changing the angle will only affect how long it takes to reach the bottom, since all we're doing ins modifying the parallel force component. Is all of this correct?
Do you understand that velocity is a vector?
do you see your own contradiction there between your 2 statements ?
if it takes less time on a steeper ramp, then the velocity must be ... ? you fill in the blank
Granted that the height is the same, then you are right. This will mean that you start from the same height but you can go down either by a steeper and shorter ramp or by another, less steep but longer. And if there is no friction, of course. In the first case the time on the ramp will be shorter but the acceleration will be higher.
The velocity at the base of the ramps will be the same as for a free fall from the same height. The ramp just "extends" the time necessary to reach that speed.
On the other hand, if you have a ramp with variable angle, like the ones with a hinge at the bottom, then changing the angle will change the initial height and the above will not apply.
Likes Mr Davis 97 and Vatsal Sanjay
Why am I the only one here who believes velocity is a vector ?
Likes Vatsal Sanjay
No, you are not the only one. Mr Davis 97 must have corrected it to speed by now. I think he meant speed.
As per the answer to the question (modified); speed at the bottom will not be dependent on the angle of the ramp, provided that
  • There is no friction.
  • The height of the topmost point on the ramp from the ground is same. As Mr Nasu mentioned if you have a ramp with hinge at the bottom, then the length of the ramp will be constant and height (## lsin(\theta) ## ) variable.
It is a simple energy conservation thing, $$ mgh = \frac{1}{2} mv^2 $$
Time will change man. Assumed ideal case, ## t = (\frac{2h/sin(\theta)}{gsin(\theta)})^\frac{1}{2} ## The length of the ramp is also variable in this case. You cannot simply relate the speed's magnitude with time.
Likes Mr Davis 97
I see what you mean (and share your belief :smile: ) but it's too late to change the word in my post above.
Of course I mean that the speed at the base is the same.
Likes Vatsal Sanjay
Nice to know it. In Spanish we don't have this subtle difference between speed and directional speed (velocity) :).
Huh. I don't see it as a "subtle" difference at all. You can't solve vector problems with a scalar and most actual mechanics problems are vector problems. How do your engineers build bridges, for example ?
I don't think that's a requirement... :smile:
What if the angle is smaller than the friction angle? What will be the speed "at the base" then?
What's a friction angle?
Putting my pedant cap on... If the transition between ramp and ground is sharp then although the object's speed at the bottom may be well defined, its velocity at the bottom will not be.
The angle for which the friction force equals the tangential component of the weight.
The body is in equilibrium on the incline at this angle.
http://www.thefreedictionary.com/angle+of+friction
But this is just a name. It was a short way to say that if the angle is too small and there is friction, the body won't move down the incline. The friction is just too strong.
And this was just a way to show that with friction, the angle matters.
Why do you think so? If I am not wrong, the work done by friction (or say the energy dissipated by friction); assumed kinetic will depend on the horizontal distance between the starting and ending points. Now if you wish to change ramp angle without changing height, you will need to change the base length of prism. is not it true? :P
The OP said it was a marble, not a block...
What energy dissipated by friction? It's a marble rolling down a ramp. And the OP did stipulate that the marble starts at the same height for the different experiments with different angles for the ramps, so the PE is the same before the marble starts to roll.
Yes, you are right. I did not pay attention.
For a marble I think it's harder to decide if friction matters or not. How do you see it when you say that friction does not matter?
Is the ball rolling without friction? Or just sliding? If it's just sliding, won't it start to roll for some friction?
My bad. I must have noticed. :(
Ok! I think I need to reframe my statement for marble case. There won't be any problem if the ramp is frictionless. The marble will simply slide down.
However, if there is friction. The is going to be a specific value of friction for which the ball will be in state of pure rolling (I can go into the mathematics of it, but I don't think there is a need for it), for which the friction will be static and not kinetic and, therefore, no loss of energy (rotational plus translational kinetic included of course!). But, there is another limit to the static friction that we will need to check as well (just for being sure).
Log story short, I think the friction might be kinetic and the rolling might not be "always" pure rolling. Is that wrong?
"celeridad" and "velocidad" ?
To most non technical English speakers "Speed" and "Velocity" mean the same thing. It's only in the context of physics that they are considered different. It is an important difference.
Related to Does the angle of a ramp with the ground affect velocity?
1. How does the angle of a ramp affect the velocity of an object?
The angle of a ramp does affect the velocity of an object. The steeper the ramp, the higher the velocity will be. This is because the steeper angle allows the object to gain more potential energy, which is converted into kinetic energy as it moves down the ramp.
2. Is there an ideal angle for a ramp to achieve maximum velocity?
Yes, there is an ideal angle for a ramp to achieve maximum velocity. This angle is known as the "critical angle" and is dependent on several factors such as the weight and shape of the object, the surface of the ramp, and the force of gravity. It is typically between 30-45 degrees.
3. Does the length of the ramp also affect the velocity of an object?
Yes, the length of the ramp can also affect the velocity of an object. A longer ramp will allow the object to gain more speed and momentum as it travels down, resulting in a higher velocity. However, the angle of the ramp is still the main determining factor for the velocity.
4. Can the angle of a ramp affect the velocity of objects of different masses equally?
No, the angle of a ramp will not affect the velocity of objects of different masses equally. Heavier objects will have a higher velocity than lighter objects on the same ramp, as they have more potential energy to convert into kinetic energy. This is why it is important to consider the weight of the object when determining the angle of the ramp for maximum velocity.
5. How does friction play a role in the relationship between the angle of a ramp and velocity?
Friction can affect the velocity of an object on a ramp, regardless of the angle. As the object moves down the ramp, it will experience friction from the surface, which will decrease its velocity. Therefore, a steeper angle with less surface contact can result in a higher velocity due to less friction. However, too steep of an angle can also result in the object losing control and not reaching its maximum velocity.
  • Mechanics
