Does the angle of the slope matter in these cases? Why/not?
In summary, on a frictionless slope, the angle of the slope does not affect the height at which the compressed spring will be able to push an air cart up the slope.
grooveactiva
This is not a direct homework problem. Rather, I modified several that I saw that had different slopes but with the same initial velocity, and the same height answer: An icy, frictionless road slopes upward with angle Θ ° above the horizontal. A snowboarder of mass m approaching the road with a speed of v [m/s]. How high in the vertical direction does the snowboarder travel up the road before stopping? Assume no friction.
½mv2 = mgh, where h is the vertical height that we want.
The masses cancel, so: ½v2 = gh.
h = v2/(2g)
Or do we use v= v0sinΘ because the sine of the angle is the opposite of that angle, which corresponds to height:
h = (v0 sin Θ)2/(2g)
In other words, doesn't gravity affect how high up in the vertical direction that the snowboarder would travel?
I have seen similar problems with differing angles, 22°, 25°, 33° with the same velocity. All have same answer in terms of height. But wouldn't it take more energy to go up a steeper slope, even with no friction? If this problem were done with Newtonian kinematics, wouldn't the angle affect the result of how high in the vertical direction (and along the slope itself) the snowboarder would travel?
Three snowboarders, of identical mass m and identical velocity v, will have zero potential energy (max height) when they attain zero velocity. Is this true on a friction-less slope of any angle? Hmm.
So. Why does the angle matter?
Can you show mathematically how the angle of the slope changes the height required to achieve zero potential energy? I say "no". Remember
##M_1=M_2=M_3##
Consider applying the 'potential energy' concept to your question.
A steeper slope means you lose speed faster but also gain height faster. In the end, without friction, all KE is converted to GPE, so the height is the same.
Thanks, but I have another question: When doing problems like this, how do I know when I can ignore the angle? I am working out another problem that says: A compressed spring with spring constant k is pushing an air cart of mass m up an air track of length L that is sloped at Θ° above the horizontal. Before moving up the air track, the air cart becomes disenaged with the spring. To what distance x was the spring originally compressed?
Conservation of energy: All PE of compressed spring becomes kinetic energy to move air cart up slope. Distance along slope depends on angle Θ?
½kx2 = mgLsinΘ, ⇒ d = √(2mgLsinΘ/k)
or just
½kx2 = mgL, ⇒ d = √(2mgL/k)
or just
The difference here is that you are given the distance along the slope. To figure out the energy required you need to find the height, and to get that from the distance you need the angle.
But in general you don’t need to determine in advance whether you need the angle. If you don’t then it will cancel out.
Related to Does the angle of the slope matter in these cases? Why/not?
1. Does the angle of the slope affect the speed of an object rolling down?
The angle of the slope can affect the speed of an object rolling down. This is because the steeper the slope, the greater the force of gravity acting on the object, causing it to accelerate faster. However, other factors such as friction and air resistance also play a role in determining the speed of the object.
2. How does the angle of the slope impact the force required to push an object up?
The angle of the slope affects the force required to push an object up. The steeper the slope, the greater the force needed to overcome the force of gravity pulling the object down. This is because the component of the force of gravity acting parallel to the slope increases with a steeper angle, making it harder to push the object up.
3. Will changing the angle of the slope affect the distance an object travels?
Yes, changing the angle of the slope can affect the distance an object travels. A steeper slope will result in a shorter distance traveled, as the object will accelerate faster and reach the bottom of the slope in a shorter amount of time. A shallower slope will result in a longer distance traveled, as the object will accelerate slower and take more time to reach the bottom of the slope.
4. How does the angle of the slope affect the work done on an object?
The angle of the slope does not directly affect the work done on an object. Work is defined as the product of force and distance, and changing the angle of the slope does not change the force applied or the distance traveled. However, the force required to push an object up a steeper slope will result in more work being done compared to pushing the same object up a shallower slope.
5. Is there an optimal angle for a slope in terms of efficiency?
The optimal angle for a slope depends on the specific scenario and what is considered efficient. For example, a steep slope may allow an object to reach its destination faster, but it may require more energy to push the object up. A shallower slope may take longer for the object to reach its destination, but it may require less energy to push the object up. Ultimately, the optimal angle will vary and should be chosen based on the specific goals and constraints of the situation.
12K
