Does the average person run on 96.85 watts?
In summary, a person eating a 2,000 calorie diet is consuming 2,000,000 calories or 8,368,000 joules. This equates to 96.85 watts, which is the average amount of energy a person runs on. However, the human body is not 100% efficient, with a maximum efficiency of 20%. This is due to the body's primary use of energy to maintain temperature. Even so, the efficiency of muscle is higher than 20%, meaning that even while exercising, the body still generates a significant amount of heat.
wasteofo2
478
I tried to figure out how many watts a person runs on who eats a 2,000 calorie diet.
First, dietary calories are really kilocalories, so someone eating a 2,000 calorie diet is really eating 2,000,000 calories.
1 calorie is 4.184 joules, so multiply 2 million by 4.184 and you get 8,368,000 joules.
Divide that by seconds in a day, 86,400, and you get 96.85.
Is that right? Does the average person run on 96.85 watts?
Well people aren't 100% efficient... but yah that's about right.
Pretty amazing to think that we use as much energy as a lightbulb or two... but a lightbulb is nothing to what your average house runs on. It's like, 10-40 people would have to be eating food and working 24/7 to produce the energy a household needs. Our house uses like 2-4kwh/h... wait... how does that work. 2 kilowatt-hours/hour... yah that makes sense...
Yeah, that doesn't include what you pee and poop out, but you're in the right order of magnitude. 70w is typical for the HVAC industry, barring more specific info about what they are doing (ie, a weight room).
It is still worse. The maximum human efficiency is 20% during bicycling and generally as low as 5%.
Efficiency in what terms? In terms of motive energy?
Keep in mind the body's primary use of energy is to maintain temperature. Unlike an internal combustion engine, the heat is not simply waste -- it's essential to the survival of proteins and enzymes necessary for human life.
- Warren
Besides - in the sense we're talking about (generating heat), humans are near 100% efficient. The energy that doesn't go toward building new cells (thus, absorbed as chemical energy) all becomes heat.
I think there's another way: use Stefan-Boltzmann law:
[tex]q=\sigma(T_{body}^4-T_{room}^4)A_{body}[/tex]
That's a lose by radiation (which is not negligible at all under standard room conditions). Try to plug in numbers, I remember it works.
If you are running up a flight of stairs or something, you could be using more than 1000 watts, if you are sprinting that is...
Yeah, and go ahead and figure out how many flights you have to run to use up just one can of Pepsi! (I was astonished anyway!)
-Dan
I can't understand why anyone would want to run up stairs to get exercise. I can't even think of a less enjoyable place to exercise than a dank, confined indoor stairwell. I can burn off a can of Pepsi in 3 miles on my bike -- three very enjoyable miles surrounded by nature and fresh air -- in nine minutes.
Big deal.
- Warren
For running 3 miles in 9 minutes the path must be facing downwards all the time. When I was in Spain, 17-18 years old (my best moment of shape), I used to run 10 km in 15 minutes in a open-air closed road circuit with my road bicycle. :-p
What? I'm not talking about running, I'm talking about bicycling. And 3 miles in 9 minutes is 20 miles an hour, which is my normal cruising speed on flats. My fastest recorded flat sprint is about 32 mph for about five minutes.
- Warren
chroot said:
I can't understand why anyone would want to run up stairs to get exercise. ... I can burn off a can of Pepsi in 3 miles on my bike -- three very enjoyable miles surrounded by nature and fresh air -- in nine minutes.
- Warren
Burning calories surrounded by nature sounds very appealing! Yet I do understand why folks want to run up stairs.. It builds up some different muscles, especially those that come in handy for hiking mountain trails and surface swim with scuba gear.. It is also an intense workout to build stamina. Though I would save it for the colder months or bad weather. We run hills in fresh air, during nice weather for the same effect. :-p
Big deal.
- Warren
Clearly, you did not wrestle in high school. "Enjoyment" has nothing to do with why you run a stairwell (though usually "punishment" did...).
- Warren
That is what I meant. If we difine the efficiency as useful energy/energy input, the human actions have a maximum efficiency of 20%. The metabolic activities consume much less energy, for example, human heart consumes about 5 Watt/min.
Including human body, inefficiency of any machine finally leads to heat whether it is required or not. If all the heat generated by the body is required to maintain the temperature, there won't be any perspiration, perhaps.
I don't know what a Watt per minute is.
Besides, like I said, the efficiency of muscle is much higher than 20%, even though the entire human body has to keep itself warm to function, and thus uses a lot of energy to maintain temperature.
Except when you're burning a thousand calories an hour on a bike. Even if your muscles are 90% efficient, you're still dissipating as much heat from muscle contractions as you do while sleeping.
- Warren
ah.. that is a blunder. Please read it as Joules/min. For other things, I should better refrain myself from commenting.
Thanks for your views.
Related to Does the average person run on 96.85 watts?
1. How is the average person's power output measured in watts?
The average person's power output is typically measured using a device called a power meter, which measures the amount of energy expended by the body in watts.
2. Is 96.85 watts considered a high or low power output for the average person?
96.85 watts is considered to be a relatively low power output for the average person. Elite athletes may have a much higher power output, ranging from 400-500 watts or more.
3. Can the average person improve their power output?
Yes, the average person can improve their power output through regular exercise and training. By increasing muscle strength and endurance, the body is able to produce more power.
4. How does power output affect athletic performance?
Power output is a key factor in athletic performance, as it directly relates to an individual's speed and strength. The higher the power output, the faster and stronger an athlete is able to perform.
5. What factors can affect an individual's power output?
There are several factors that can affect an individual's power output, including genetics, age, gender, and overall fitness level. Additionally, factors such as nutrition, hydration, and environmental conditions can also play a role in an individual's power output.
31K
19K
  • Science Fiction and Fantasy Media
