Does the book have an error in the addition of these two vectors?
The discussion centers on a potential error in a textbook regarding the addition of vectors. The calculated unit vector from the given vectors results in components of approximately 0.923 for x, 0.355 for y, and 0.142 for z. The textbook, however, lists the z-component as 0.4, which raises questions about its accuracy. Participants suggest that this discrepancy may stem from a typographical error, particularly since 0.4 has only one significant figure compared to the others. The consensus leans towards the calculated values being correct, indicating a possible mistake in the book.
CaliforniaRoll88
Given the vectors ##\vec M = -10\hat a_x+4\hat a_y-8\hat a_z## and ##\vec N = 8\hat a_x+7\hat a_y-2\hat a_z## , find: (a) a unit vector in the direction of ##-\vec M - 2\vec N##
##\hat a_B=\frac {\vec B} {\sqrt {B^2_x+B^2_y +B^2_z}}##
(a)
$$\vec A = -\vec M+2\vec N=26\hat a_x+10\hat a_y+4\hat a_z$$
Unit Vector Formula
$$\hat a_A=\frac{26\hat a_x+10\hat a_y+4\hat a_z}{\sqrt {26^2+10^2+4^2}}$$
$$0.923\hat a_x+0.355\hat a_y+0.142\hat a_z$$
The book gives ##0.92\hat a_x+0.36\hat a_y+0.4\hat a_z##
Not sure how the book get 0.4 for the z-component. Maybe it's an error.
CaliforniaRoll88 said:
Homework Statement: Given the vectors ##\vec M = -10\hat a_x+4\hat a_y-8\hat a_z## and ##\vec N = 8\hat a_x+7\hat a_y-2\hat a_z## , find: (a) a unit vector in the direction of ##-\vec M - 2\vec N##
I assume that the latter is correct (plus sign, not minus, in front of ##2N##).
Considering that the answer is given with two significant figures and that ##0.4## only has one, this looks like a typo (missing 1).
Likes CaliforniaRoll88 and PeroK
Much appreciated.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
