Does the charge of a capacitor change during immersion?
In summary, when a capacitor with stored charge is immersed in a liquid such as distilled water, assuming no leakage current, the charge on the plates will remain constant. However, the capacitance and voltage may change depending on the properties of the liquid. This is because while the charge is conserved, the capacitance and voltage can be affected by the dielectric constant (ε) of the liquid. If there is a change in capacitance and voltage, the energy stored in the capacitor may also change.
halo168
If given a capacitor with stored charge, would its charge remain constant before and after it is immersed in a liquid (i.e. distilled water)? Why?
I know that before immersion, the capacitance would be = (ɛAV/d), but would that be the same if immerged in distilled water?
If you are asking theoretically without regard to practical realities, then the charge can't change unless there is a current in or out. The capacitance can change, but not the charge if there is no place for the charge to go.
In real life, there are nonzero leakage currents that negate that answer.
It looks like you are combining two equations...
Q=CV
C=εA/d
When you immerse the capacitor that has nothing between the plates in distilled water, assuming no leakage current, the charge on the plates will not change. So what happens in the first equation? ε changes (by how much?) in the 2nd equation, so what does that do to the first equation?
And since the energy stored in the capacitor is E=CV^2/2, is there a change in the energy stored in the system? If so, where did the extra energy come from or go to? :smile:
I think what you are referring to is the capacitance changing. A very important rule regarding capacitors is that charge is always conserved (unless actively changed by a current or voltage). While the charge is always conserved, capacitance can change and voltage as well. The capacitance and voltage might go up or down when immersed, but never the charge.
Related to Does the charge of a capacitor change during immersion?
1. What is a capacitor?
A capacitor is a device that stores electrical energy by accumulating an electric charge on its plates. It consists of two conductive plates separated by an insulating material known as a dielectric.
2. Does the charge of a capacitor change during immersion?
Yes, the charge of a capacitor can change during immersion. When a capacitor is immersed in a liquid, the dielectric material between the plates may absorb some of the liquid, which can change the capacitance and therefore the charge of the capacitor.
3. How does the charge change during immersion?
The charge of a capacitor changes during immersion due to the change in the dielectric constant of the material between the plates. If the dielectric constant of the liquid is higher than that of the previous material, the capacitance will increase and the charge will increase as well. If the dielectric constant of the liquid is lower, the capacitance and charge will decrease.
4. Are there any other factors that can affect the charge of a capacitor during immersion?
Yes, there are other factors that can affect the charge of a capacitor during immersion. These include the temperature of the liquid, the surface area of the plates, and the distance between the plates. These factors can also impact the dielectric constant and therefore the charge of the capacitor.
5. Is the change in charge during immersion permanent?
No, the change in charge during immersion is not permanent. If the capacitor is removed from the liquid and allowed to dry, the dielectric material will return to its previous state and the charge will return to its original value. However, if the immersion causes damage to the capacitor, the change in charge may be permanent.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
