Does the derivative of a P(V) eqn give the eqn for change in Pressure?
Taking the derivative of a P(V) equation can provide insights into the rate of change of pressure with respect to volume. The interpretation of this derivative depends on the variable with respect to which differentiation is performed. In general, derivatives represent rates of change, but their meaning varies based on the context of the differentiation. The discussion emphasizes that understanding the relationship between pressure and volume is crucial for interpreting the results correctly. Ultimately, the derivative can indicate how pressure changes as volume changes.
JoeyBob
N/A
N/A
I know the integral of a P(V) eqn gives an eqn for work.
I was wondering if taking the derivative of a P(V) eqn gives an eqn for change in pressure?
JoeyBob said:
Homework Statement:: N/A
Relevant Equations:: N/A
What is your definition of an "equation for change in pressure?"
Gives rate of change.
For instance, if you take the derivative of velocity, you get acceleration, which is the rate of change of velocity.
No, the derivative of velocity with respect to time is acceleration. What you differentiate with respect to is important. For example, there are situations where velocity is given as a function of position. The derivative of such a velocity function is not acceleration.
Derivatives are rates of change with respect to the differentiation variable, but depending on what the differentiation variable is, the interpretation may vary.
Likes Steve4Physics
So it would be rate of change with respect to volume?
