Does the direction of current inverse in ac?
In summary: Suppose you have two wires, one is live and one is neutral. If you touch the live wire and nothing else, you will get zapped because you are putting current through the neutral wire. If you touch the live wire and the neutral wire, you will not get zapped because the current will flow through the neutral wire to the ground.
ChrisToffer
I'm learning AC and theory says that the polarity of AC inverses.. even the name says 'alternating current'.. now what about the live and neutral? does the current goes from neutral to live and and vice versa?
Some people says that only the phase inverses, but the current is always from live to neutral, and direction of current never inverses..
Is all these true?? can someone help me understand all these?? and why do transformers has only one color for both wires? like, transmission transformers also are pretty much same, i mean same principle.. I'm so confused..
Alternating current doesn't necessarily mean it is centered at 0. You could have an alternating signal with a DC offset so that it always stays positive.
However I think you are talking about regular mains voltage centered on zero. And yes, it does alternate going forward to going backward. It is rather easy to think about. If you had a battery run circuit and switch the terminals every second, the current would going 'backwards' every other second right?
Likes 1 person
Yes, the voltage AND the current reverses at line frequency (60Hz in US). I have no idea what the phrase "only the phase inverses" means to "some people". Phase relative to what?
Additionally, the relative phase of the voltage and current can be non-zero, giving rise to "power factor". That is, you don't always get maximum current at maximum voltage. Wikipedia is a fine place to read about power factor.
also, something that obvious that helped me when I was first learning...
Electricity is like heat or water. It will always flow from High to Low. If at some point in time, neutral is 0V and the line is -5V, then the neutral is High and it has to flow from neutral to the line.
Likes 1 person
if the direction has reversed, it means that the live became neutral?
The neutral wire is always a live wire (a current carrying conductor). It's said to be neutral because it's normally attached to ground at some point in a grounded power system and/or is a reference point for other wires IRT voltage.
Neutral is called such due to the way it is attached to the transformer or group of transformers.
i know that the polarity will inverse periodically, phase and current directions would change.. yes but the live is the hot wire, current will flow to neutral.. but when the polarity inverses, the direction of current has changed, that is from neutral to live.. but how is it possible that current now goes from neutral to live??
if you touch the 'live' wire and nothing else, will you get zapped? no.
if you touch the 'live' wire and the 'neutral' wire, will you get zapped? yes.
How can the 'live' wire be live if you touch it and nothing happens? Because current needs a return path.
the neutral wire carries the return current. Current has to return in order to form a circuit. But the direction we say its going in is fairly arbitrary as long we stay consistent with our notation. The electrons don't care what the wire is labeled. They flow through them regardless. If voltage is applied one way, they go that way. If voltage is reversed, the electrons turn around.
Its called neutral because it is tied to ground. If you touch the ground and the neutral wire, nothing happens because there is no voltage difference. But it still carries current when it is connected to a circuit.
Related to Does the direction of current inverse in ac?
1. What is alternating current (AC) and how does it differ from direct current (DC)?
Alternating current (AC) is a type of electrical current that changes direction periodically. This is opposed to direct current (DC), which flows in only one direction. AC is used to transmit electricity over long distances and is what powers most household appliances.
2. How does the direction of current change in AC?
In AC, the direction of current changes because the voltage supplying the current changes from positive to negative and back again in a cyclical pattern. This creates a flow of electricity that alternates in direction.
3. Is the direction of current always changing in AC?
Yes, the direction of current is constantly changing in AC. This is what allows electricity to be transmitted over long distances without losing too much energy. The constant change in direction also allows for the use of transformers to step up or step down the voltage for different applications.
4. How does the direction of current affect the function of electrical devices?
The direction of current in AC does not affect the function of most electrical devices, as they are designed to work with alternating current. However, some devices, such as motors and generators, require the current to flow in a specific direction in order to function properly. These devices have mechanisms in place to ensure the current flows in the correct direction.
5. Can the direction of current be changed in AC circuits?
Yes, the direction of current can be changed in AC circuits by using devices called diodes. These devices allow current to flow in one direction only, effectively changing the direction of the current in the circuit. This is often used in rectifiers to convert AC to DC for certain applications.
  • Electrical Engineering
13K
