Does the effective action make sense in Quantum Mechanics?
In summary: If QFT was used as a theory of fields in the sense in which QM is used as a theory of particles, there would be no much use of effective action in QFT just as there is no much use of effective action in QM. But in practice, QFT is usually not used as a theory of fields. Instead, QFT is usually used as a theory of particles, as a tool to compute the particle scattering amplitude. But as theories of particles, QM and QFT are quite different theories. In particular, particles are fundamental in QM but emergent in QFT. That's, I think, is a deeper reason why effective action is useful in QFT but not so
jordi
197
I think the effective action should make sense also in Quantum Mechanics, not only in QFT. But I have never seen described in a QM book as such. Could there be a QM book that uses effective actions? Or maybe in QM effective actions are called another name?
I think effective actions in QM could be interesting, since there are several QM models which are solved exactly, so I assume the effective action could be calculated explicitly.
But now that I think about it, in QFT the effective action gives the correlation functions calculating only "tree level". But in QM, there are no loops (which are relativistic) ...
You can have loops in QM. Just expand the path integral in terms of the coupling and evaluate against the free theory measure as you do in QFT. It's really no different in that sense.
The only real difference is that the Feynman diagrams converge without renormalization. This is due to the fact that the QM path integral measures have ##C^{0}## functions as their support rather than distributions.
Likes vanhees71, dextercioby, Demystifier and 1 other person
Sure, you are right.
As a consequence, an effective action for QM could make sense, right?
Why are QM books not using this language, which is closer to QFT? (at least, the QM books I have read).
If QFT was used as a theory of fields in the sense in which QM is used as a theory of particles, there would be no much use of effective action in QFT just as there is no much use of effective action in QM. But in practice, QFT is usually not used as a theory of fields. Instead, QFT is usually used as a theory of particles, as a tool to compute the particle scattering amplitude. But as theories of particles, QM and QFT are quite different theories. In particular, particles are fundamental in QM but emergent in QFT. That's, I think, is a deeper reason why effective action is useful in QFT but not so much useful in QM.
Let us briefly explain it at a more technical level. In general, the effective action is a tool to compute the n-point function. In QFT, the n-point function is something like
$$\langle \phi({\bf x}_1,t_1)\cdots \phi({\bf x}_n,t_n)\rangle$$
From this one can compute the particle scattering matrix via the LSZ formalism. Essentially the n-point function above is related to particles because ##\phi({\bf x},t)## can be thought of as an operator that (by acting on the vacuum) creates a particle at position ##{\bf x}## at time ##t##.
In QM, on the other hand, the n-point function is something like
$$\langle x(t_1)\cdots x(t_n)\rangle$$
where ##x(t)## is a particle position operator in the Heisenberg picture. The QM n-point function above is not related to the scattering matrix of particles. Unlike ##\phi({\bf x},t)##, the operator ##x(t)## is not something that creates a particle at position ##x## at time ##t##. When ##x## acts on the 1-particle harmonic-oscillator ground state ##\psi_0(x)## , it creates the first excited state ##\psi_1(x)## of the 1-particle harmonic oscillator - the number of particles remains unchanged.
Likes jordi, Mentz114 and DarMM
Under the LSZ formula in QM it would be a way of calculating transitions between Energy levels. As the analogue of particles from QFT in QM are the energy levels of the system.
However it's not as good as other methods we have of doing this in QM like the Fermi approximation and higher order corrections to it.
Also even if you were to try it, because in QM all the terms are relevant the effective action would just be more complex than the original one without terms dying off.
So you'd essentially have a more complicated Lagrangian for computing scattering between energy levels via a method less effective than the Born series.
Likes jordi and Demystifier
Well, in the case of real scalar fields, it's not the case that ##\phi## is a creation operator.
If you consider a free real scalar field in ##D+1## dimensions (##D## spatial dimensions and 1 time dimension), then the Lagrangian is:
##\frac{1}{2} (\frac{\partial \phi}{\partial t}^2 - \frac{\partial \phi}{\partial x^j}^2 - m^2 \phi^2)##
To the extent that it makes sense to consider ##D=0##, this becomes
##\frac{1}{2} (\frac{\partial \phi}{\partial t}^2 - m^2 \phi^2)##
which is the same as the quantum-mechanical Lagrangian for a harmonic oscillator with mass ##1## and spring constant ##m^2##, if you re-interpret ##\phi## as position. So the quantum-mechanical harmonic oscillator can be interpreted as a degenerate (0 spatial dimensions) quantum field theory. In which case, the ##n^{th}## energy level of the harmonic oscillator is interpreted as ##n## particles in the corresponding field theory.
Quantum mechanics with other sorts of potentials can similarly be interpreted as a degenerate quantum field theory with self-interaction.
Likes vanhees71, jordi and A. Neumaier
FAQ: Does the effective action make sense in Quantum Mechanics?
What is the effective action in Quantum Mechanics?
The effective action in Quantum Mechanics is a mathematical tool used to describe the dynamics of a system at a macroscopic level. It takes into account all possible interactions and fluctuations of the system and provides a comprehensive understanding of its behavior.
How is the effective action different from the standard action in Quantum Mechanics?
The standard action in Quantum Mechanics is a fundamental quantity that describes the dynamics of a system at a microscopic level. It only takes into account the classical dynamics of the system and does not consider quantum effects. The effective action, on the other hand, includes the effects of quantum fluctuations and interactions, making it a more accurate description of the system's behavior.
Why is the effective action important in Quantum Mechanics?
The effective action is important in Quantum Mechanics because it allows us to understand the behavior of a system at a macroscopic level, taking into account the effects of both classical and quantum dynamics. It is especially useful in studying complex systems, such as those found in condensed matter physics and particle physics.
How is the effective action calculated in Quantum Mechanics?
The effective action is typically calculated using perturbation theory, where the system is treated as a small perturbation on a known or solvable system. This allows for the calculation of the effective action in terms of the standard action and the perturbation terms. Other methods, such as the renormalization group, can also be used to calculate the effective action.
Can the effective action be experimentally measured in Quantum Mechanics?
No, the effective action cannot be directly measured in experiments. It is a theoretical concept that helps us understand the behavior of a system. However, the predictions made by the effective action can be tested through experiments and compared to observations, providing evidence for its validity.
