MHB Does the entrance test score determine the final exam score?
  • Thread starter Thread starter nycmathdad
    Exam
The discussion focuses on the relationship between entrance test scores and final exam scores in an algebra course. A scatter plot can be created to visualize the data, and it is noted that a student with a final exam score in the 80s has an entrance score of 65. The analysis reveals that a higher entrance score does not necessarily lead to a higher final exam score, as demonstrated by the variability in the data. While some students with high entrance scores achieved high final scores, others with lower entrance scores also performed well. Overall, the relationship between entrance and final exam scores is complex and influenced by multiple factors.
nycmathdad
The table shows the mathematics entrance test scores x and the final examination scores y in an algebra course for a sample of 10 students.
x...22 29 35 40 44 48 53 58 65 76
y...53 74 57 66 79 90 76 93 83 99
(a) Sketch a scatter plot of the data.
(b) Find the entrance test score of any student with a final exam score in the 80s.
(c) Does a higher entrance test score imply a higher final exam score? Explain.
Let me see.
Part (a) is just plotting points on the xy-plane.
Part (b)
The entrance score is 65 as shown in the table above for the point (65, 83).
Part (c)
A higher entrance score does not imply a higher final exam score. The table shows how entrance scores and final exam scores fluctuate. The point (76, 99) shows that a high entrance score led to a high final exam score but the case is different for (48, 90). A low entrance score of 48 led to a high final exam score of 90. Many factors lead to this fluctuation in terms of entrance scores versus final exam scores.
Mathematics news on Phys.org
This question is poorly worded, but I expect you are supposed to get a Least Squares Regression Line, so that you can use the equation to answer part (b) and determine if there is a trend in part (c).
Ok. I will research this problem online.
The data are given in order increasing entrance score. The corresponding final scores are:
The scores increase from
53 to 75, from 57 to 66, from 66 to 76, from 76 to 989, and from 83 to 99, 5 times.
The scores deceas3 from
74 to 57 and from 93 to 83, 2 times,
While not always increasing the data are, overall, increasing.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
