Does the Harmonic Series Exceed Its Integral Counterpart?
In summary,The expressions $\displaystyle \sum_{n=1}^{\infty}\frac{1}{n}$ and$\displaystyle \int_{0}^{\infty} \frac{1}{x}\ dx$ are meaningless because both the series and the integral diverge... may be is true that...$\displaystyle \sum_{k=1}^{n} \frac{1}{k} > \int_{1}^{n+1} \frac{dx}{x}\ (1)$The expressions $\displaystyle \sum_{n=1}^{\infty}\frac{1}{n}$ and$\displaystyle \int_{
mathworker
111
Is it true that,
\(\displaystyle \sum_{n=1}^{\infty}\frac{1}{n}>\int_{1}^{\infty}\)\(\displaystyle \frac {1}{x}dx\)
explanation is appreciated :)
edit:sorry,lower limit in right hand side is changed from "0" to "1"
Re: series integral comparision
mathworker said:
Is it true that,
\(\displaystyle \sum_{n=1}^{\infty}\frac{1}{n}>\int_{0}^{\infty}\)\(\displaystyle \frac {1}{x}dx\)
No it's not. Your sum is the right-hand estimate for the definite integral, but since the function is decreasing, your sum is an UNDER-estimate.
mathworker said:
Is it true that,
Kind regards
$\chi$ $\sigma$
mathworker said:
Is it true that,
I suspect that the OP is trying to prove that \(\displaystyle \displaystyle \begin{align*} \sum_{n = 1}^{\infty}{\frac{1}{n}} \end{align*}\) is divergent. To do this, a simple comparison can be used.
\(\displaystyle \displaystyle \begin{align*} \sum_{n = 1}^{\infty}{\frac{1}{n}} &= \frac{1}{1} + \frac{1}{2} + \frac{1}{3} + \frac{1}{4} + \frac{1}{5} + \frac{1}{6} + \frac{1}{7} + \frac{1}{8} + \dots \\ &> \frac{1}{2} + \frac{1}{2} + \left( \frac{1}{4} + \frac{1}{4} \right) + \left( \frac{1}{8} + \frac{1}{8} + \frac{1}{8} + \frac{1}{8} \right) + \dots \\ &= \frac{1}{2} + \frac{1}{2} + \frac{1}{2} + \frac{1}{2} + \dots \\ \to \infty \end{align*}\)
Since the harmonic series is greater than this divergent series, the harmonic series is divergent.
Yeah its meaning less to to compare two infinities, see 10.4 in this author trying two make some sense by comparing area under graphs,is the author wrong doing so?
No, the author is not wrong to do so. You have interpreted the original integral incorrectly. In this case the author is using the sum as a LEFT endpoint estimate on the integral, as on a decreasing function, you have an OVER estimation. The integral is actually being evaluated between 1 and infinity, not 0 and infinity. So the sum IS greater than the integral in that region, and so can be used to show the divergence of this series.
Actually my question is why did the author use bars for in graph
The task of the author probably is to demonstrate by geometrical evidence that... $\displaystyle \sum_{k=1}^{n} \frac{1}{k} > \int_{1}^{n+1} \frac{d x}{x} = \ln (n+1)\ (1)$
But if (1) is true, what can we say about the asyntotical behavior of $\displaystyle \sum_{k=1}^{n} \frac{1}{k}$ and $\displaystyle \ln n$?... in the XVIII century the Swiss mathematician Leonhard Euler demonstrated that...$\displaystyle \lim_{n \rightarrow \infty} \sum_{k=1}^{n} \frac{1}{k} - \ln n = \gamma\ (2)$
... where $\displaystyle \gamma= .5772...$ is the so called 'Euler's constant'... Kind regards $\chi$ $\sigma$
Because each bar has an area that is numerically equal to each term in the sum...
Very elegant! I'll have to remember this one.
This 'very elegant' prove that the harmonic series diverges was found in the 14th century by the French mathematician, economist, phisician, astronomer, astrologist, philosoph and theologian Nicolas d'Oresme, bishop of Lisieaux, one of the most original a versatile minds of the Middle Age...
Kind regards
$\chi$ $\sigma$
FAQ: Does the Harmonic Series Exceed Its Integral Counterpart?
What is a series integral comparison?
A series integral comparison is a method used in calculus to determine the convergence or divergence of an infinite series. It involves comparing the series to an integral function that is known to converge or diverge. This can help to simplify the problem and provide a quicker solution.
How is a series integral comparison done?
To use the series integral comparison method, you must first determine the integral function to compare the series to. This function should have the same general form as the series. Then, you must evaluate the integral and compare it to the series. If the integral converges, then the series also converges. If the integral diverges, then the series also diverges.
What are the limitations of series integral comparison?
Series integral comparison can only be used to determine the convergence or divergence of series with positive terms. It also cannot be used to determine the exact value of the series, only whether it converges or diverges. Additionally, the integral function chosen must be simpler than the series itself.
Why is series integral comparison useful?
Series integral comparison is useful because it provides a quick and easy method for determining the convergence or divergence of an infinite series. It also allows for comparison between different series and can help to identify patterns and relationships between them.
Can series integral comparison be used for all types of series?
No, series integral comparison can only be used for series with positive terms. It also may not work for all types of series, such as alternating series or series with non-polynomial terms. In these cases, other methods must be used to determine convergence or divergence.
