Does the limit of $||f||_p$ equal $||f||_{\infty}$ as $p$ approaches infinity?
  • MHB
  • Thread starter mathmari
  • Tags
    Limit
In summary, the conversation discusses proving that the limit of $||f||_p$ as $p$ approaches infinity is equal to $||f||_\infty$. The conversation goes into detail about using the essential supremum and shows that $m(A)>0$, where $A$ is the set of points where $|f|$ takes values greater than $||f||_\infty - \epsilon$. Ultimately, it is shown that the limit of $||f||_p$ is equal to $||f||_\infty$.
mathmari
MHB
5,049
Hey! :eek:
In a space with measure $1$, $||f||_p$ is an increasing function with respect of $p$. To show that $\lim_{p \rightarrow \infty} ||f||_p=||f||_{\infty}$ we have to show that $||f||_{\infty}$ is the supremum, right??
To show that, we assume that $||f||_{\infty}-\epsilon$ is the supremum.
From the esential supremum we have that $m(\{|f|>||f||_{\infty}-\epsilon\})=0$.
So, we have to show that $m(\{|f|>||f||_{\infty}-\epsilon\})>0$.
Let $A=\{|f|>||f||_{\infty}-\epsilon\}$.
We have that $\int_A |f|^p \leq \int |f|^p \leq ||f||_{\infty}^p$.
$\int_A |f|^p >\int_A (||f||_{\infty}-\epsilon)^p=(||f||_{\infty}-\epsilon)^p m(A)$
So, $m(A)^{1/p} (||f||_{\infty}-\epsilon)<||f||_p \leq ||f||_{\infty}$
Taking the limit $p \rightarrow +\infty$ we have the following:$$\lim_{p \rightarrow +\infty}m(A)^{1/p} (||f||_{\infty}-\epsilon)<\lim_{p \rightarrow +\infty} ||f||_p $$
Since we have supposed that $||f||_{\infty}-\epsilon$ is the supremum, is the limit of $||f||_p$ equal to $||f||_{\infty}-\epsilon$?? (Wondering)
So, is it as followed??
$$\lim_{p \rightarrow +\infty}m(A)^{1/p} (||f||_{\infty}-\epsilon)<||f||_{\infty}-\epsilon $$
(Wondering)
How can we get a contradiction?? (Wondering)
mathmari said:
Hey! :eek:
(Wondering)
Your proof is going in the right direction. But instead of treating it as a proof by contradiction, just choose $\epsilon>0$. It follows from the definiton of $\|f\|_\infty$ as an essential supremum that your set $A$ must have positive measure: $m(A) > 0.$
You have shown that $\|f\|_p^p = \int_A |f|^p \geqslant\int_A (||f||_{\infty}-\epsilon)^p=(||f||_{\infty}-\epsilon)^p m(A)$. When you take the $p$th root of that, you get $\|f\|_p \geqslant m(A)^{1/p}(||f||_{\infty}-\epsilon).$ By choosing $p$ large enough, you can get $m(A)^{1/p}$ as close as you like to $1$. Since $\epsilon$ could be made arbitrarily small it follows that by taking $p$ large enough you can get $\|f\|_p$ as close as you like to $\|f\|_\infty.$
Haven't we supposed that $||f||_{\infty}-\epsilon$ is the supremum?? (Wondering)
Why does it follow from the definiton of $\|f\|_\infty$ as an essential supremum that the set $A$ must have positive measure: $m(A) > 0.$ ?? (Wondering)
I think you need to look a bit more closely at the definition of $\|\,f\|_\infty$. Remember that when dealing with measurable functions we ignore anything that happens on a null set. So $\|\,f\|_\infty$ is not the least upper bound of $|\,f|$, but the least essential upper bound. This means that $|\,f|$ can take values larger than $\|\,f\|_\infty$, but only on a null set. However, if you take any number less than $\|\,f\|_\infty$ (for example $\|\,f\|_\infty - \epsilon$) then it is not an essential upper bound. This means that the set of points where $|\,f|$ takes values greater than $\|\,f\|_\infty - \epsilon$ is not a null set and must therefore have measure greater than $0$. That is the reason why $m(A)>0$.
We have that $0<||f||_{\infty}-\epsilon<||f||_{\infty}$ for some $\epsilon>0$.
$||f||_{\infty}$ is the essential supremum. So, from the definition we have that $m\left ( \{|f(x)>||f||_{\infty}-\epsilon\} \right )>0$.
$$\lim_{p \rightarrow +\infty}m(A)^{1/p} (||f||_{\infty}-\epsilon)<\lim_{p \rightarrow +\infty} ||f||_p \overset{ m(A)>0 \Rightarrow \lim_{p \rightarrow +\infty}m(A)^{1/p}=1}{\Longrightarrow} \\ ||f||_{\infty}-\epsilon<\lim_{p \rightarrow +\infty} ||f||_p$$
So, we have that $$||f||_{\infty}-\epsilon<\lim_{p \rightarrow +\infty} ||f||_p \leq ||f||_{\infty}$$
Since $\epsilon$ is arbitrarily, it follows that $$\lim_{p \rightarrow +\infty} ||f||_p = ||f||_{\infty}$$
Is this correct?? (Wondering)
Yes, that looks good. (Sun)
Great! Thank you very much! (Yes)
FAQ: Does the limit of $||f||_p$ equal $||f||_{\infty}$ as $p$ approaches infinity?
What does it mean to "show that this is the limit"?
"Showing that this is the limit" refers to proving that a mathematical expression or function approaches a specific value as its input approaches a certain value. This is often denoted by the limit notation, where the input value is represented by a variable approaching a specific value, and the output value is represented by a limit value.
Why is it important to determine the limit of a function?
Determining the limit of a function is important because it helps us understand the behavior of the function at a certain point or as the input approaches a certain value. It can also help us determine the continuity and differentiability of a function, and is a fundamental concept in calculus and other areas of mathematics.
What are the different methods for showing that a limit exists?
There are several methods for showing that a limit exists, including the epsilon-delta method, the squeeze theorem, and the limit laws. These methods involve using certain mathematical techniques and properties to prove that a function approaches a specific value as its input approaches a certain value.
Can a function have multiple limits?
No, a function can only have one limit at a specific point. The limit of a function is unique, meaning that as the input approaches a certain value, the output can only approach one specific value. However, a function may have a different limit at different points, and may also have a right and left limit at a specific point.
How can I use limits in real-world applications?
Limits have many real-world applications, such as in physics, engineering, and economics. They can be used to model and predict the behavior of systems, to optimize functions, and to understand the behavior of physical phenomena. For example, limits are used in calculus to calculate velocity and acceleration, and in economics to determine the maximum profit for a given production level.
