Does the maximum value of the following integral exist?
In summary, for the given conditions, there does not exist a maximum value for ##a##. As shown by the example using the function ##f:\mathbb R\to\mathbb R## that is equal to ##\frac{\sin nx}{\sqrt\pi}## on the interval ##[0,2\pi]## and zero outside it, the first integral is always 1 but the second integral increases without limit as ##n## increases. If we change the second integral to use the 4th power of the derivative instead of its square, we still get an infinite value for ##a## when ##n## is infinite.
Tspirit
50
Suppose ##\intop_{-\infty}^{+\infty}(f(x))^{2}dx=1##, and ##a=\intop_{-\infty}^{+\infty}(\frac{df(x)}{dx})^{2}dx##, does a maximum value of ##a## exist? If it exists, what's the corresponding ##f(x)##?
No it doesn't exist. Consider the function ##f:\mathbb R\to\mathbb R## that is equal to ##\frac{\sin nx}{\sqrt\pi}## on the interval ##[0,2\pi]## and zero outside it. The first integral is 1 regardless of the value of ##n## but the second integral increases without limit as ##n## increases.
Likes Tspirit
Yes, you are right. Thanks.
Nice example, andrewkirk ! (Now I wonder what if the original problem were changed only so that the second integral used the 4th power of the derivative instead of its square.)
I think it is like this: ##\intop_{+\infty}^{-\infty}f(x)dx=1##,and ##a=\intop_{-\infty}^{+\infty}(\frac{df(x)}{dx})^{4}dx##, does a maximum value of a exist?
If we use the example andrewkirk said ##“\frac{sin(nx)}{\sqrt{\pi}}”##, we have $$a=\intop_{-\infty}^{+\infty}(\frac{df(x)}{dx})^{4}dx=\intop_{-\infty}^{+\infty}(\frac{ncos(nx)}{\sqrt{\pi}})^{4}dx,$$ $$(ncos(nx))^{4}=n^{4}\left(\frac{1+cos2nx}{2}\right)^{2}=n^{4}[\frac{1}{4}+\frac{1}{2}cos2nx+\frac{1}{8}(1+4con4nx)],$$ so when ##n## is infinite, the ##a## is also infinite.
Related to Does the maximum value of the following integral exist?
1. What is the maximum value of an integral?
The maximum value of an integral is the highest possible numerical result that can be obtained by evaluating the integral over a given range.
2. How is the maximum value of an integral calculated?
The maximum value of an integral can be calculated by finding the critical points of the function being integrated and evaluating the function at those points. The highest value obtained is then the maximum value of the integral.
3. Can the maximum value of an integral be negative?
Yes, the maximum value of an integral can be negative. This can occur when the integrand has both positive and negative values over the given range, resulting in a net negative value for the integral.
4. Does the maximum value of an integral always exist?
No, the maximum value of an integral may not always exist. This can happen when the function being integrated is discontinuous or undefined over the given range, making it impossible to find a maximum value.
5. How can it be determined if the maximum value of an integral exists?
To determine if the maximum value of an integral exists, one can evaluate the integral over a smaller and smaller range, approaching the given range. If the values obtained become increasingly large or small, it indicates that the maximum value of the integral does not exist.
  • Calculus
  • Calculus
