Does the non-periodic signals have frequency or not?
In summary: I don't have the mathematical background to go into more detail. Perhaps someone with that level of expertise can answer this question more appropriately.In summary, a non-periodic signal does not have a frequency. But we can calculate a frequency spectrum as indicated in post #4.
Geek007
Can someone kindly explain , what is the frequency of non periodic signals? Periodic signals have frequency of number of cycles completed in one second and but non periodic signals don't have repeated pattern so what would be the frequency of non periodic signals. Kindly do explain it in simple words , as my background isn't of physics.I'm a CS students.
Non-periodic signals do not have "a frequency". If they are close to a periodic signal, but with some additional nonperiodic noise, you can still find frequencies that are relevant for the signal. Mathematically, that is done via a Fourier transformation. It will give you an amplitude for every frequency, which shows you how "relevant" that frequency is.
Likes Geek007
Another way of looking at this: A perfectly periodic signal lasts forever and started an infinitely long time ago -- or else it would not be perfectly periodic. In practice, e.g. in music, a tone can be almost perfect (have one single frequency for all we know) and last only a short time. But it's clearly not exactly periodical.
The mathematical bottom line is that if we choose a time slice, for music e.g. 1 second, we can calculate a frequency spectrum for that one second of music. To do that we simply let this second repeat forever and calculate the aforementioned Fourier transform ( -- very useful for CS students too !) We don't get information on frequencies lower than 1 Hz but don't care about that.
That's what spectrum analyzers do (for example in media player visualizations).
Likes Geek007
Well, if non periodic signal don't have frequency then why we said this music is of 25khz etc? i mean to say , why should then we associate frequency with non peroidic signals such like music?
If the frequency spectrum has a peak somewhere then that's the frequency we hear. But when the music is over, we don't hear that frequency anymore. So it's periodical for a while. Not periodical in the mathematical sense that ## f(t + n \tau)\quad \forall n \quad ##.
does the non periodic signal have period, as period and frequency are exactly of opposite of each other?
Geek007 said:
see, i said i don't have physics background that's why its really difficult for me to understand The answer with too much detail. i just want to know simple and precise answers .
Does Non periodic signal have period and frequency as like of periodic signal if not then why?
Do you understand the answers that you got so far ? If not, what is your background ? I would expect some math for a CS student ( -- if CS means Computer Science ). Trigonometry ?
geek007 said:
For the time being i don't need that much detail as I'm preparing a lesson. But I'm revising my physics concepts of high school to get on track asap. can you please now give me answer of my question. Bundle of thanks in advance.
A non-periodic signal does not have a frequency as indicaterd in post #3. But we can calculate a frequency spectrum as indicated in post #4.
We do it because it 'works' as a way of describing the signal to an adequate level of accuracy. (And that goes for any measurement of anything.)
The very first assumption in frequency analysis assumes that any continuous waveform exists for all time. The full Fourier Transform of such a signal will not consist of a 'comb' of frequency components - which is what we see on a spectrum analyser. It will be a continuous function in the Frequency Domain What we always see is a Discrete Fourier Transform, which takes a sequence of thousands or millions of signal values (samples) over a period of time and that will give a comb of components, spaced by a frequency equal to 1/(the sequence length). It 'assumes' that the signal repeats itself over the time of the whole number of samples. A FFT (Fast Fourier Transform is a cheeky / clever method that uses a set of samples that is 2n long and uses a process of reduction to give an answer with much less computing time.
So you may say that it is all a big con from the start! And, if you are not careful, you can get 'wrong' answers from the process. Using a long enough string of samples and a process of 'windowing' can reduce errors to an acceptable level. If you try to make a wrong analysis of a signal, you can end up losing some major components in your result.
Unfortunately, many people do not consider the small print involved in these signal processes and can come to false conclusions. Signal processing is hard stuff and you often have to take some things for granted (as long as you get them from a reputable source).
FAQ: Does the non-periodic signals have frequency or not?
Does a non-periodic signal have a frequency?
Yes, a non-periodic signal does have a frequency. However, unlike a periodic signal, the frequency of a non-periodic signal is not constant and may vary over time.
How is the frequency of a non-periodic signal determined?
The frequency of a non-periodic signal can be determined by analyzing its Fourier transform. This mathematical tool breaks down a signal into its individual frequency components.
Can a non-periodic signal have multiple frequencies?
Yes, a non-periodic signal can have multiple frequencies. This is because it is composed of multiple frequency components that make up the overall signal.
Do non-periodic signals have a fundamental frequency?
No, non-periodic signals do not have a fundamental frequency like periodic signals do. This is because the frequency of a non-periodic signal is not constant and cannot be represented by a single frequency value.
Why are non-periodic signals important in science and engineering?
Non-periodic signals are important in science and engineering because they are commonly found in real-world systems and can provide valuable information about the behavior of these systems. They are also used in various applications such as signal processing and communication systems.
