I Does the Normal contact force act through the centre of mass?
The discussion centers on the behavior of normal contact forces in relation to torque and the center of mass (COM) when a block is pushed to the right. It clarifies that the normal contact force does not always act through the center of mass, as it is defined as perpendicular to the contact surface. The maximum displacement occurs when the weight of the block aligns with the pivot point, preventing rotation. If the center of mass moves beyond the edge, the normal force cannot counterbalance the torque from the weight, leading to loss of contact. The conversation emphasizes that normal forces and gravitational forces can create torque, affecting stability and motion.
phantomvommand
TL;DR Summary
Does the Normal contact force always act through the centre of mass?
Consider the following situation:
You have 1 rectangular block lying on a table, and an identical block is placed above the block on the table. Now, this new block is constantly pushed to the right, right before it topples off.
Consider the torque about an axis passing through the rightmost and topmost point (this point is labelled A) of the bottom block. I read somewhere that the maximum this new block can be pushed is to the point where it Weight acts through A. Does this mean Normal contact force also only acts through A at this point?
Thank you!
No. Normal contact force is a general concept that has nothing to do with the centre of mass per se.
Yes, in this special case, where the normal forces must not create any net torque, their effective sum has to pass through the center of mass.
Likes Lnewqban and phantomvommand
A.T. said:
No. Normal contact force is a general concept that has nothing to do with the centre of mass per se.Yes, in this special case, where the normal forces must not create any net torque, their effective sum has to pass through the center of mass.
I was really confused just now. Yes, it does not always go through the COM. Normal force is perpendicular to the contact surface, right?
In the situation I mentioned earlier, why is it that the maximum rightwards displacement is when Weight acts through the pivot point?
I suppose it is because when the Centre of Mass moves beyond the edge, normal contact force (acting perpendicular to the contact surface) can never balance the torque due to weight, resulting in rotation, loss of contact, and normal contact force = 0 eventually?
Yes, that's all it means.
I would put it like this: Uniform gravity doesn't create any torque around the CoM, so the torque around the CoM by the supporting froces must also be zero to prevent rotation. With all the contact surface on one side of the CoM, there is no possible distribution of a non-zero support froce, that would create zero torque around the CoM.
Same thing will happen in the case the surfaces of contact between both blocks are not horizontal.
Normal forces will have one direction and gravity force will have another, yet the top block will start rotating around point A clockwisely as soon as it has been pushed towards the right enough as to have more mass to the right than to the left of an imaginary vertical line that intersects point A.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
