Does the Polynomial $P(x)=x^3+mx^2+nx+k$ Have Three Distinct Real Roots?
In summary, the Polynomial Challenge VIII is a mathematical problem involving finding the roots of a polynomial equation of the 8th degree. It is unique and more challenging compared to other polynomial challenges. Common strategies for solving it include using the rational root theorem, factoring, and the quadratic formula. There is no one specific formula for solving it, and different techniques can be used. It can be solved by hand, but a computer or calculator may be needed for more complex equations.
anemone
MHB
POTW Director
3,883
115
A polynomial $P(x)=x^3+mx^2+nx+k$ is such that $n<0$ and $mn=9k$.
Prove that the polynomial has three distinct real roots.
Mathematics news on Phys.org
If $m = 0$, then $k = 0$ and $P(x) = x^3 + nx$. So $P$ has three real distinct roots: $0, \sqrt{-n}$ and $-\sqrt{-n}$.
Now suppose $m \neq 0$. If $m > 0$, then $P(x)$ has one sign change and $P(-x)$ has two sign changes. By Descartes' rule of signs, $P$ has one positive root and zero or two negative roots. Since $P(0) = \frac{mn}{9}$ and $P(-m) = -\frac{8mn}{9}$ have opposite signs, the intermediate value theorem ensures that $P$ has a negative root. Therefore $P$ has two negative roots. By a similar argument, if $m < 0$, then $P$ has one negative root and two positive roots. Hence in both cases, $P$ has three real roots, two of which have different signs. So it suffices to show that $P$ has no double root.
Since $P$ is cubic, if it has a double root, then that root is a critical point. The critical points of $P$ are $\frac{-m+\sqrt{m^2-3n}}{3}$ and $\frac{-m-\sqrt{m^2-3n}}{3}$. Neither of these satisfy $P$. Indeed, by the second derivative test, these points give a global min and max for $P$. But $P$ is nonconstant, so they cannot be roots of $P$. So, $P$ has no double root. Therefore, $P$ has three distinct real roots, with exactly two roots of the same sign.
Well done, Euge! And thanks for participating!
Here is one solution that I saw online that approaches it differently than you, so I will share it with you and the rest of the members:
Consider the derivative $P'(x)=3x^2+2mx+n$. Since $n<0$, it has two real roots $x_1$ and $x_2$. Since $P(x)\rightarrow \pm \infty$ as $x\rightarrow \pm \infty$, it is sufficient to check that $P(x_1)$ and $P(x_2)$ have different signs, i.e., $P(x_1)P(x_2)<0$.
Dividing $P(x)$ by $P'(x)$ and using the equality $mn=9k$, we find that the remainder is equal to $x\left(\dfrac{2n}{3}-\dfrac{2m^2}{9}\right)$. Now, as $x_1x_2=\dfrac{n}{3}<0$, we have $P(x_1)P(x_2)=x_1x_2\left(\dfrac{2n}{3}-\dfrac{2m^2}{9}\right)^2<0$ and we're done.
FAQ: Does the Polynomial $P(x)=x^3+mx^2+nx+k$ Have Three Distinct Real Roots?
What is the Polynomial Challenge VIII?
The Polynomial Challenge VIII is a mathematical problem that involves finding the roots or solutions of a polynomial equation of the 8th degree.
How is the Polynomial Challenge VIII different from other polynomial challenges?
The Polynomial Challenge VIII is unique because it involves a polynomial equation of the 8th degree, which is generally more complex and challenging to solve compared to lower degree polynomial equations.
What are the common strategies for solving the Polynomial Challenge VIII?
Some common strategies for solving the Polynomial Challenge VIII include using the rational root theorem, factoring, and using the quadratic formula for higher degree polynomials.
Is there a specific formula for solving the Polynomial Challenge VIII?
No, there is no one specific formula for solving the Polynomial Challenge VIII. Different techniques and strategies can be used depending on the specific equation and its factors.
Can the Polynomial Challenge VIII be solved by hand or do I need a computer?
The Polynomial Challenge VIII can be solved by hand using various techniques and methods. However, for more complex equations, a computer or calculator may be necessary to find the solutions accurately.
