Does the ruby laser (the first invented laser) have nonlinear behavior?
In summary, a ruby laser has three energy levels that can be accessed with radiationless transition, and the process of transitioning to the metastable level is considered as nonlinear optics.
Sciencestd
63
Hello Everyone!
I read about the function of the ruby laser which made from ruby crystal and has three energy levels. There is radiationless transition to what so called metastable level and then the electrons there stimulated to transit to ground energy state. The question is: does this process considered as nonlinear optics? does ruby laser has nonlinear optics concept? One of what also confused me that when I read in a book that the nonlinear optics born was in 1961 after the invention of the first laser (ruby laser), and there they could get second harmonic generation... So please if you can explain these things tom me I will be glad for that known that I'm bit new in this field. Thank you!
Science news on Phys.org
Not sure what you are looking for with "non-linear". Like most lasers, a minimum number of phosphor in the exited state before a laser discharge can occur. Others like He-Ne lasers keep enough molecules in the exited state to discharge continously. Perhaps a threshold for emission is your non-linear.
True non-linear optics, like Lithium Iodate, can mix two light frequencies and get a third light frequency. Or it can double or tripple single frequencies e.g. turn an infrared laser beam into a blue laser beam.
Likes Sciencestd
I used "phosphor" to simplify atomic emission (chrome in ruby), emission from organic dye molecules, emission from charge anhiliation in semiconductors (bandgap laser).
Likes Sciencestd
For harmonic generation I think you need a coherent oscillator like a laser. Before the invention of the laser, we had neon tubes, for example, which just created incoherent optical noise. A parallel to this is the radio frequency oscillator, which has harmonics, and the spark gap, which does not.
Likes Sciencestd
Ruby is non-linear, to some extent. You can find the data with a web search. However, non-linear optical materials isn't a beginner level of physics.
In practice, it isn't used as a non-linear material in optical design since there are much, much more efficient nonlinear crystals (KDP, KTP, LBO, BBO, etc.). It may be of interest if you want to design a modern Ruby laser (which I don't think anyone does these days); it would come into play as a lossy element in the gain medium. Except for some CW lasers, frequency doubling (or mixing) is typically done outside of the laser resonator to avoid the loss issues with non-linear optics from interfering with the laser gain. There are typically fewer constraints on the non-linear crystals when they don't have to be inside the laser resonator.
I suspect that what they meant was that Ruby lasers were a light source that allowed evaluation of non-linear behavior in other materials. Ruby was one of the early sources of pulsed high peak power laser light, which you want if your looking for non-linear behavior.
Likes Sciencestd
Thank you all for the answers, it directed me and explained a lot of things to me. :)
Sure if I have further questions so I will post it here ;)
Likes berkeman
Related to Does the ruby laser (the first invented laser) have nonlinear behavior?
1. How does the ruby laser produce light?
The ruby laser produces light through a process called stimulated emission. This involves exciting the ruby crystal with an external energy source, such as a flash lamp, causing the ruby atoms to emit photons in a specific wavelength.
2. What is nonlinear behavior in a laser?
Nonlinear behavior in a laser refers to the deviation from a linear relationship between the input energy and the output light intensity. This can occur when the intensity of the light reaches a certain threshold, causing changes in the laser's behavior.
3. What factors can affect the nonlinear behavior of a ruby laser?
The nonlinear behavior of a ruby laser can be affected by several factors, including the intensity of the input energy, the quality of the ruby crystal, and the temperature of the crystal. Any changes in these factors can lead to nonlinear behavior.
4. Can the nonlinear behavior of a ruby laser be controlled?
Yes, the nonlinear behavior of a ruby laser can be controlled through various methods such as adjusting the input energy, using high-quality ruby crystals, and maintaining a stable temperature. These measures can help minimize the nonlinear effects and improve the laser's performance.
5. How does the nonlinear behavior of a ruby laser impact its practical applications?
The nonlinear behavior of a ruby laser can impact its practical applications in various ways. For example, it can affect the laser's efficiency, stability, and output characteristics. Therefore, it is essential for scientists and engineers to understand and control the nonlinear behavior to optimize the laser's performance for specific applications.
  • Atomic and Condensed Matter
  • Quantum Physics
