Does the series with increasing numerators converge?
  • MHB
  • Thread starter karush
  • Tags
    Series Sum
In summary, the series given by $\frac{5}{3}+2+\frac{12}{5}+...$ eventually simplifies to $\frac{n^2+3n+6}{2(n+2)}$, which also diverges as the individual terms do not go to 0.
karush
MHB
3,269
Find the sum for the series
$$\frac{5}{3}+2+\frac{12}{5}+...$$
This equals
$$\frac{25}{15}+\frac{30}{15}+\frac{36}{15}+...$$
So the numerator increases by 4+k from the previous numerator
But unable to set up
$$\sum_{k+1}^{\infty}f(x)$$
The series should go to $\infty$ since the terms only increase in size
Mathematics news on Phys.org
Correct, the series diverges.
This equals
Given that the numerator increases linearly, we know it will be a quadratic function and so the $n$th term in the series will have the form:
\(\displaystyle a_n=\frac{an^2+bn+c}{15}\)
Using the given initial values, the following 3X3 linear system arises:
\(\displaystyle a+b+c=25\)
\(\displaystyle 4a+2b+c=30\)
\(\displaystyle 9a+3b+c=36\)
Solving this system, we obtain:
\(\displaystyle (a,b,c)=\left(\frac{1}{2},\frac{7}{2},21\right)\)
And so we have the $n$th term:
\(\displaystyle a_n=\frac{n^2+7n+42}{30}\)
Hence, the $n$th sum of the series is given by:
\(\displaystyle S_n=\sum_{k=1}^n\left(a_k\right)=\frac{1}{30}\left(\sum_{k=1}^n\left(k^2+7k+42\right)\right)=\frac{1}{30}\left(\sum_{k=1}^n\left(k^2\right)+7\sum_{k=1}^n(k)+42\sum_{k=1}^n(1)\right)\)
Now, using the following formulas:
\(\displaystyle \sum_{k=1}^n\left(k^2\right)=\frac{n(n+1)(2n+1)}{6}\)
\(\displaystyle \sum_{k=1}^n\left(k\right)=\frac{n(n+1)}{2}\)
\(\displaystyle \sum_{k=1}^n\left(1\right)=n\)
We may now state:
\(\displaystyle S_n=\frac{1}{30}\left(\frac{n(n+1)(2n+1)}{6}+\frac{7n(n+1)}{2}+42n\right)=\frac{n}{180}\left((n+1)(2n+1)+21(n+1)+252\right)\)
Expanding, combining like terms and factoring, we finally obtain:
\(\displaystyle S_n=\frac{n}{90}\left(n^2+12n+137\right)\)
And so we find:
\(\displaystyle S_{\infty}=\lim_{n\to\infty}\left(S_n\right)=\infty\)
karush said:
Find the sum for the series: [tex]\frac{5}{3}+2+\frac{12}{5}+ \cdots[/tex]
This equals: [tex]\frac{25}{15}+\frac{30}{15}+\frac{36}{15}+\cdots[/tex]
So the numerator increases by 4+k from the previous numerator , but unable to set up [tex]\sum_{k+1}^{\infty}f(x)[/tex]
I saw a different series.
[tex]\frac{5}{3} + 2 + \frac{12}{5} + \cdots \;=\;\frac{5}{3} + \frac{8}{4} + \frac{12}{5} + \cdots \;=\;\sum^{\infty}_{n=1} \frac{n^2+3n+6}{2(n+2)}[/tex] . . . which also diverges.
You should see immediately that the individual terms do not go to 0 so the series does not converge.
FAQ: Does the series with increasing numerators converge?
What is a series?
A series is a mathematical concept that involves adding together a sequence of numbers or terms. The terms in a series can be finite or infinite.
What is the sum for a series?
The sum for a series is the total value obtained by adding together all the terms in the series. It is also known as the total or the result of the series.
How do you find the sum for a series?
To find the sum for a series, you can use various mathematical techniques such as the arithmetic progression formula, the geometric progression formula, or the telescoping series method. The specific method used will depend on the type of series and its terms.
Why is finding the sum for a series important?
Finding the sum for a series is important because it allows us to determine the total value or result of a sequence of numbers. This can be useful in various real-life situations, such as calculating interest rates, predicting future trends, or solving mathematical problems.
What are some common types of series?
Some common types of series include arithmetic series, geometric series, telescoping series, harmonic series, and alternating series. Each type has its own unique characteristics and methods for finding the sum.
