Does there exist a proof for these conjectures?
  • A
  • Thread starter hilbert2
  • Tags
    Proof
In summary, the claims about 1d quantum mechanics are that (1) the standard deviation of the particle's position in the eigenstates of ##\hat{H}## increases monotonically with increasing quantum number, (2) the energy level spacing ##E_{n+1} - E_n## can only increase or stay constant with increasing quantum number, and (3) a system having any spectrum like ##E_n = a + bn^c## with ##a,b,c## constants, ##1\leq c \leq 2## and ##b>0## can be produced with a ##V(x)## of the form given above.
hilbert2
Insights Author
605
TL;DR Summary
Made up some unproven(?) statements about simple one particle QM.
Does anyone know if a proof exists for these statements about 1d quantum mechanics?
1. If the potential energy where a particle moves is of the form
##V(x) = c_2 x^2 + c_4 x^4 + c_6 x^6 + \dots##
or
##V(x) = c_2 x^2 + c_3 |x|^3 + c_4 x^4 + c_5 |x|^5 + c_6 x^6 + \dots##
with ##c_j \geq 0## for all ##j\in\mathbb{N}##, then the standard deviation of the particle's position in the eigenstates of ##\hat{H}## increases monotonically with increasing quantum number.
2. If the ##V(x)## is like that above, then the energy level spacing ##E_{n+1} - E_n## can only increase or stay constant with increasing quantum number ##n##.
3. A system having any spectrum like ##E_n = a + bn^c## with ##a,b,c## constants, ##1\leq c \leq 2## and ##b>0## can be produced with a ##V(x)## of the form given above.
The claim number 2 seems to be correct, because if you begin with the harmonic oscillator potential ##V(x) = \frac{1}{2}kx^2## and add a small perturbation of form ##V'(x) = \lambda x^{2n}## with ##n\in\mathbb{N}## and ##n\geq 2##, then the first order correction to the ##m##:th energy eigenvalue is ##E_{m}^{'} = \lambda\int\limits_{x=-\infty}^{x=\infty}\psi_{m}^{*}(x)x^{2n}\psi_m (x)dx##. This clearly gets larger with increasing ##m## (basically because of what was said in claim 1, i.e. the particle is more likely to be far from the origin ##x=0## for higher excited states), so this perturbation will only increase energy level spacings. But it's not rigorously clear that one can assume claim 1 is true and the first-order change can be used to predict the result of finite perturbations.
I invented claim 3 because of the observation that a spectrum like ##E_n = a + bn^c## usually fits very accurately to the first 10 - 20 eigenenergies of a system with a convex potential energy function ##V(x)##. Only with larger quantum numbers it's easy to see the difference. So the claim 3 is the converse of that statement. However, the potential energy ##V(x) = c_2 x^2 + c_4 x^4 + c_6 x^6 + \dots## is not necessarily the only one that produces the same spectrum - a system with constant energy level spacings can also be created with the singular "isotonic oscillator potential" ( https://www.sciencedirect.com/science/article/abs/pii/037596017990197X ) instead of a harmonic oscillator. One way to reconstruct a ##V(x)## corresponding to a given spectrum ##E_n## is the inverse scattering theorem, but it's not necessarily easy to calculate the limit of Eqn. (5a) in the link https://arxiv.org/pdf/0811.1389.pdf when all eigenvalues are included and the determinant becomes "infinitely large".
Likes Haborix
Regarding #2, I recall at some point looking at work on Sturm-Liouville problems for the asymptotics of eigenvalues at large quantum numbers. But I also remember everything was much more complicated when the domain was the whole line as opposed to some compact segment.
Likes vanhees71 and hilbert2
That sounds like it has something to do with the WKB approximation... But if the system is on a compact segment of the real line, then shouldn't the eigenvalues behave like ##E_n \propto n^2## for large ##n##, as in the particle in a box problem?
When trying to fit those functions ##E_n = a + bn^c## to spectra of systems where the graph of ##V(x)## can only turn upward, the clearest difference was already seen in the low eigenvalues when the potential energy was ##V(x) = C|x|## for ##|x| < L/2## and ##V(x) = \infty## for ##|x| \geq L/2## for some well diameter ##L##. In this potential, the particle should "see" a linear slope at low energies and only care about the hard walls at ##|x|=L/2## with high energy eigenstates. In that one the two different "extreme cases" are found from the same system.
Likes vanhees71
FAQ: Does there exist a proof for these conjectures?
What is a proof and why is it important?
A proof is a logical and rigorous argument that demonstrates the truth of a mathematical statement or conjecture. It is important because it provides a solid foundation for mathematical knowledge and allows for the verification of mathematical claims.
How do mathematicians go about proving conjectures?
Mathematicians use a combination of logical reasoning, mathematical techniques, and creativity to construct proofs. They often start by assuming the conjecture is true and then work backwards to find a logical sequence of steps that lead to a known truth or axiom.
Can a conjecture ever be proven wrong?
Yes, a conjecture can be proven wrong if a counterexample is found. A counterexample is a specific case that contradicts the conjecture. However, even if a conjecture is proven wrong, it can still be valuable in guiding future research and understanding the limits of current mathematical knowledge.
How long does it take to prove a conjecture?
The time it takes to prove a conjecture varies greatly and depends on the complexity of the conjecture, the available resources and techniques, and the creativity of the mathematician. Some conjectures may be proven relatively quickly, while others may remain unsolved for decades or even centuries.
Are there any famous unsolved conjectures in mathematics?
Yes, there are many famous unsolved conjectures in mathematics, such as the Riemann Hypothesis, the Goldbach Conjecture, and the P vs. NP problem. These conjectures have intrigued mathematicians for centuries and have led to significant advancements in mathematical research.
