Does there exist a surjection from the natural numbers to the reals?
The discussion centers around the existence of a surjection from the natural numbers to the reals, concluding that no such surjection can exist. It references Cantor's proof, which demonstrates that there is no bijection between the two sets, implying that the cardinality of the naturals is less than that of the reals. The participants explore the implications of assuming a surjection and derive contradictions by constructing subsets of natural numbers that would lead to a bijection with the reals. Ultimately, they reaffirm that the cardinality of the natural numbers is not equal to that of the reals, reinforcing the conclusion that a surjection cannot exist. The thread emphasizes the importance of understanding the proof strategy rather than just formalizing it.
docnet
1) What does it mean if two sets ##X## and ##Y## have the same cardinality?
2) Given sets ##A## and ##B## what does ##|A|\leq |B|## mean?
3) Does there exist a surjection from the natural numbers to the reals? If so, define one. If not, explain why one cannot exist.
##\mathbb{N}## and ## \mathbb{R}##
1)
Two sets have the same cardinality if there exists a bijection (one to one correspondence) from ##X## to ##Y##. Bijections are both injective and surjective. Such sets are said to be equipotent, or equinumerous. (credit to wiki)
2)
##|A|\leq |B|## means that there is an injective function from ##A## to ##B##. An injective function maps distinct elements of ##A## to distinct elements in ##B##.
3)
No.
Cantor's proof that there is no surjection ##f:\mathbb{N}\longrightarrow \mathbb{R}## seems relevant here.
I'm wondering if there is a lazier way to answer this question, although I think the following logic is flawed.
In class, we are given as a theorem that there is no bijection ##f:\mathbb{N}\longrightarrow \mathbb{R}##. Bijective functions are both injective and surjective, so there is no such ##f:\mathbb{N}\longrightarrow \mathbb{R}## that is both injective and surjective.
An example of an injection ##f:\mathbb{N}\longrightarrow \mathbb{R}##:
Let ##f:\mathbb{N}\longrightarrow \mathbb{R}## be a function defined by the rule ##f(n)=n##. ##f(n)\neq f(m)## whenever ##n\neq m##, so ##f## is injective. Since an injection ##f:\mathbb{N}\longrightarrow \mathbb{R}## was defined, it exists.
The issue is that this logic cannot deal with the possibility of an ##f## being surjective and not injective.
You are right, including your assessment of the last argument. It does not help that there is an injection, or that there is no bijection. You must take a possible surjection and deduce a contradiction. Just an idea: Assume ##f\, : \,\mathbb{N}\longrightarrow \mathbb{R}## is surjective. Then ##\emptyset \neq f^{-1}(r)\subseteq \mathbb{N}## for every ##r\in \mathbb{R}.## Hence we have a well-defined smallest element ##\mathbb{N}\ni N_r\in f^{-1}(r)## for all ##r\in \mathbb{R}.## This defines a function ##r\longmapsto N_r\,.##
What can you say about it?
Likes docnet, sysprog and PeroK
##f## is surjective, so it is well-defined. So ##f(n)\neq f(m)\Longrightarrow n\neq m##. This leads to ##f^{-1}(f(m))\neq f^{-1}(f(n))## whenever ##m\neq n##. So the ##f^{-1}(r)## are disjoint in ##\mathbb{N}## for all ##r##. ##N_r\in f^{-1}(r)##. Hence the ##N_r## are disjoint for all ##r##. Hence ##r\longmapsto N_r## is injective.
(Is this okay?)
This means the image of ##r\longmapsto N_r## (we could call the set ##\mathbb{N}_r## for brevity) has a cardinality equal to ##|\mathbb{R}|=𝔠 ##. ##N_r\in \mathbb{N}## for all ##r##, so we have ##\mathbb{N}_r\subset\mathbb{N}##. So it must also be that ##|\mathbb{N}|\geq 𝔠##.
(Is this still okay?)
There can be no bijections from ##\mathbb{N}## to ##\mathbb{R}##. This means ##|\mathbb{N}|\neq 𝔠##. So we have ##|\mathbb{N}|> 𝔠##.
I am stumped trying to derive a contradiction. @fresh_42 could you please drop a little hint?
These are two unrelated properties. A function is well-defined if it doesn't map one element on two targets. A function is surjective if every possible target is actually hit at least once. You can only construct an implicit dependency. By saying a function is surjective, it is already assumed that it is a function, i.e. especially well-defined. If you meant this, then you are right. But it would be better to state that ##f## is well-defined by assumption, rather than by surjectivity.
(Is this okay?)
Think so.
Yes. You could also simply observe that ##f(\varphi (r))=r## where ##\varphi (r)=N_r## is the function we get from ##f^{-1}## by picking the least number. Now ##\mathbb{R}\stackrel{\varphi }{\longrightarrow }\mathbb{N}_r\stackrel{f}{\longrightarrow }\mathbb{R}## is the identity map, and since ##f## is surjective, we have ##\mathbb{R}=\mathbb{N}_r## and there is no such bijection.
Well, you could simply say that we already know that ##|\mathbb{N}|<|\mathbb{R}|## by Cantor's diagonal enumeration argument.
I suggest it's better to really understand the strategy of the proof before you get into the complications of writing it down formally:
1) We know that there is no bijection from ##\mathbb N## to ##\mathbb R##.
2) We also know that there is no bijection from a subset of ##\mathbb N## to ##\mathbb R##.
3) Suppose ##f## is a surjection from ##\mathbb N## onto ##\mathbb R##.
3a) The idea is to use ##f## to construct a bijection from a subset of ##\mathbb N## to ##\mathbb R##, which proves that no such surjection exists.
3b) Every real number ##r## is in the range of ##f##. Hence, there exists a non-empty set of natural numbers ##S_r## than are all mapped to ##r##. Note that ##S_r## may be a single element, finite or infinite subset of ##\mathbb N##. Note that the ##S_r## are disjoint, as ##f## is a (well-defined) function.
3c) Each ##S_r## has a smallest element ##n_r##.
3d) The set ##S = \{n_r: r \in \mathbb R \}## is a subset of (or equal to) ##\mathbb N##.
3e) Technical point: ##S## cannot be finite(!)
3f) Define ##\tilde f : S \rightarrow \mathbb R##, by ##\tilde f(n_r) = r## (or, if you prefer, ## \tilde f(n) = f(n)##.
3g) ##\tilde f## is a bijection from ##S## to ##\mathbb R##. Which is the required contradiction.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
