Does this hold in general ? (as an approximation only)
In summary, the conversation discusses the use of an approximation for the sum of exponential terms and its relation to the classical partition function. It is stated that this approximation may have limitations at low temperatures, but is generally effective for small values of the parameter 'a'.
tpm
72
Does this hold in general ?? (as an approximation only)
for every real or pure complex number 'a' can we use as an approximation:
[tex] \sum _{n} exp(-aE_{n}) \sim \int_{-\infty}^{\infty} dx \int_{-\infty}^{\infty} dp exp(-ap^{2}-aV(x)) [/tex]
So for every x V(x) > 0 in case of real and positive a ... then i would like to know if this approximation could be useful to describe the 'Semi-classical behaviour' of the sum over energies (trace) replaced by an integral.
What you've written is more or less the classical partition function. It has all manner of problems at low temperatures (i.e. a goes to infinity), but as long as a is very small, this approximation works okay.
I cannot give a definitive answer without further context and information about the specific system and approximation being considered. However, in general, using an integral to approximate a sum can be a useful tool in certain cases. It is commonly used in physics and other sciences to simplify complex systems and make calculations more manageable. However, whether this specific approximation holds in general will depend on the specific system and the range of values for 'a' and 'V(x)' being considered. More rigorous analysis and testing would be necessary to determine the validity and usefulness of this approximation.
FAQ: Does this hold in general ? (as an approximation only)
What does "holding in general" mean?
"Holding in general" refers to a concept or principle that applies to a wide range of cases or situations, rather than just a specific one.
Why is it important to consider whether something holds in general?
Considering whether something holds in general is important because it allows us to make generalizations and predictions based on a specific case or situation. This can help us better understand and explain the world around us.
What does it mean if something only holds as an approximation?
If something only holds as an approximation, it means that it is not entirely accurate or perfect. It may be a close or reasonable estimate, but it is not exact.
How do scientists determine if something holds in general?
Scientists determine if something holds in general by conducting experiments, collecting data, and analyzing patterns and trends. They may also use mathematical models and theories to make predictions and test if something holds true in various scenarios.
What are some examples of things that only hold in general?
Some examples of things that only hold in general include scientific laws and theories, statistical trends, and mathematical approximations. These concepts may not apply to every single case, but they are generally accepted as true and useful in explaining and understanding the world.
