Does this integral converge at $y=1$?
  • MHB
  • Thread starter karush
In summary, the conversation discusses the convergence of the integral $\int_{-\infty}^{0} \frac{1}{1+{x}^{2}}\,dx$ on the interval of $-\infty<x\leq0$. It is determined that the integral converges on this interval and that the asymptote of the function $\frac{1}{1+{x}^{2}}$ is $y=0$ as $x$ approaches $-\infty$. It is also noted that the integral has the same value when integrated from $-\infty$ to $0$ as it does from $0$ to $\infty$. The domain does not determine convergence, rather it is determined by how
karush
MHB
3,269
$\displaystyle
Due to the interval does this converge at $y=1$ ?
karush said:
$\displaystyle
You'll have to define y first. What is it?
-Dan
$a=-\infty $ $b=0$
$\displaystyle
\int_{a}^{b} \frac{1}{1+{x}^{2}}\,dx$
$x=\tan\left({\theta}\right)
\therefore dx=\sec^2{\theta} \, d\theta
\therefore \theta = \arctan\left\{x\right\}$
$\displaystyle
\int_{a}^{b}\frac{\sec^2{\theta}}{\tan^2\left({\theta}\right)+1}
=\int_{a}^{b}\frac{\sec^2{\theta}}{\sec^2{\theta}} \,d\theta
=\int_{a}^{b}1\,d\theta
=\theta$
backsubstute $a=-\infty $ $b=0$ $\theta = \arctan\left\{x\right\}$
$=\left[\arctan\left(x\right) \right]_{-\infty}^0
=\frac{\pi}{2}$
That's correct, but what is $y$ ?
$x=0,y=1$
But is that convergence
For $-\infty<x\le0$ ?
karush said:
$x=0,y=1$
Yes, the integral converges on \(\displaystyle (-\infty, 0] \).
But what is y supposed to be? (Crying)
-Dan
so you mean what $\frac{1}{1+{x}^{2}}$ approaches, not what it is at a point
as it goes to $-\infty$ it approaches $y=0$
So you are talking about the asymptote of the function 1/(1 + x^2). As x goes to - infinity then the asymptote is y = 0.
-Dan
Don't know, hope so🚬
If you are defining:
\(\displaystyle y(x)\equiv\frac{1}{x^2+1}\)
Then yes, we have:
\(\displaystyle y(0)=1\)
and:
\(\displaystyle \lim_{x\to\infty}y=0\)
However, the fact that the above limit is zero, is a necessary but not sufficient condition for the integral to converge. :D
The domain is $x\le 0$ would that make it converge or is that the wrong direction
I did write the limit incorrectly, but we could note that an implication of the even function rule is that:
\(\displaystyle \int_{-\infty}^{0}\frac{1}{x^2+1}\,dx=\int_{0}^{\infty}\frac{1}{x^2+1}\,dx\)
What makes it converge isn't the domain but rather how quickly the integrand approaches zero as $x$ increases.
FAQ: Does this integral converge at $y=1$?
What does it mean for a function to converge at y=1?
Convergence at y=1 means that as the independent variable of a function approaches a certain value, the output of the function approaches the value of 1.
How is convergence at y=1 different from a limit?
Convergence at y=1 is a specific type of limit, where the output of a function approaches a specific value (in this case, 1) as the input approaches a certain value. In general, a limit can approach any value, not just 1.
Can a function converge at y=1 for all values of x?
Yes, it is possible for a function to converge at y=1 for all values of x. This would mean that as x approaches any value, the output of the function approaches 1.
How do you determine if a function converges at y=1?
A function converges at y=1 if the limit of the function as x approaches a certain value (usually represented as lim f(x) as x-->a) is equal to 1. This can be determined using various techniques, such as algebraic manipulations or graphing the function.
What are some real-life applications of convergence at y=1?
Convergence at y=1 can be used in various fields such as economics, physics, and engineering. For example, in economics, it can be used to model the behavior of demand for a product as the price approaches a certain value. In physics, it can be used to describe the behavior of a system as it approaches equilibrium. In engineering, it can be used to analyze the stability of a system as it approaches a critical point.
