Does this physics homework problem make sense?
In summary, the problem involves a 0.85kg mass oscillating on a spring with a spring constant of 45 N/m. The angular frequency, force, acceleration, elastic potential energy, and kinetic energy were determined for when the object reaches a maximum position of 12 cm from equilibrium. The problem then asks for the velocity, force, acceleration, potential elastic energy, and kinetic energy at the maximum position and equilibrium position.
livblue23
A 0.85kg mass oscillating on a spring w/ spring constant of 45 N/m. How do i determine angular frequency?
A 0.85kg mass oscillating on a spring w/ spring constant of 45 N/m. This object reaches a maximum position of 12 cm from equilibrium. Determine:
a.) angular frequency of this mass
b.) force
c.) acceleration
d.) elastic potentional energy
e.) kinetic energy
Determine:
f.) velocity that it experiences at its maximum position.
Determine:
g.) force
h.) acceleration
i.) potential elastic energy
j.) kinetic energy
k.) velocity that it experiences at the equilibrium position.
okay so i got parts a through e, but for g through j... didnt i already answer those in b through e?
Hi livblue23,
b.) force
c.) acceleration
e.) kinetic energy
Determine:
Determine:
g.) force
h.) acceleration
j.) kinetic energy
I could be wrong (having the word Determine appear right before f is a bit confusing), but do they mean to evaluate b-f at the maximum position, and g-k at the equilibrium position?
There are two statements in the problem. a to e is related to the first statement. The rest for second statement. Try.
FAQ: Does this physics homework problem make sense?
1. How do I know if my physics homework problem makes sense?
There are a few ways to determine if your physics homework problem makes sense:
  • Check if the problem is solvable using the given information and equations.
  • Ensure that the units are consistent throughout the problem.
  • Double check your calculations and make sure they are logical.
2. What should I do if the physics homework problem doesn't make sense?
If the problem doesn't make sense, try breaking it down into smaller parts and understanding each component individually. You can also consult with your teacher or classmates for clarification.
3. Are there any common mistakes that can make a physics homework problem seem like it doesn't make sense?
Yes, some common mistakes that can make a physics homework problem seem like it doesn't make sense include using incorrect equations, not paying attention to units, and making calculation errors.
4. How can I improve my understanding of physics homework problems?
To improve your understanding of physics homework problems, it is important to practice regularly and fully understand the concepts and principles behind the equations. You can also seek help from your teacher or classmates if you are struggling with a specific problem.
5. Is it normal to struggle with understanding certain physics homework problems?
Yes, it is normal to struggle with understanding certain physics homework problems. Physics can be a challenging subject and it is important to seek help and practice regularly to improve your understanding.
