Does this problem make sense to anyone?
  • Thread starter Drew777
In summary, the uniform rod of 200cm length is in equilibrium when a 50 dynes downward force is applied at the center of gravity (100cm) and a 200 dynes upward force is applied at 185cm from the left end-point. The point of rotation is at 168cm from the left end-point.
Drew777
Uniform rod 200cm in legth is in equilibrium. An upward force of 200 dynes is applied 15 cm from the right edge. If the rod is 50dynes. At what pint will rod rotate about?
Just one of many
-50(100)+200(185)
-5000+37000
=32000
32000/150
= 213.33 ?
What am I missing? Please I need help.
Just one of many
-50(100)+200(185)
-5000+37000
=32000
32000/150
= 213.33 ?
Hi there! This sounds like a rotational equilibrium problem! Below is my rationale -
1) Set a horizontal axis zero point at the left end-point of the rod. Therefore, we have the center of gravity of the rod at 100cm, and we have the point of upward force at 185cm.
2) Set the point of rotation at location X, (i.e. X cm from the left end-point).
3) Given the system is at equilibrium, therefore the torque moving the rod at clock-wise direction (produced by upward lift force at 185cm), equals to the torque moving the rod at counter-clock-wise direction (weight of the rod, at the center of gravity, at 100cm). This is the foundation for setting the equation to solve for X.
4) Setting equations: Torque CW = Torque CCW
=> 50*(X-100)=200*(185-X)
=> X=168cm
FAQ: Does this problem make sense to anyone?
What do you mean by "this problem"?
When someone asks if a problem makes sense, they are usually referring to a specific issue or challenge that they are facing. It could be a scientific problem, a mathematical problem, or even a personal problem.
Why is it important to ask if a problem makes sense?
Asking if a problem makes sense is an important step in the problem-solving process. It allows us to identify any potential errors or misunderstandings early on and make necessary adjustments before investing more time and resources into finding a solution.
How do you determine if a problem makes sense?
The best way to determine if a problem makes sense is by breaking it down into smaller, more manageable parts. This will help you identify any gaps in your understanding or any missing information that may be needed to solve the problem.
What should I do if a problem doesn't make sense to me?
If a problem doesn't make sense to you, don't be afraid to ask for clarification or seek help from others. It's always better to address any confusion or uncertainty early on rather than wasting time and resources trying to solve a problem that doesn't make sense.
Is it possible for a problem to make sense to some people but not others?
Yes, it is possible for a problem to make sense to some people but not others. This could be due to differences in background knowledge, experience, or perspective. It's important to communicate and collaborate with others to find a shared understanding and approach to solving the problem.
