Does this solution make sense?
  • Thread starter supernova1203
In summary, the jet's speed from Bangkok to Tokyo was 800 km/h. The solution was found using the formula Distance=(speed)(time) and solving a quadratic equation with the given information.
supernova1203
210
The solution is at the bottom you can skip right to it if you like
1. Homework Statement
A jet flew from Tokyo to Bangkok, a distance of 4800 km. On the return trip, the speed was decreased by 200km/h. If the difference in the times of the flights was 2 hours, what was the jet's speed from Bangkok to Tokyo?
2. Homework Equations
Time=Distance/Speed
Speed=Distance/Time
3. The Attempt at a Solution
On sample questions they showed us how to solve a problem like this, i attempted to solve it in a similar manner however as you will see i was unable to
Let x represent speed
D=4800 Speed=? Time =?
Distance Speed Time
A to B 4800 x 4800/x (since time = d/s)
Tokyo
to Bangkok
B to A 4800 (x-200) 4800/(x-200)
Bangkok Since on return
to Tokyo trip speed was
reduced by 200
Time -2
4800/x +4800/(x-200)=-2
Lowest common denominator = x(x-200)
Here we multiply everything by x(x-200)
4800/x*x(x-200)+4800/(x-200)*x(x-200)=-2x(x-200)
Here some of the variable cancel out and the calculations are made and we are left
with the end result which is
4800x-960000+4800x=-2x(x-200)
4800x-960000+4800x=-2x^2+400x (On next step the 2x^2 and the right side is moved to
2x^2-400x+4800x-960000+4800x=0 the left side, hence the change in signs)
2x^2-400x+4800x+4800x-960000=0
Basically at this point my calculations got sketchy because there were several ways of going about this problem at this point, also I believe i had made some errors early in my calculations.
I was able to solve this however i should give credit where credit is due
I would like to thank:
sjb-2812 (For fixing the -2x^2 to what it should be which is 2x^2 without the negative)
Apphysicist
zgozvrm
Solution
D = distance
S=speed
T=time
d=st
t=d/s
s=d/t
let x represent the speed
(x-200) because on the return trip the speed was reduced by 200
Distance Speed Time
A to B
(Tokyo 4800 x 4800/x
to Bangkok)
(Bangkok
to Tokyo)
Total 2
4800/(x-200) - 4800/x = 2
LCD is x(x-200)
4800/(x-200)*x(x-200)-4800/x*x(x-200)=2x(x-200)
the two (x-200) cancel out here as well as the 2 x's cancel out
4800x-4800(x-200)=2x(x-200)
4800x-4800x+960000=2x^2-400x
960000=2x^2-400x
=2x^2-400x-960000
2(x^2-200x-480000)
Standard form-------> =(x^2-200x-480000)
a=1
b=-200
c=-480000
Quadratic equation here
-b+-Sqrt b^2-4ac/2a
-b+sqrt b^2-4ac/2a
-(-200) + sqrt (-200)^2-4(1)(-480000)/2(1)
+200 + sqrt 40000-4(-480000)/2
+200 + sqrt 40000 + 1920000/2
+200 + sqrt 1960000/2
200+1400/2
1600/2
x^1=800
x^2
-b-sqrt b^2 - 4ac/2
200-1400/2
-1200/2
=-600
x^2=-600
Since x^2 does not make sense because its a negative, it is logical to conclude the solution is x^1, which is x=800
Therefore the speed of the jet from Bangkok to Tokyo was 800km/h
Related to Does this solution make sense?
1. What is the purpose of asking if a solution makes sense?
Asking if a solution makes sense is important because it allows for critical evaluation of the proposed solution and ensures that it is logical and feasible.
2. How do you determine if a solution makes sense?
A solution can be deemed sensible if it addresses the problem at hand, takes into consideration all relevant factors, and can be realistically implemented with the resources available.
3. Are there any specific criteria for determining if a solution makes sense?
Yes, a solution should be practical, cost-effective, and ethical. It should also align with any existing laws or regulations.
4. Is it possible for a solution to make sense in some situations but not in others?
Yes, a solution may make sense in one scenario but not in another depending on the specific context and variables involved.
5. Can a solution that makes sense still fail?
Yes, even if a solution makes sense, there is still a possibility of failure due to unforeseen circumstances or external factors beyond control.
