Does this theorem “theoretically” falsify macrorealism?
However, it does provide conditions for testing macro-realism through empirical means, such as Leggett inequalities. Essentially, the paper suggests that it is impossible to prove one way or the other whether macro-realism is true, but some theorems may suggest the likelihood of non-realism. This can be a complex topic, so it is best to continue studying QM to avoid misunderstandings. Some recommended resources for further study are Susskind's books and a calculus book.
Daria K
Hello!
Recently I found this article: http://quantum-journal.org/papers/q-2017-07-14-13/pdf/
Being familiar with some basis of quantum formalism, I, nevertheless, experienced several difficulties with understanding of the theorem described in this paper. I would really appreciate if someone could tell me does this theorem really disprove some types of macrorealism or it only provides the conditions for empirical tests of macrorealism (like Leggett inequality)? I could metaphorically rephrase my question: "Does this no-go theorem prove, that the moon is not there when nobody looks?"
I understand, that this question is based on my layman concepts, and everything is much more deep and complex, but I really need your help.
Thank you in advance!
Likes davidge
I had a scan.
I am a realist agnostic myself believing in the ensemble interpretation which doesn't specify an exact position regarding that one way or the other, but the paper says it all even in layman terms. It clearly states its impossible to prove one way or other. All that has happened is some people have come up with some theorems that suggest to them (ie via a certain point of view they have) that non-realism is more likely.
That's fine if you are into that sort of thing - but its an advanced area not really suitable for a beginner.
As a beginner you are better off learning real QM and making up your own mind. I suggest, if you actually want the real deal, not pop-sci accounts, Susskind's books:
https://www.amazon.com/dp/0465075681/?tag=pfamazon01-20
https://www.amazon.com/dp/0465062903/?tag=pfamazon01-20
If you need to brush up on calculus:
https://www.amazon.com/dp/0471827223/?tag=pfamazon01-20
Regardless of if you are a realist or not rest assured the moon is there if you look or not because its always in contact with its environment eg the Cosmic Background Radiation. Via the process of decoherence it basically means that macro objects like the moon behave classically, part of which is being there if you look or not - intuitively its being looked at and is entangled with the environment all the time. So you run into the issue of exactly what is a macro object since those around us are entangled with the environment - that's the issue for approaches like the paper you posted. Now if you want to find out if a macro object totally isolated from an environment has classical properties how would you do it? Why you would have to interact with it in some way so it no longer isolated is it? So in a certain sense its a bit, well I won't say pointless, but rather academic. Still it's a legit area of investigation. Micro objects like say an electron is another matter. The borderline between the two is a very interesting thing as well leading to some very strange effects eg look up buckyballs.
Thanks
Bill
Likes vanhees71
Dear Bill,
Thank you very much for your answer. Maybe my confusion appeared because I interpreted the macro objects with "macro properties" in this paper as not isolated from their environment. Also I thought that we can rule out macrorealism only empirically, for example, by violating Leggett-Garg inequalities, but in this theorem there is nothing to "violate".
The best decision, I think, is to continue studying QM in order not to fall into such misunderstandings again. That is why I am grateful for the resources you mentioned.
Daria.
As they say in the paper, their theorem does not rule out all types of macro-realism, such as that provided by Bohmian mechanics.
Related to Does this theorem “theoretically” falsify macrorealism?
1. What is macrorealism and how does it relate to this theorem?
Macrorealism is a physical theory that suggests that objects have definite properties and exist independently of observation or measurement. This theorem, also known as Bell's theorem, challenges the assumptions of macrorealism by showing that certain predictions made by the theory are incompatible with the laws of quantum mechanics.
2. How does this theorem impact our understanding of reality?
This theorem has significant implications for our understanding of reality, as it suggests that the laws of quantum mechanics are fundamentally at odds with the assumptions of macrorealism. This means that our traditional understanding of how objects exist and behave in the physical world may need to be reevaluated.
3. Can this theorem be tested experimentally?
Yes, this theorem has been tested experimentally through a series of experiments known as Bell tests. These tests have consistently shown that the predictions of quantum mechanics are correct, providing further evidence against the assumptions of macrorealism.
4. Are there any alternative explanations for the results of this theorem?
There have been attempts to explain the results of this theorem through alternative theories, such as local hidden variable theories. However, these theories have not been able to fully explain the experimental results and are considered less likely than the implications of quantum mechanics.
5. How does this theorem impact the future of scientific research?
This theorem has opened up new areas of research and inquiry in physics. It has spurred further investigations into the nature of reality and has challenged scientists to rethink their assumptions about the physical world. It will continue to be a topic of interest and discussion in the scientific community for years to come.
  • Quantum Physics
  • Quantum Physics
19K
  • Quantum Interpretations and Foundations
19K
9K
