Does time dilation occur between comoving galaxies?
In summary: As an astronomer observes a galaxy, which is receding, does time dilation occur between the two comoving galaxies? If so, which (rf) is (t) longer in, as observed here on Earth (Our local Milkyway galaxy or the remote galaxy)?The answer to this question is difficult to determine, as it depends on the definition of "time" and "cosmological time". According to one definition, cosmological time is the time measured by an observer who is outside of the universe. In this case, the two galaxies would have different cosmological times, and the galaxy that is receding would be time-dilated.However, another definition of time allows for the same universe
eugene pletcher
As an astronomer observes a galaxy, which is receding, Does time dilation occur between the two comoving galaxies? If so, which (rf) is (t) longer in, as observed here on Earth (Our local Milkyway galaxy or the remote galaxy)? Thank you.
Space news on Phys.org
It is certainly true that if we were to look at a clock in a far-away galaxy that has a high redshift, the image that we see of that clock would move more slowly than a clock here on Earth (by an amount exactly proportional to the amount the wavelength has been increased by the redshift.
But how much of that is due to time dilation and how much is due to perspective effects is up to interpretation.
Thanks Chalnoth,
What about velocity, due exclusively to cosmic expansion?
In order to talk about time dilation at all you need to define a set of simultaneous surfaces in space time. In special relativity there is a canonical choice and so it is the one we use. In GR this often is no longer the case, although in standard cosmology we would often use comoving time. With that choice the answer is no, there will not be any time dilation between comoving galaxies with respect to comoving time simply because the comoving time is defined as the time for a comoving observer.
If you select a different set of simultaneous surfaces, the answer may be different. This is also apparent in SR as selecting the simultaneities of a different observer will lead to the original observer being time dilated instead. As Chalnoth said, what you call "time dilation" is largely a matter of interpretation and thinking about it more I have started thinking it is unfortunate that it is presented the way it is even in SR. Both length contraction and time dilation have been the source of a mountain of misunderstanding, students tend to try to apply it to everything and do not realize that there are requirements in order to use the simple formula with the gamma factor conversion.
Likes strangerep
Thanks Chalnoth,
Again, that's not an easy question to answer. The problem is that the velocity of a far-away object is not a well-defined quantity in General Relativity. You can subtract velocities at a single point, so that the question, "What is the velocity of object X that just passed me, relative to me?" is well-defined. But a far-away galaxy isn't so easy.
In the end, usually people working with General Relativity tend to limit the questions they ask to directly-observable questions. For example, the redshift is a directly-observable quantity. But "time dilation" is not: time dilation is an abstract concept that is well-defined in special relativity, but isn't a directly-observable quantity, and doesn't generalize well to curved space-time.
Hmm, why not? It seems I'm missing something . Isn't the cosmological time dilation well defined due to its cause, the increase of the scale-factor? To my understanding we observe any phenomenon happening in a far away galaxy, e.g. the duration of a supernova, slower compared to the same phenomenon nearby, which correlates to the increase of the scale-factor during the time of emission and absorption.
I think you are misinterpreting what "time dilation" is. It is not the fact that we see other clocks ticking slower, it is a question of the proper time of different observers between two different simultaneities. What you are talking about is more related to redshift, which is not the same thing as time dilation (a light source moving towards you will be blue-shifted, even if it is moving and therefore time-dilated).
Likes timmdeeg
Ah, got it, I was wrong. Thanks for your good explanation!
FAQ: Does time dilation occur between comoving galaxies?
1. What is time dilation?
Time dilation is a phenomenon in which time appears to pass at a different rate for objects in motion relative to each other. This is a consequence of the theory of relativity, which states that time and space are relative and can appear differently to observers in different frames of reference.
2. How does time dilation occur?
Time dilation occurs because of the relationship between space and time in the theory of relativity. As an object moves faster, it experiences a "slowing down" of time relative to a slower-moving object. This effect becomes more pronounced as the speed of the objects approaches the speed of light.
3. Does time dilation occur between comoving galaxies?
Yes, time dilation does occur between comoving galaxies. Comoving galaxies are galaxies that are moving away from each other at a constant rate due to the expansion of the universe. As they move away from each other, they experience a relative increase in speed and therefore experience time dilation.
4. How does time dilation affect our perception of time between comoving galaxies?
Due to the effects of time dilation, our perception of time between comoving galaxies would be different from the actual time experienced by objects in those galaxies. This means that if we were to observe events in those galaxies, they would appear to happen at a slower rate than if we were observing them from a non-moving frame of reference.
5. Is time dilation a proven phenomenon?
Yes, time dilation has been proven through numerous experiments and observations, including the famous Hafele-Keating experiment and observations of high-speed particles in particle accelerators. The effects of time dilation have also been confirmed by GPS satellites, which must account for time dilation in order to maintain accurate time measurements.
