Does time expand along with space?
In summary, the conversation discusses the expansion of space and time in the context of the flat FRW metric. It is mentioned that the proper distance between comoving points scales with ##a(t)##, indicating that space expands. However, when considering the time dilation effect, it is clarified that it is the wavelength of light that expands with ##a(t)##, not time intervals themselves.
jcap
170
Sorry to go on about this topic. I'll get it out of my system soon!
The flat FRW metric is given by:
$$ds^2=-c^2dt^2+a(t)^2dr^2$$
If we take ##dt=0## then we get:
$$ds=a(t)\ dr$$
The proper distance between co-moving points scales with ##a(t)##. Thus we find that space expands.
If we take ##ds=0## to find the null geodesic followed by a light beam we get:
$$c\ dt=a(t)\ dr$$
Surely this implies that cosmological time intervals expand in the same way as space intervals?
Space news on Phys.org
This implies ## dt=\frac{c}{a(t)}dr ##, which is a useful relation but says nothing of "time expansion".
If ##\tau## is the proper time of a comoving observer, and ##\delta## the distance in his reference frame to another comoving object situated at comoving distance ##r##,
##\quad\tau=t## (no time expansion)
##\quad\delta=a(t)r## ("space expansion")
But you may be referring to the time dilation effect when this observer looks at a comoving source. Light emitted by that source at ##t## and ##t+dt## is received at ##t'## and ##t'+\frac{dt}{a(t)}## because the second pulse was emitted from a more distant source than the first - this is actually the same thing as the redshift ot a distant source due to expansion.
No, it implies that the wavelength of light expands with ##a(t)##--i.e., that the light gets redshifted as the universe expands, as wabbit said.
Related to Does time expand along with space?
1. Does time expand along with space?
According to Einstein's theory of relativity, time is a fundamental component of space-time and is affected by gravitational forces. Therefore, time can also be affected by the expansion of space, but it does not expand in the same way.
2. How does the expansion of space affect time?
The expansion of space affects time by causing time dilation, which means that time passes slower in regions with stronger gravitational forces. This can also be observed in the expanding universe, where the rate of expansion affects the perception of time.
3. Is time expanding at the same rate as space?
No, time and space do not expand at the same rate. While space is constantly expanding, time is not expanding in the same way. Time is a constant in our universe and is not subject to expansion in the same way that space is.
4. Can the expansion of space be observed by looking at time?
Yes, the expansion of space can be observed by looking at time. Scientists use cosmological observations, such as redshift and supernovae measurements, to study the expansion of the universe and its effect on time.
5. Does the expansion of space affect the flow of time?
Yes, the expansion of space can affect the flow of time. As space expands, the distance between objects increases, which can cause time to pass slower in those regions. This is known as time dilation and has been observed in the expanding universe.
  • Cosmology
