Does topology distinguish between real and imaginary dimensions?
In summary, the conversation discusses the concept of topology and its relationship to objects in different 3D spaces, specifically donut-shaped objects. The question is whether these donuts, despite having different equations and properties, would be considered the same object in topology due to the connectedness of their dimensions. However, there is confusion over the use of "imaginary dimensions" and whether they exist. The conclusion is that topology only considers the number of dimensions and any objects that can be transformed into each other through a continuous function are considered identical.
Feynstein100
171
Let's say we have four 3D spaces: (x, y, z) , (x, y, iz) , (x, iy, iz) and (ix, iy, iz), with i being the imaginary unit. Now, let's say we have a donut in each of these spaces. Geometrically, the donuts are different objects, have different equations and different properties (I think) but would they be considered the same object in topology?
I want to say no because topology deals with connectedness and if the dimension is different, then that should mean that objects in different spaces would be connected differently. However, I'm not sure. Could someone weigh in perhaps?
Likes ohwilleke
I would say that topology needs "I" level thread not "B", and I don't think your questions can be answered at the desired level. More importantly you cannot ask them correctly at "B" level. It would be very difficult to unwind you post and point out all the inacuracies. For example what exactly are the four spaces in you first sentence?
Thank you for the reply. I've changed the level to "I" according to your suggestion.
The four spaces I mentioned are just 3D versions of what would be the real plane (x,y) and the complex plane (x,iy). I was gonna go with the 2D version but then I wouldn't get the donut 😂 So I decided to make them 3D. But yeah, other than that, they're just 3D planes, if that makes sense.
This is what I had in mind when I meant "space", with an increasing number of the axes being imaginary.
I wasn't suggesting that. I was suggesting that you don't have the background for what you want to ask.
The real plane and the complex plane are the same topological space. So your four spaces are really just one.
Likes PeroK and ohwilleke
Oh 😅
Well, that seems to be my answer. Topology doesn't distinguish between real and imginary dimensions. It's only the number of dimensions that matters. Hmm but why?
Likes ohwilleke
Feynstein100 said:
Oh 😅
There is no such thing as imaginary dimension. Where did you get it from?
Likes PeroK and DaveE
Wait, there isn't? What about the complex plane then? One of the axes there is imaginary, right?
I'd say too, that it depends on the choice of embedding of the Torus/Donut. Are you using the "Standard" ## S^1 \times S^1## ? Maybe you want to identify the embeddings up to , what , homotopy, isotopy, etc? But I agree with Martin that it's not clear what imaginary axes are. Ultimately, ix, iy, iz would be interpreted as the respective ##x,y,z ## axes rotated by ## \pi/2 ##. Is that what you meant? If so, rotations are homeomorphisms ( here automorphisms), which would thus have no effect in the underlying topology of the space(s). I mean, is , say , ix,y,z, the space resulting of rotating the x-axis by ##\pi/2 ##, while leaving the other axes fixed?
So, ultimately, not sure your question is well-posed enough to be given a meaningful answer.
Likes DaveE, ohwilleke and Feynstein100
My idea was that if such axes existed, then a number would be represented by them as, e.g., ax+byi +cyi +dz, etc.
Not aware of any such thing.
As I understand topology, any two objects that can be transformed to each other by a continuous function are 'identical' in the sense that their images can be superimposed on each other. If you can write a function that maps one of your tori one-to-one onto another one, then the two are topologically identical.
Likes ohwilleke
True, though you need a bit more, your functio must be both onto ad its inverse must be continuous as well.
The real plane and the complex plane are really the same thing. It's just different notation. Complex numbers are very useful for cyclic phenomena like wave forms, but anything you can do with complex numbers can also be done with real numbers. It might be clumsy and verbose, but it can be done.
  • Skeptical
Likes PeroK, DaveE and ohwilleke
Wait then how do you make sense of the complex plane? Isn't i different from real numbers and thus should be treated as such? I thought the whole point of the complex plane was to illustrate that real and imaginary numbers are independent of each other. Which is why they are represented by different axes. It's kind of what an axis means, I think? That things on it are independent of other axes.
I'm having a hard time wrapping my head around this. I've been treating them as different my entire life
I thought they showed that real and complex hilbert space formulations of QM could give different results a couple of years ago.
Likes Feynstein100
Topologically they are the same. Why do you think they are not?
Likes ohwilleke
Well, you have your Real and Imaginary axes, snd you can represents a number as## a+ib## So there's a correspondence between the Complexes## a+ib ## and the Real , imaginary axes. But Im not aware of any mathematical object that's written as a function, combination of terms of the form ##a*ix+b*iy+c*iz##, nor any of the other combinations you propose. Similarly, polar/cylindrical/spherical coordinates would correspond to axes indexed by ##(r,\theta);( r ,\theta , \rho)##, etc.
Edit: So , you have a correspondence between coordinate systems and axes. Im not aware of any coordinate systems that warrants your choice of axes.
I think real and complex plane are are both two dimensional spaces and geometrically the same. The difference comes from their algebraic structures, which are different. Two dimensional vector space does not have the same multiplication as complex plane has and vice versa, you don't see dot or cross products defined for complex plane either.
Likes PeroK and Feynstein100
Yes, Complex numbers are an Algebra, while ## \mathbb R^2## is not, but rather, as you stated, a vector space, albeit one with a topology, i.e., a Topological Vector Space.
That sounds really interesting. Could you maybe share a link for it? I'd like to learn more
Because of this ^
That sounds interesting but I didn't really understand it. Would you mind elaborating a bit? Sorry 😅
Wow, this sounds very interesting. I didn't know spaces could have algebraic structures too. Would you mind telling me more about it?
Also, this opens new possibilities. Like, could 2 objects that are the same geometrically be different algebraically? 🤔
Hmm so what's the difference between an algebra and a vector space? Sorry I'm a total noob 😅
Do you know what topology is?
Here you go. The technical papers are referenced if you want to go deeper.
https://physics.aps.org/articles/v15/7
Likes Feynstein100
What do you think a vector space is, for example? Have you studied abstract algebra?
@Pikkugnome gave you an example in his/her post.
vela said:
What do you think a vector space is, for example? Have you studied abstract algebra?@Pikkugnome gave you an example in his/her post.
Idk a vector space is like a field but for vectors? 😅
I don't know much maths. I see it like this. You can have a flat plain without anything else. You can imagine geometric objects on it: circles, lines, ... . If you add coordinates to the plane, then you can say about the objects more. They have coordinates now and might reveal new things about the objects you didnt notice before. You define distance to the plane. Then you can say that points of a circle are equidistant from one coordinate point the center of the circle. I like to think that new structures you define gives you an ability reveal new things about the plane or its objects.
Real plane and complex are to me two different points of view of the same thing. You just try to look it in a different way.
Are you a high school student? It's great to be enthusiastic about learning more complicated math, but skipping ahead to concepts you don't understand at all will harm your development. If you really want to understand this question you should start by learning linear algebra, and what a metric space is.
  • #31
Maybe if the OP can give us a few examples of what s/he wants to do, we can figure out and suggest something.
  • #32
Heuristically, "real" and "imaginary" dimensions ought to be the same because "imaginary" dimensions are those involving a real number times the square root of negative one in each dimension. But the designation of something as positive or negative is a purely arbitrary choice of units.
For example, if you are dealing with electromagnetic charge, the fact that an electron has a negative one charge, and a proton has positive one charge is purely an arbitrary assignment of directions on the real number line and could have been different with a different arbitrary assignment of units. So, nothing "physical" should depend upon how positive v. negative units are assigned.
Likes WWGD
  • #33
Thank you for the analogy. I found it really helpful. However, I think you misunderstood me. In the proton vs electron example, I'm not arguing that one should be labeled positive and the other negative. That's completely arbitrary and simply a matter of choice. What I am saying, however, is that the proton and electron have different charges and thus should be treated as such. To me, saying that real and imaginary numbers are same is like saying the proton and the electron have the same charge. Or worse, that they're the same particle. Might as well take an apple and an orange and say they're the same fruit. I don't care what you call each fruit, as long as you acknowledge that they're different fruits and give them different names.
I'm sorry, I'm feeling quite frustrated. I recently learned that I have autism and one of the consequences of having autism, apparently, is that I can distinguish between things where non-autistic people cannot. I treat things individually instead of making generalizations. I thought that in a forum full of physicists, most of whom are likely autistic like me, I'd find sympathetic ears. And yet, I feel just as different and alien as always.
Not that I'm saying I'm better than everyone else. It's just that I feel like I'm trying to describe the difference between colors to someone who's colorblind. It makes me wish I was colorblind too.
  • Skeptical
Likes PeroK
  • #34
The thing is that if you reverse the positive and negative charges of the proton and electron, then equations involving the square root of proton charges will now be in the imaginary plane, while equations involving the the square root of electron charges will now be in the real plane.
As you correctly posed the question in the first place, it isn't that real numbers and imaginary numbers are the same. But, they have the same topology.
You can, in general, map points in the real plane to the imaginary plane on a one to one basis. You can likewise map points in the imaginary plane to the real plane on a one to one basis.
  • #35
I'm sorry to disabuse you of the notion that you are seeing deeply into mathematics. You are seeing far less than those of us with mathematical training. You lack a basic understanding of abstract mathematical concepts. Your question about "real" and "imaginary" dimensions misses the point about how real and complex numbers relate to each other mathematically.
The real plane ##\mathbb R^2## and the complex plane ##\mathbb C## are isomorphic when considered as real vector spaces. I.e. vector spaces over ##\mathbb R##. In this case, we are simply considering a complex number (vector in the complex plane) as an ordered pair of real numbers with no further structure or properties.
The complex plane, however, is usually considered not as a real vector space, but an algebraic field. That is to say, we define multiplication of complex numbers, which (as @Pikkugnome has pointed out) distinguishes ##\mathbb C## from ##\mathbb R^2##.
Note that a set in mathematics can be given algebraic and/or analytic structure. This means that the same underlying set can be the basis of different mathematical objects. Algebraic generally refers to addition and/or multiplication and analytic refers to properties of some fundamental notion of distance or length. Ultimately, leading to the notion of analytic topology underpinned by the notion of a collection of open sets.
It's perfectly acceptable, therefore, to see both ##\mathbb R^2## and ##\mathbb C## as built on the same underlying set of ordered pairs of real numbers. The difference is that ##\mathbb C## is endowed with a rule for multiplication that produces a closed field.
If you introduce the same multiplication rule for ##\mathbb R^2##, then you do not create a new, distinct mathematical object, but simply ##\mathbb C## in a different notion. This is called an isomorphism. And, to claim that this somehow avoids introducing complex numbers misses the point. You have created an object with the same properties as the complex numbers and have the complex numbers in all but name.
In fact, an interesting and sometimes useful isomorphism of the complex numbers is to a subset of real ##2 \times 2## matrices:
$$a + ib \leftrightarrow
\begin{bmatrix}
a& b\\
-b&a
\end{bmatrix}$$Finally, if we define distance between two points in ##\mathbb R^2## by the usual Euclidean metric:$$|(x_1, y_1) - (x_2, y_2)| \equiv \sqrt{(x_1 - x_2)^2 + (y_1 - y_2)^2}$$And we define the distance between two compelx numbers as$$|z_1 - z_2| = \sqrt{(z_1 - z_2)(z_1 - z_2)^*}$$Then, purely as simple topological spaces, the two are isomorphic.
However, when we look at complex-valued functions of a complex variable, we move into complex analysis, which has no analogue in real analysis or multi-dimensional real vector spaces.
Likes Feynstein100, ohwilleke and martinbn
<H2>1. What is topology?</H2><p>Topology is a branch of mathematics that studies the properties of geometric objects that remain unchanged under continuous transformations, such as stretching, twisting, or bending.</p><H2>2. What is the difference between real and imaginary dimensions?</H2><p>In mathematics, real dimensions refer to the dimensions we experience in our physical world, such as length, width, and height. Imaginary dimensions, on the other hand, are abstract concepts used in certain mathematical models to describe phenomena that cannot be observed in the physical world.</p><H2>3. How does topology distinguish between real and imaginary dimensions?</H2><p>Topology does not distinguish between real and imaginary dimensions. It is a mathematical tool that can be used to study both real and imaginary dimensions, as well as their interactions.</p><H2>4. Can topology be used to visualize imaginary dimensions?</H2><p>Topology can provide a framework for understanding and visualizing abstract concepts, including imaginary dimensions. However, since imaginary dimensions cannot be directly observed, their visualization is limited to mathematical models and representations.</p><H2>5. How is topology applied in science?</H2><p>Topology has various applications in science, including physics, biology, and computer science. It can be used to study the properties of complex systems, analyze data, and model real-world phenomena. In physics, topology has been used to explain the behavior of materials and particles, while in biology, it has been used to study the structure and function of biological systems.</p>
FAQ: Does topology distinguish between real and imaginary dimensions?
