Does warm air rise or does cold air sink?
In summary, the conversation discusses the concept of warm air rising and cold air sinking, with one person arguing that this is incorrect and instead the opposite is true. They explain that this phenomenon can be observed with a hot air balloon and when opening a refrigerator. Both processes occur simultaneously due to the Rayleigh-Taylor Instability. The stability of a configuration of cold air on top of warm air also depends on the temperature gradient. The conversation ends with an analogy of a heavy and light person on a seesaw.
somega
32
I have a friend and he complained that at school they are teaching that warm air rises.
He said it's wrong. He said instead the cold air sinks.
Is this true?
What is the difference? What sort of experiment could be used to determine the difference between the two propositions
Likes russ_watters, Chestermiller and Ibix
Two ways of saying the same thing, really.
Likes Dale
Place a mass of air in air that is cooler and it rises. That is why a hot air balloon rises. Warmer air is less dense than cooler air. Conversely a mass of cool air will sink if place in air that is warmer. This is easily experienced when you open a refrigerator and feel the cool air on your legs first.
Both things happen at the same time. If you have some hot air rising, it is displacing cold air which has nowhere else to go but down. So hot air rising is always accompanied by cold air sinking.
Likes VVS2000, Vanadium 50, anorlunda and 2 others
It's the Rayleigh-Taylor Instability. Here is a visualization:
Edit: Just for the sake of completeness: A configuration of cold air on top of warm air can be stable if the temperature gradient doesn’t exceed the adiabatic lapse rate. The best example is the atmosphere.
Likes VVS2000 and Bystander
Does the heavy person at one end of a see saw sink or does the light person at the other end rise?
Likes anorlunda and Vanadium 50
Related to Does warm air rise or does cold air sink?
1. Does warm air rise or does cold air sink?
Warm air rises and cold air sinks. This is due to the difference in density between warm and cold air. Warm air is less dense and therefore lighter, causing it to rise. Cold air is more dense and heavier, causing it to sink.
2. Why does warm air rise?
Warm air rises because it is less dense than cold air. As the air is heated, the molecules spread out and take up more space, making the air less dense. This lighter air then rises above the denser, colder air.
3. Does cold air always sink?
Yes, cold air always sinks. This is because cold air is more dense than warm air. The denser air sinks below the less dense air, creating a circulation pattern known as convection.
4. What is the role of temperature in air movement?
Temperature plays a crucial role in air movement. As mentioned before, warm air is less dense and rises, while cold air is more dense and sinks. This creates a convection cycle, which is responsible for many weather patterns and phenomena.
5. How does the movement of warm and cold air affect weather?
The movement of warm and cold air greatly affects weather. When warm air rises, it cools and condenses, forming clouds and precipitation. Cold air sinking can bring drier conditions. The interaction between warm and cold air masses is responsible for the formation of many weather systems and patterns.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Other Physics Topics
  • Earth Sciences
