Does Watt's Law apply to flowing water in a pipe?
The discussion explores whether the heat generated by flowing water in a pipe is proportional to the product of the flow rate and the pressure drop, similar to an electrical circuit. It establishes that if the system is at steady state and insulated, the change in specific enthalpy is zero, leading to a relationship between temperature change and pressure drop. The equation derived shows that the heat generated can be expressed in terms of mass flow rate and specific heat capacity. The analogy to electrical circuits suggests that flow rate corresponds to amperes and pressure drop to volts. Overall, the relationship indicates that heat generation in flowing water can be quantified similarly to electrical power.
Jack of some trades
Is the heat generated by flowing water in a pipe proportional to the product of the rate of flow and the pressure drop across the section of pipe in question, analogous to an electrical circuit? If so, what units would you plug into get an answer in watts?
If the flow is at steady state and the pipe is insulated, then then change in specific enthalpy of the water is zero. So, $$C_p\Delta T+v(1-\alpha \bar{T})\Delta P=0$$where ##\alpha## is the volumetric coefficient of thermal expansion, ##C_p## is the specific heat capacity, v is the specific volume of the water and ##\bar{T}## in the second term is the average temperature in the pipe (that doesn't change much). So, the change in temperature from inlet to outlet is $$\Delta T=\frac{v(1-\alpha \bar{T})(-\Delta P)}{C_p}$$
If you imagine that the "heat generated" is ##\dot{m}C_p\Delta T## where ##\dot{m}## is the mass flow rate, then$$\dot{m}C_p\Delta T=\dot{m}v(1-\alpha \bar{T})(-\Delta P)=(1-\alpha \bar{T})\dot{V}(-\Delta P)$$,where ##\dot{V}## is the volumetric flow rate.
Likes vanhees71, Delta2 and Dale
Jack of some trades said:
Summary:: Is the heat generated by flowing water in a pipe proportional to the product of the rate of flow and the pressure drop?
This seems to be a correct statement (we do not want to confuse Temperature with Heat). With the electrical analogue I think the flow rate would be Amperes and the pressure drop Volts.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
