Does work energy theorem fail while dealing with friction?
In summary: The real work done by friction is difficult to calculate. But if you're only interested in mechanical energy and rigid bodies that can be treated as particles (as is usually the case in intro physics courses), then friction X displacement does correctly describe the change in kinetic energy of the body.
NoahCygnus
96
Let's consider a setup consisting of a table with friction, and a block on top of it. Suppose we drag the block across the table with a constant speed. The applied force ##f_{app}## acting through a distance ##d## does a work ##f_{app}d##. The frictional force ##\mu N## is equal to ##f_{app}## since there is no acceleration. So the total work done on the block by these external forces will be ##\Sigma W = W_{app} + W_{friction} = F_{app}d - f_{Kinetic Friction}d = 0##
According to law of conservation of energy, if there is an energy change in the system , it is because the energy is being transferred across the system boundary by a transfer mechanism (work, heat, mechanical waves, matter transfer, electromagnetic radiation etc.)
So, ##\Delta E_{system} = \Sigma T##, where ##\Delta E_{system} = \Delta K + \Delta U + \Delta E_{internal}## and ##\Sigma T## is an energy transfer mechanism.
In our case, we have ##W_{app} + W_{friction} = \Delta K + \Delta U+ \Delta E_{internal} ##, as work is the only mechanism of transfer of energy. Also ##\Delta K = 0## as there is no change in speed and ##\Delta U = 0##. Then ##W_{app} + W_{friction} = \Delta E_{internal} ## , but as ##W_{app} + W_{friction} = 0 \Longrightarrow \Delta E_{internal} = 0## So that means there is no increase in the internal energy, but clearly the block heats up. Can anyone explain to me what's happening here?
The work energy theorem assumes a rigid body. A rigid body cannot heat up since it has no internal degrees of freedom. In your example, it is only the table that heats up.
If work energy theorem assumes a rigid body, and the points of contact between the block and table deform rendering work energy theorem useless, then why do we say work done by kinetic friction on a body for a displacement ##d## is ## W = -f_{kinetic}d##? Shouldn't the work done by kinetic friction be incalculable as the points of contact get deformed locally?
I wouldn't say it is useless. It is useful for describing the mechanical energy. It just doesn't describe thermal energy. If you are interested only in the mechanical energy then it makes calculations very easy.
Lots of physics is like that.
Likes NoahCygnus
You can extend the "Work"-energy theorem to non-rigid bodies by introducing 'center of mass' work (or pseudo-work). It makes some calculations of mechanical energy very easy (in line with what Dale said above).
You can read more about it in this thread: https://www.physicsforums.com/threads/work-done-by-friction.732127/
Likes NoahCygnus
What I don't understand is why do we say work done by frictional force on something is ##W_{friction} = -fd## for a displacement ##d## if frictional force is not concentrated on a single point , and is distributed over the entire contact area. The individual contact points should deform so how did we come to the result ##W_{friction} = -fd## ?
The real work done by friction is difficult to calculate. But if you're only interested in mechanical energy and rigid bodies that can be treated as particles (as is usually the case in intro physics courses), then friction X displacement does correctly describe the change in kinetic energy of the body. But you are correct, that it is not really a true "work" (as in conservation of energy).
Bruce Sherwood wrote a classic paper that I think directly addresses your concerns. Here it is: Work and heat transfer in the presence of sliding friction (Linked from Prof Sherwood's website.)
Likes Dale and Nugatory
Related to Does work energy theorem fail while dealing with friction?
1. Does work energy theorem apply to systems with friction?
Yes, work energy theorem applies to systems with friction. However, it may need to be modified to account for the work done by friction.
2. Can work energy theorem be used to calculate the work done by friction?
No, work energy theorem cannot be used to directly calculate the work done by friction. It only considers the work done by non-conservative forces, such as friction, as a reduction in mechanical energy.
3. How does work energy theorem account for the work done by friction?
Work energy theorem accounts for the work done by friction by including it as a negative term in the total work done on a system. This means that the work done by friction reduces the total work done on a system, resulting in a decrease in mechanical energy.
4. Is work energy theorem still valid in the presence of friction?
Yes, work energy theorem is still valid in the presence of friction. However, it may require additional considerations and modifications to accurately describe the motion of a system.
5. Does work energy theorem fail in the presence of friction?
No, work energy theorem does not fail in the presence of friction. It is a fundamental principle in physics and can be applied to systems with friction, as long as the appropriate modifications are made to account for the work done by friction.
  • Mechanics
