MHB Doesn't it suffice to pick the limit of the sequence?
  • Thread starter Thread starter evinda
    Limit Sequence
evinda
MHB
Hello! (Wave)
Let $(a_n)$ be a sequence of real numbers such that $a_n \to a$ for some $a \in \mathbb{R}$. I want to show that $\frac{a_1+a_2+\dots+a_n}{n} \to a$.
We have the following:
Let $\epsilon>0$.
Since $a_n \to a$, there is some positive integer $N$ such that if $n \geq N$, then $a-\epsilon<a_n<a+\epsilon$.
Let $b_n=\frac{a_1+a_2+\dots+a_n}{n}$, for $n \geq N$.
We have that $b_n=\frac{a_1+a_2+\dots+a_N}{n}+\frac{a_{N+1}+\dots+a_n}{n}$
and since
$\frac{(n-N)(a-\epsilon)}{n}<\frac{a_{N+1}+\dots+a_n}{n}<\frac{(n-N)(a+\epsilon)}{n}$
we have that
$\frac{C}{n}+\frac{(n-N)(a-\epsilon)}{n}<b_n<\frac{C}{n}+\frac{(n-N)(a+\epsilon)}{n}$
where $C=a_1+a_2+\dots+a_N$.
Can we now just let $n \to +\infty$ ?
Then we would get that $\lim_{n \to +\infty} \left( \frac{C}{n}+ \left( 1-\frac{N}{n}\right)(a-\epsilon)\right)< \lim_{n \to +\infty}b_n < \lim_{n \to +\infty} \left( \frac{C}{n}+\left( 1-\frac{N}{n}\right) (a+\epsilon)\right) \Rightarrow a-\epsilon<\lim_{n \to +\infty} b_n< a+\epsilon \Rightarrow \lim_{n \to +\infty} b_n=a$.
Is this right? :confused:
Because I found the proof online and there they pick $\lim_{n \to +\infty} \sup{b_n}$ in order to get the desired result. But is this necessary? (Thinking)
No, I don't think this is entirely correct, unfortunately. Namely, at this point you have not proven that the limit exists. It looks like you have only shown that
a - \epsilon \le \liminf_{n \to \infty}{b_n}, \limsup_{n \to \infty}{b_n} \le a + \epsilon,
for the fixed $\epsilon > 0$ that you started with. This is not sufficient to establish the limit itself, but you are very close! (Namely, $\epsilon > 0$ can be chosen arbitrarily small, and what do you know about the limit of a sequence when its $\liminf$ and $\limsup$ coincide?)
(Also, note that if you take limits, strict inequalities become non-strict inequalities.)
So we have that $\frac{C}{n}+\frac{(n-N)(a-\epsilon)}{n}<b_n<\frac{C}{n}+\frac{(n-N)(a+\epsilon)}{n}$ for each $n \geq N$. So it also holds for $\sup{b_n}$. So, $\frac{C}{n}+\frac{(n-N)(a-\epsilon)}{n}<\sup{b_n}<\frac{C}{n}+\frac{(n-N)(a+\epsilon)}{n}$. Right?
Do we know that the limit $\lim_{n \to +\infty} \sup{b_n}$ exists? :confused:
Do the equalities $\lim_{n \to +\infty} \sup{b_n}=a$ and $\lim_{n \to +\infty} \inf{b_n}=a$ imply that $\lim_{n \to +\infty} b_n$ exists and is equal to $a$ ? (Thinking)
Yes, provided that in the second equation, you replace the strict inequalities $<$ with non-strict inequalities $\le$.
Recall that by definition
\limsup_{n \to \infty}{b_n} := \lim_{n \to \infty}{\sup_{k \ge n}{b_k}}, \qquad \liminf_{n \to \infty}{b_n} := \lim_{n \to \infty}{\inf_{k \ge n}{b_k}}.
So you are really taking the limits as $n \to \infty$ of the decreasing sequence $(\sup_{k \ge n}{b_k})_n$ and the increasing sequence $(\inf_{k \ge n}{b_k})_n$. Since both sequences are also bounded, these limits exist. (This is a theorem.)
Yes. This is another theorem. You may want to look up these two theorems and their proofs in your analysis notes. (You will be able to follow the proofs.) They are used often.
Nice... Thank you... (Smirk)
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
