MHB Domain and range of inverse functions (circular and hyperbolic)
The discussion focuses on the challenges of determining the domain and range of inverse trigonometric functions, particularly $\sin^{-1}(x)$ and $\sec^{-1}(x)$. Participants describe methods for visualizing these functions, such as using the unit circle and flipping graphs over the line $y=x$. There is a consensus that while memorization can be helpful, understanding the underlying principles and practicing can make it easier to recall the domains and ranges. Some express that the process feels tedious, and they seek quicker methods for determining these values. Overall, familiarity and practice are emphasized as key to mastering inverse functions.
Dethrone
I've always been having trouble with the domain and range of inverse trigonometric functions. For example, let's start with an easy one: $\sin^{-1}\left({x}\right)$
Process: First, I draw out the function of $\sin\left({x}\right)$. Then I look at its range and attempt to restrict it so that it is invertible, which is from $\frac{-\pi}{2}$ to $\frac{\pi}{2}$. Now to draw the graph, I have to rotate it by the axis $y=x$...I can't seem to visualize how to do that...Do I turn my page sideways?
Let's try another one: $\sec^{-1}\left({x}\right)$
Drawing $\sec\left({x}\right)$ first, I look at its asymptotes which are when $\cos\left({x}\right)$ is equal to $0$ on... Does someone actually go through all this work to find the domain and range of $\sec^{-1}\left({x}\right)$? Or do they have it memorized?
This seems very tedious and a lot of work to know the domain and range of inverse functions. Is there a quicker way? (Wondering)
Mathematics news on Phys.org
Yep. That's a way to do it.
I usually visualize the unit circle in my mind and consider the range of the sine and the corresponding angles "that make sense".
Not rotate - flip.
That is, keep the page fixed at bottom-left and top-right, and flip it.
Or you start with the sine graph and the line $y=x$ and then mirror a couple of key points in the line.
Alternatively you can start by marking the horizontal axis with -1 and +1, and mark a couple of points to help draw the graph.
I'm afraid I never use $\sec$, so I'm usually not interested in its domain or range.
If someone asks, I just have to look it up, or figure it out again.
I usually use $\frac{1}{\cos x}$ instead.
With practice they tend to stick to mind. But it's not too bad if you forget. You just need a quick and reliable way to deduce them. (Sweating)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
