Domain and range of the function (arctan(ln(sqrtx)-1)))^3
In summary, the function f(x) = (arctan(ln(sqrtx - 1)))^3 has a domain of x>0 when x ≠ 1, and a range of -∏/2 to ∏/2. It is best to work from the inside out when finding the domain and range, and the effect of the cubed on the equation is to simply raise the result of the inside function to the power of 3.
Emworthington
domain of arctan: all real numbers
range of arctan: -∏/2, ∏/2
I know that domain is x>0 when x ≠ 1, because I need a positive number to go under the radical and the natural log of 0 is undefined. For the range, then, I worked inwards through the parentheses and then set lnsqrt(x) -1 greater than -pi/2 and less than pi/2. Still, I think I may have made a mistake because my answers keep coming out different. Also, I don't know the effect that the cubed on the whole equation has. Any help to clarify would be greatly appreciated.
I know that domain is x>0 when x ≠ 1, because I need a positive number to go under the radical and the natural log of 0 is undefined. For the range, then, I worked inwards through the parentheses and then set ln(sqrt(x) -1) greater than -pi/2 and less than pi/2. Still, I think I may have made a mistake because my answers keep coming out different. Also, I don't know the effect that the cubed on the whole equation has. Any help to clarify would be greatly appreciated.
It's best to work from the inside out.
In general, the Domain of f(g(x)) is: all values of x in the domain of g, such that g(x) is in the domain of f .
Finding the range can be a bit trickier.
Is your function [itex]f(x)=\arctan(\ln(\sqrt{x}-1)\,)\,?[/itex]
Or is it [itex]f(x)=\arctan(\ln(\sqrt{x-1}\,)\,)\,?[/itex]
FAQ: Domain and range of the function (arctan(ln(sqrtx)-1)))^3
What is the domain of the function (arctan(ln(sqrtx)-1)))^3?
The domain of the function (arctan(ln(sqrtx)-1)))^3 is all real numbers greater than or equal to 0. This is because the square root cannot take a negative value, and the natural logarithm function is only defined for positive numbers.
What is the range of the function (arctan(ln(sqrtx)-1)))^3?
The range of the function (arctan(ln(sqrtx)-1)))^3 is all real numbers. This is because the arctangent function (arctan) has a range of (-π/2, π/2), and raising it to the power of 3 does not change this range. Additionally, the natural logarithm function (ln) has a range of all real numbers, and taking the square root of a positive number also results in all real numbers.
How do you graph the function (arctan(ln(sqrtx)-1)))^3?
To graph the function (arctan(ln(sqrtx)-1)))^3, you can plot points by choosing different values for x and calculating the corresponding y values using the function. Alternatively, you can use a graphing calculator or software to plot the function.
Is the function (arctan(ln(sqrtx)-1)))^3 one-to-one?
Yes, the function (arctan(ln(sqrtx)-1)))^3 is one-to-one. This means that for every input, there is exactly one output. This can be seen by the fact that each unique input value results in a unique output value.
Can the function (arctan(ln(sqrtx)-1)))^3 be simplified?
Yes, the function (arctan(ln(sqrtx)-1)))^3 can be simplified using trigonometric identities and properties of logarithms. However, the simplified form may not be as easily recognizable or interpretable as the original form.
