Donor Impurities and the Forbidden region
  • Thread starter BOAS
  • Tags
    Impurities
In summary, the band gap is the region in a semiconductor where the energy levels of the conduction and valence bands meet, and adding an impurity to a material changes the energy level of the dopant so that it falls within the gap.
BOAS
552
Hello,
I am doing my prep work for the 'Hall Effect' experiment that I will be doing next week in labs and have a question regarding the forbidden region between the valence band and the conduction band. I haven't taken any formal solid state physics, but this is 2nd year lab, if that helps.
The description of band theory for conductors and insulators is easy to understand, with the fermi level being in the conduction band for conductors, allowing electrons to be in the conduction band when in the ground state, and the fermi level being in the valence band for insulators.
The energy gap between the conduction and valence band is small for semiconductors, which makes their properties highly temperature dependent. We dope the material in order to make it more useful.
N-Type Extrinsic semiconductors are doped with donor impurities that contribute electron energy levels high in the band gap and shifts the fermi level. It is now easy to elevate these electrons into the conduction band with an applied voltage, but I thought this 'band gap' was the forbidden region.
What is missing/wrong with this understanding?
BOAS said:
Hello,
The band gap is a "forbidden" region only for the parent semiconductor. The dopant has a separate energy level.
Zz.
Zz.
Thanks.
So, am I correct in thinking that the adding of an impurity effectively changes the forbidden region? Electrons from the parent semi conductor can now be 'promoted' into the energy levels provided by an acceptor, so this part of the band gap no longer seems to be 'forbidden' in the sense that electrons are not allowed to populate it.
BOAS said:
Thanks.
I'm not exactly sure what you mean by "changes the forbidden region". The band gap remains the same (i.e. as in the size). The dopant simply has an energy state that happens to fall somewhere in the gap region, and the non-zero temperature allows it to add charge carrier to the semiconductor.
Zz.
Zz.
I was imagining that this new energy level became the boundary for the valence band, but I can see that this is mistaken.
The gap stays the same size, and the dopant adds an energy level somewhere in the gap, making the energy required to reach the conduction band (in a donors case) less, and provides an easy route for electrons to move from the valence band to the new energy level (in an acceptor case) creating holes, since it no longer has to jump all the way to the conduction band.
Related to Donor Impurities and the Forbidden region
1. What are donor impurities?
Donor impurities are atoms of an element that are intentionally added to a semiconductor material to change its electrical properties.
2. How do donor impurities affect the forbidden region of a semiconductor?
Donor impurities introduce additional energy levels within the forbidden region of a semiconductor, making it easier for electrons to move from the valence band to the conduction band.
3. What is the significance of the forbidden region in a semiconductor?
The forbidden region, also known as the band gap, is an energy range where electrons are not allowed to exist in a semiconductor material. This region determines the electrical conductivity of a material.
4. How do donor impurities impact the conductivity of a semiconductor?
Donor impurities increase the concentration of free electrons in a semiconductor, leading to a higher conductivity. This is because the additional energy levels created by the impurities allow for easier movement of electrons within the material.
5. Can the concentration of donor impurities be controlled in a semiconductor?
Yes, the concentration of donor impurities can be controlled during the manufacturing process of a semiconductor material. This is important for achieving desired electrical properties in electronic devices.
  • Atomic and Condensed Matter
13K
