Don't understand this template with nontype in the book
  • Thread starter Thread starter yungman
    Book
The discussion revolves around understanding a C++ template function example from a book, contrasting it with a simpler version. The first example uses a standard template function with parameters for low and high values, while the second example introduces a more complex syntax involving explicit template instantiation, where the types and values are specified directly in the function call. Participants express confusion over this syntax and its relevance, questioning whether it is a newer feature compared to what is presented in older programming texts. Suggestions are made to search for "function template instantiation" and "explicit instantiation" to better understand the concept. However, some participants find the documentation challenging to comprehend, highlighting the importance of grasping the syntax to effectively navigate programming resources.
yungman
This is actually very simple. I think the normal way is done like this:
C++:
#include<iostream>
using namespace std;
template<class T2>
auto inRange(const T2& value, int low, int hi)
    if ((value <= hi) && (value >= low)) return "It is in range.";
    else return " It is out of range.";
int main()
    int val1 = 99;
    cout << inRange(val1, 100, 500)  << "\n\n";
    return 0;
But this is from the Ivor book:
C++:
#include<iostream>
template<class T1, int low, int hi>//how does this work
auto inRange(const T1& value)
int main()
    int val2 = 200;
    cout << inRange<double, 100, 500>(val2);//what is this, it not in the function parameter
    cout << "\n\n";
    return 0;
I have no idea what the book is doing, what is inRange<double, 100, 500>(val2);? I never seen this before. Is this something newer than my old Gaddis book again?
Thanks
Technology news on Phys.org
Did you try a web search for "function template instantiation" or similar? I don't believe this is newer than what is presented in the Gaddis book, but his intent wasn't to present every possible detail of all of the features of C++.
Here is some documentation similar to the example you posted - Explicit Instantiation | Microsoft Docs
The std::array we got with C++11 is a very useful example of this.
Yes, I tried. It would really help IF I know to look for Explict Instantiation. Problem for me is if I don't know the syntax, I don't know what terms to search.
Honestly, I read your link, I have no idea what it is saying. But now I know the term to look for, I'll dig around.
thanks
This is something that was covered in previous posts about template functions - explicit instantiation vs. implicit instantiation.
Well, that's a problem. You can't get very far in programming if you don't understand what is being said in the documentation for some feature of the language.
Likes Vanadium 50
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
