Don't understand tower of Hanoi Program Stack
In summary, the code includes #include <array> and references the array and it's methods (xxxyyy) using "std::array" and "std::xxxyyy".
FallenApple
566
61
1)I have two questions. I don't know why pegs[0].push(i); is used inside the for loop in the first void function. It makes sense that the program needs rings to be placed on a stack. But why pegs[0]? why not pegs[i]?
Mod note: Edited pegs[ i] above to prevent the following text to be rendered as italic.
2) What is the array <stack<int>,kNumPegs>pegs ? Is it a vector? Vectors have that <> symbol. And why is the stack inside? Is it because we need 3 pegs?3)Also, I can't get this to implement in the main. I got this code from my book but they didn't have a main function to test it. So I got a bunch of errors. My C++ is a bit rusty so I don't know what should be done in the main to implement this.
Code:
#include <iostream>
using namespace std;
const int kNumPegs=3;
void ComputeTowerHanoi(int num_rings){
  array <stack<int>,kNumPegs>pegs; //initialize pegs
  for(int i=num_rings; i>=1; --i){
    pegs[0].push(i);
  ComputeTowerHanoiSteps(num_rings,pegs,0,1,2);
}void ComputeTowerHanoiSteps(int num_rings_to_move,array<stack<int>,kNumPegs>&pegs, int from_peg,int to_peg,int use_peg){
if(num_rings_to_move>0){
  ComputeTowerHanoiSteps(num_rings_to_move-1,pegs,from_peg,use_peg,to_peg);
  pegs[to_peg].push(pegs[from_peg].top());
  pegs[from_peg].pop();
  cout<<"Move from peg "<<from_peg<<" to peg "<<to_peg<<endl;
  ComputeTowerHanoiSteps(num_rings_to_move-1,pegs,use_peg,to_peg,from_peg);
}int main() {
    ComputeTowerHanoi(3);
Technology news on Phys.org
FallenApple said:
1)I have two questions. I don't know why pegs[0].push(i); is used inside the for loop in the first void function. It makes sense that the program needs rings to be placed on a stack. But why pegs[0]? why not pegs?
All the disks start on the first peg, peg[0].
The disks on each of the pegs are handled using the template for a LIFO stack (see http://www.cplusplus.com/reference/stack/stack/ ). That gives you methods for putting a disk on top (push) and removing the top disk (pop).
This code uses C++ features like templates. Be sure that you are compiling and using it as you should for C++ rather than C. Beyond that, you need to say what the error messages are so you can get good help. The first error message should be addressed first, because the ones that follow may just be dominoing from the first.
FactChecker said:
All the disks start on the first peg, peg[0].The disks on each of the pegs are handled using the template for a LIFO stack (see http://www.cplusplus.com/reference/stack/stack/ ). That gives you methods for putting a disk on top (push) and removing the top disk (pop).This code uses C++ features like templates. Be sure that you are compiling and using it as you should for C++ rather than C. Beyond that, you need to say what the error messages are so you can get good help. The first error message should be addressed first, because the ones that follow may just be dominoing from the first.
The error message is
"main.cpp: In function 'void ComputeTowerHanoi(int)': main.cpp:7:3: error: 'array' was not declared in this scope"
Which is strange because it is delared inside the function call for the purposes of computing the answer. It would disappear later, but that shouldn't matter.
I don't have a compiler here, so I can't help much. Try this at the top:
#include <array>
and reference the array and it's methods (xxxyyy) using "std::array" and "std::xxxyyy"
(see http://en.cppreference.com/w/cpp/container/array )
Maybe some of the other includes in the reference are also needed.
Beyond that, I can't help since I don't have a C++ compiler and don't remember specifics. Hopefully someone else can provide more help.
#include <array>
In addition to what @FactChecker said, you have to also #include <stack>.
Also, in the code below, which is the code cited in the compiler error, since you haven't included the necessary header files, the compiler doesn't know what to make of "array" and "stack." The comment is misleading, as there is no initializing going on. This is only a declaration, and only a partial one at that.
Before the array can be initialized (values stored in it), each of the three stack objects has to also be initialized.
C:
    pegs[0].push(i);
Likes FactChecker
Here is a program stub in Pascal that implements the Towers of Hanoi.
Code:
Const
  Hmax = 12;
  HWunit = 8;
  HSpace = 160;
Type
Skive = record
  sz: integer;
  w, h: integer;
  c: TColor;
  end;
Stang = record
   Ramme: TRect;
   Tykkelse: integer;
   Antall: integer;
   stabel: Array[1..Hmax] of Skive;
   end;
procedure Hanoi;
var
  n: integer;
  Tavle: TRect;
  Rep: Variant;
  Stenger: Array[1..3] of Stang;
Procedure Setup;
Var
  i, j, k: Integer;
Begin
  For i:=1 to 3 Do Begin
    Stenger[i].Tykkelse := HWunit div 2;
    Stenger[i].Ramme.Left := (i-1)*HSpace + xoffset;
    Stenger[i].Ramme.Right := Stenger[i].Ramme.Left + HSpace - 16;
    Stenger[i].Ramme.Bottom := Height;
    Stenger[i].Ramme.Top := Height - (Hmax + 4)*HWunit;
    if (i=1) then with Stenger[i] do begin
      Antall := n;
      for j := 1 to Antall do begin
        k := Antall + 1 - j;
        stabel[j].sz := k;
        stabel[j].w := (k + 2)*HWunit;
        stabel[j].h := HWunit;
        case j of
          1: stabel[j].c := clBlue;
          2: stabel[j].c := clFuchsia;
          3: stabel[j].c := clGreen;
          4: stabel[j].c := clLime;
          5: stabel[j].c := clMaroon;
          6: stabel[j].c := clNavy;
          7: stabel[j].c := clOlive;
          8: stabel[j].c := clPurple;
          9: stabel[j].c := clRed;
          10: stabel[j].c := clSilver;
          11: stabel[j].c := clTeal;
          12: stabel[j].c := clYellow;
          end;
        end;
      end else
      Stenger[i].Antall := 0;
    end;
End;
Procedure paintStack(i: integer);
var
  j, k, l: integer;
  R: TRect;
Begin
  if ((i>=1) and (i<=3)) then
    with Stenger[i] do Begin
      Lerret.Canvas.Brush.Color := clBtnFace;
      Lerret.Canvas.FillRect(Ramme);
      R.Left := Ramme.Left + 2;
      R.Right := Ramme.Right - 2;
      R.Bottom := Ramme.Bottom;
      R.Top := Ramme.Bottom - Tykkelse;
      Lerret.Canvas.Brush.Color := clAqua;
      Lerret.Canvas.FillRect(R);
      R.Top := Ramme.Top;
      l := (Ramme.Right - Ramme.Left - Tykkelse) div 2;
      R.Left := Ramme.Left + l;
      R.Right := R.Left + Tykkelse;
      k := Tykkelse + 1;
      l := (Ramme.Right + Ramme.Left) div 2;
        R.Bottom := Ramme.Bottom - k;
        R.Top := R.Bottom - stabel[j].h;
        k := k + stabel[j].h + 1;
        R.Left := l - (stabel[j].w div 2);
        R.Right := R.Left + stabel[j].w;
        Lerret.Canvas.Brush.Color := stabel[j].c;
        end;
    end;
End;
procedure PaintAll;
Var
  p: integer;
Begin
  if DoAll then begin
    while (not Lerret.forts) do
      Application.ProcessMessages;
    Lerret.forts := False;
    end;
  for p := 1 to 3 do
    paintStack(p);
End;
Procedure Move(a, b, c, num: Integer);
Var
  na, nb: integer;
Begin
  na := Stenger[a].Antall;
  nb := Stenger[b].Antall;
  if (num=1) then begin
    Inc(nb);
    Stenger[b].stabel[nb] := Stenger[a].stabel[na];
    Stenger[b].Antall := nb;
    Dec(na);
    Stenger[a].Antall := na;
    PaintAll;
    end
  else begin
    Move(a, c, b, num - 1);
    Move(a, b, c, 1);
    Move(c, b, a, num -1);
    end;
End;
Related to Don't understand tower of Hanoi Program Stack
1. What is the Tower of Hanoi program stack?
The Tower of Hanoi program stack is a classic mathematical puzzle that involves moving a stack of disks from one peg to another, using a third peg as an intermediate. The goal is to move the entire stack to a different peg, following specific rules for moving the disks.
2. How does the Tower of Hanoi program stack work?
The Tower of Hanoi program stack follows a set of rules for moving the disks. Only one disk can be moved at a time, and a larger disk cannot be placed on top of a smaller disk. The disks must always be stacked in order from largest to smallest on any given peg.
3. What is the purpose of the Tower of Hanoi program stack?
The Tower of Hanoi program stack is often used as a tool for teaching problem-solving skills, mathematical thinking, and algorithmic processes. It also has practical applications in computer science, such as in data sorting and searching algorithms.
4. How do you solve the Tower of Hanoi program stack?
To solve the Tower of Hanoi program stack, follow these steps:
  • Start by moving the top disk from the starting peg to the destination peg.
  • Next, move the next smallest disk from the starting peg to the intermediate peg.
  • Move the original top disk from the destination peg to the intermediate peg.
  • Repeat this process, moving the next smallest disk from the starting peg to the destination peg, and then back to the intermediate peg until all disks are on the destination peg.
5. Why is understanding the Tower of Hanoi program stack important in computer science?
The Tower of Hanoi program stack is an important concept in computer science as it demonstrates the power of recursion and the importance of algorithmic thinking in solving complex problems. It also has practical applications in data sorting and searching, as well as in understanding the limitations and capabilities of computer systems.
