Doppler effect and how it affects the light spectrum
In summary, the Doppler effect can be separated from the original spectrum of light emanating from a moving body through the recognition of emission and absorption lines in the spectrum, which are determined by atomic physics and remain consistent throughout the universe. This allows for the identification of the shifted spectrum and the original spectrum, revealing the effect of the Doppler shift. Additionally, a prism can also be used to differentiate between elements in a single light beam by observing the spectrum produced.
roineust
338
Looking for a beginners explanation to the following question:
How is Doppler effect separated from the original spectrum of light emanating from a moving body (in astronomy or other physics branches)?
If the question does not make sense, here is the reasoning to ask it:
If a certain color is emanating from a moving body, then it is shifted to red or to blue, according to the speed and relative direction of that body. Does this mean that the observed color is a 'scrambled' signal of both its original color and its shifted color? How are these 2 original causes separated back into their original values?
I assume that i did not take into account in my question the difference between wave frequency and wave length and that is perhaps important in considering the answer?
Science news on Phys.org
Good question. Spectra have recognizable features. They have emission lines and absorbsion lines with frequencies determined by atomic physics. We know that no matter where we are in the universe, the atomic elements there (such as hydrogen) are the same as here. So, like in the picture below, it becomes intuitively obvious that the spectrum has been shifted.
Does that answer your question?
Likes Dale, roineust and PeroK
Got it, the change in relative position or pattern of spectral lines of different elements, thanks!
Another question:
How are different elements spectral lines naturally 'scrambled' and then differentiated by observation into each and every element contained in a 'single' light beam emanating from a light source?
This is the type of question that I ask my students in their homework and/or quizzes. Are you sure we are not doing your assignment for you?
Second question: have you ever played with a prism before?
Zz.
Likes roineust and anorlunda
Related to Doppler effect and how it affects the light spectrum
1. What is the Doppler effect?
The Doppler effect is a phenomenon in which the perceived frequency of a wave, such as sound or light, changes when the source and observer are in relative motion. This means that the wavelength of the wave appears to be either stretched or compressed depending on the direction of motion.
2. How does the Doppler effect affect the light spectrum?
The Doppler effect can affect the light spectrum in two ways: redshift and blueshift. Redshift occurs when the source of light is moving away from the observer, causing the wavelength to appear longer and the light to shift towards the red end of the spectrum. Blueshift occurs when the source of light is moving towards the observer, causing the wavelength to appear shorter and the light to shift towards the blue end of the spectrum.
3. What causes the Doppler effect?
The Doppler effect is caused by the relative motion between the source of the wave and the observer. This can be due to the movement of the source, the observer, or both. For example, the Doppler effect can be observed when an ambulance with a siren passes by, causing the pitch of the siren to change as it approaches and then moves away from the observer.
4. How is the Doppler effect used in astronomy?
The Doppler effect is used in astronomy to measure the motion and speed of celestial objects, such as stars and galaxies. By analyzing the redshift or blueshift of the light emitted from these objects, scientists can determine whether they are moving towards or away from Earth and at what speed. This information can provide insights into the structure and evolution of the universe.
5. Can the Doppler effect be observed in other types of waves?
Yes, the Doppler effect can be observed in all types of waves, including sound, light, and water waves. However, the effect is most commonly associated with sound waves due to its practical applications, such as in radar and sonar technology. The Doppler effect is also observed in seismic waves, which are used to study earthquakes and the Earth's interior.
  • Optics
  • Quantum Physics
