B Doppler effect in moving medium?
The discussion centers on the effect of wind on sound frequency perception between a fixed source and listener. It questions whether the scenario of wind blowing from the source to the listener differs from both moving at the wind's speed in a windless frame. It concludes that both situations are equivalent, but the standard non-relativistic Doppler formula does not apply. A general Doppler formula is suggested for accurate calculations in such cases. Understanding these nuances is essential for correctly interpreting sound frequency changes in varying conditions.
xxxyyy
Hi there,
here's the problem:
There's a sound, with a certain frequency coming, from a source.
Both the listener and the source are fixed in a inertial reference frame.
But there's wind blowing from the source to the listener.
Now, this situation isn't the same as the listener chasing the source, both moving with the speed of wind, in a reference frame with no wind?
This would give no change in frequency for the listener, I guess.
The solution in my book gives me another answer: source fixed, listener moving towards the source at the speed of wind (in a reference frame with no wind).
Who's right?
Thanks for the help!
Yes, it is the same. However, the typical non-relativistic Doppler formula does not work for this.
Here is a page on the general Doppler formula that applies for everything.
https://www.mathpages.com/rr/s2-04/2-04.htm
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
