Doppler Effect of a 1-kilohertz sound
In summary, the conversation is about finding the correct formula to calculate the frequency of a sound emitted by a source moving towards the listener. The correct formula is f' = f*v/(v+vr), where f' is the observed frequency, f is the emitted frequency, v is the speed of sound, and vr is the radial component of the source's velocity. The key to solving the problem is understanding that vr should be negative when the source is moving towards the listener.
Fanaticus
A source of 1-kilohertz sound is moving straight toward you at a speed .9 times the speed of sound. The frequency you receive is:
[tex] \nu = \frac{v}{\lambda} [/tex]
[tex] f' = \frac{v + v'}{v} f [/tex]
When I attempt the solution I get [tex] f' = \frac{v + .9v}{v} f = 1.9 f [/tex]. However, that is not correct. The answer is 10 f. What am I missing?
Thx
Your sign on the relative velocity probably. You could also work on the algebra that let you change f'=1.9*f into f=1.9*f'. That doesn't seem right either.
Well, the source is moving toward you. So the direction of the sound and the source should have the same sign. I don't know. I am missing something small I am sure, because this is a GRE question so it shouldn't take long to solve.
The formula I've got is f'=f*v/(v+vr). f' is observed frequency, f is emitted frequency. vr is radial component of source velocity. v is speed of sound. If it's moving towards you, you want an increase in frequency. That mean vr should be negative to make numerator larger than denominator.
Ok, thx. The formula I was using seems to be for a moving listener not a moving source.
I see how you justify making the vr negative. However it still seems odd since vr and v are going in the same direction, know what I mean?
v is the speed of sound. It's isn't going in any particular direction. vr is coming towards you. Apparently according to the conventions of that formula that makes vr negative.
FAQ: Doppler Effect of a 1-kilohertz sound
What is the Doppler Effect?
The Doppler Effect is the change in frequency or pitch of a sound wave as the source of the sound moves towards or away from an observer. This effect is caused by the compression or expansion of sound waves due to the relative motion between the source and the observer.
How does the Doppler Effect affect a 1-kilohertz sound?
The Doppler Effect causes the frequency of a 1-kilohertz sound to increase if the source is moving towards the observer and decrease if the source is moving away from the observer. This change in frequency is perceived as a change in pitch.
What factors influence the magnitude of the Doppler Effect?
The magnitude of the Doppler Effect is influenced by the speed of the source and observer, the distance between them, and the speed of sound in the medium through which the sound is traveling.
How is the Doppler Effect used in real-world applications?
The Doppler Effect has many practical applications, such as in weather radar systems, medical ultrasound imaging, and police radar guns. It is also used in astronomy to measure the movement of stars and galaxies.
Can the Doppler Effect be observed with other types of waves besides sound?
Yes, the Doppler Effect can be observed with any type of wave, including light waves and water waves. In fact, the colors of stars can be used to determine whether they are moving towards or away from Earth, similar to how the Doppler Effect is used with sound waves.
